Post 714584 by stribo on 2014-05-26 17:07:39
The ABS light has started coming on intermittently on the S70, and at the same time, the speedo stops working. I plugged my code reader in, and got the above code, would this indicate a sensor, reluctor ring, ABS pump, or any of the above? With the speedo not working, I'm guessing pump, but just need ideas/confirmation.
Post 714588 by merc85 on 2014-05-26 17:13:27
On blacky the Speedo always worked regardless of wether the abs did, mine was dry solder joints
Post 714593 by stribo on 2014-05-26 17:24:25
[QUOTE=merc85;714588]On blacky the Speedo always worked regardless of wether the abs did, mine was dry solder joints[/QUOTE]
Yeah, I think the ME7 cars take their speed signal from a different source.
Post 714594 by merc85 on 2014-05-26 17:27:30
Maybe bud. Blacky did have s70 clocks too , probably diff as me7 :(
