awd
Post 710956 by abdul on 2014-05-11 20:57:27
Want the awd on my v70 checked where can I take it in the north west or further if I have to
Post 711745 by Dan H on 2014-05-14 19:59:23
Put it on 4 axel stands/two poster lift and start the car then put it in gear, all 4 wheels should go, Or the fun way, get on some damp grass/gravel and see if it goes sideways. I had mine go sideways the other day coming off a roundabout in the wet so I know mine works.
Post 711749 by foammanmark on 2014-05-14 20:06:16
Certainly worked when I had her Abdul. Do you suspect a fault?
Post 711769 by abdul on 2014-05-14 22:08:41
[QUOTE=foammanmark;711749]Certainly worked when I had her Abdul. Do you suspect a fault?[/QUOTE] Theres no fault just wanted it checked and anything that needs or should be replaced done
Post 711774 by MoleT-5R on 2014-05-14 22:17:49
Sorry Abdul, didn't get back to you after the conversation we had at the Chesire meet regarding your AWD, the company that I was thinking of was MRG (at swindon I believe) and I sure a good few peeps hear have used them, I think Volvokid had his AWD sorted there and praised them high it was a couple of years ago so I hope I have the right member, hope this helps. I will be MOTing our phase3 V70R AWD sortly and sending her to Volvo, following a conversation on the same sunday, for a gearbox flush and software updates, to see if the cures the problems, before I convert her to manual
Post 711787 by abdul on 2014-05-14 22:47:03
[QUOTE=MoleT-5R;711774]Sorry Abdul, didn't get back to you after the conversation we had at the Chesire meet regarding your AWD, the company that I was thinking of was MRG (at swindon I believe) and I sure a good few peeps hear have used them, I think Volvokid had his AWD sorted there and praised them high it was a couple of years ago so I hope I have the right member, hope this helps. I will be MOTing our phase3 V70R AWD sortly and sending her to Volvo, following a conversation on the same sunday, for a gearbox flush and software updates, to see if the cures the problems, before I convert her to manual[/QUOTE] Goingto contact mrg see what they say
