Post 710075 by Kingsford G on 2014-05-08 19:55:44
Does anyone know if I can bring the back down just by changing the rear shocks and keeping the stock springs?Looks like I have nivos there.
If you put standard shocks on I seem to think mrp said it will drop by about 40mm
[QUOTE=expolicev70t5;710107]If you put standard shocks on I seem to think mrp said it will drop by about 40mm[/QUOTE] Not on the s60. If it has nivs (which is very unusual on the s60 plodder) you can put standard shocks on but I doubt it'll drop much - they always sit high at the back. You could fit 40mm springs on the back and 30mm on the front to level it up a bit.
