Post 715831 by stribo on 2014-05-31 15:47:31
Got around to fitting the intake pipe to the R today. It's a GWE one and although no-one would argue that his welding is top drawer, his finishing, and attention to detail leaves a lot to be desired though, as the metal pipe still had swarf in it:
Not really what you want to be sending through the engine, the pipe for my C70 has even more in it.
So, to fitting, getting the old one off was a piece of cake, with a couple of extensions and a wobble bit I could get to the jubilee clip holding the pipe to the turbo from the top, then it was just a case of pulling the PCV and vac hoses off it, seperate it from the MAF, and done. Putting the new one on was a bit more fiddly, but I put it on in stages to make access easier, and an hour later it was all back together.
Took it for a quick spin and there's a bit more turbo noise, which is nice, and although I don't know if ultimately any quicker, it certainly sounds more angry. :D All in all very happy.
Post 715851 by AndysR on 2014-05-31 16:15:06
It's amazing how much sound is deadened in the standard corrugated intake pipe isn't it!
Post 715854 by stribo on 2014-05-31 16:16:45
[QUOTE=AndysR;715851]It's amazing how much sound is deadened in the standard corrugated intake pipe isn't it![/QUOTE]
Yeah, I think the metal section helps amplify the sound.
Post 715863 by M-R-P on 2014-05-31 16:30:49
Nice writeup Steve.
The combination of dp and metal intake certainly makes for some satisfying noises.
you should borrow my recirc gizmo sometime chirp chirp ;)
Post 715865 by stribo on 2014-05-31 16:33:18
[QUOTE=M-R-P;715863]Nice writeup Steve.
you should borrow my recirc gizmo sometime chirp chirp ;)[/QUOTE]
I would, but I'm not a chav. :P TBH I like the sound of the recirc, the K24 one sounds a lot different to the 16t one, a lot more urgent. :D
Post 715875 by M-R-P on 2014-05-31 16:46:18
The k24 is an internal piston type and has a sharper sound as a result.
with the recirc locked off, a 17psi gearchange gives of one almighty chirp rather than chattering. Very satisfying but the chatter gets irritating after a while, hence I have a switch to turn the bugger off when not being a chav lol.
Post 715876 by stribo on 2014-05-31 16:48:53
[QUOTE=M-R-P;715875]The k24 is an internal piston type and has a sharper sound as a result.
with the recirc locked off, a 17psi gearchange gives of one almighty chirp rather than chattering. Very satisfying but the chatter gets irritating after a while, hence I have a switch to turn the bugger off when not being a chav lol.[/QUOTE]
And then there's the lag. ;)
Post 716427 by LeeT5 on 2014-06-02 19:00:45
Now you just need to clean that disgusting air filter! :shockedbi
Post 716434 by stribo on 2014-06-02 19:17:44
Was put through the dishwasher after I finished.:P
Post 716435 by Harvey on 2014-06-02 19:19:58
[QUOTE=stribo;716434]Was put through the dishwasher after I finished.:P
[/QUOTE]
What tablets did you use on them ?.
Post 716436 by stribo on 2014-06-02 19:22:14
I didn't, wasn't sure whether use detergent or not, I text MRP, but they went in before he replied, he said dishwasher detergent for future reference.
Post 716437 by Tomcat on 2014-06-02 19:23:13
Dishwasher??... Really?.. Oh dear god,lol... You know you're supposed to clean them inside out (ie.. rinse them from the inside out) otherwise you're just pushing any trapped dirt deeper into the filter. Hope you're gonna re oil them afterwards... :)
Post 716438 by Harvey on 2014-06-02 19:25:00
[QUOTE=stribo;716436]I didn't, wasn't sure whether use detergent or not, I text MRP, but they went in before he replied, he said dishwasher detergent for future reference.[/QUOTE]
What do the manufacturer say you should use to clean them ?.
Post 716439 by stribo on 2014-06-02 19:26:34
[QUOTE=Tomcat;716437]Dishwasher??... Really?.. Oh dear god,lol... You know you're supposed to clean them inside out (ie.. rinse them from the inside out) otherwise you're just pushing any trapped dirt deeper into the filter. Hope you're gonna re oil them afterwards... :)[/QUOTE]
After an 1 1/2 hours in the dishwasher (its shortest cycle) I think all the dirt has been pushed through, and out. I've got some pipercross oil, but not sure if it's suitable for K&N filters, as the Pipercross are sponge, and the K&N cotton.
Post 716440 by stribo on 2014-06-02 19:27:11
[QUOTE=Harvey;716438]What do the manufacturer say you should use to clean them ?.[/QUOTE]
They don't mention dishwashers strangely enough ;)
Post 716444 by stribo on 2014-06-02 19:41:21
Yeah, I've seen them before, been using K&N filters for donkey's years, the dishwasher method is a lot easier. ;)
Post 716447 by Jamest5r on 2014-06-02 19:43:23
I'm a.fan of the dishwasher as well :)
Post 716448 by stribo on 2014-06-02 19:44:42
[QUOTE=Jamest5r;716447]I'm a.fan of the dishwasher as well :)
[/QUOTE]
Rachel's gutted it's not big enough to fit a wheel in. :D
Post 716451 by Jamest5r on 2014-06-02 19:48:17
[QUOTE=stribo;716448]Rachel's gutted it's not big enough to fit a wheel in. :D[/QUOTE]
That's what immigrant car washes are for :)
Post 716481 by LeeT5 on 2014-06-02 20:41:38
Yeah you should use liquid detergent not tablets or powder.
Post 716506 by M-R-P on 2014-06-02 21:12:51
The few times I've oiled a filter, I used extra virgin coconut oil and blew it through with a air line.
Post 716539 by V70 Graham on 2014-06-02 22:42:17
.....and how many 'extra virgins' are there in Poole ?
Post 716547 by M-R-P on 2014-06-02 22:59:20
[QUOTE=V70 Graham;716539].....and how many 'extra virgins' are there in Poole ?[/QUOTE]
More than west Drayton, that's for bloody sure lol
Post 716745 by LeeT5 on 2014-06-04 02:03:59
Too be honest, It's not necessary to oil a cotton filter. I know the manufacturers say you should, but the way I see it is this....
A cotton filter, when clean, filters down to approx 0.05 microns. That's a hell of a lot more than an OE paper filter yet no where near as much as stainless steel race filter.
To put that into perspective....0.05 microns is 0.00005 mm!!! That's so small you can't see it with the naked eye. A particle of dirt that small is not going to damage an engine.
I do not see any need to then spray a load of filter oil all over the filter. All it does is attract dirt that cannot pass through the filter anyway and long term, will knacker your MAF! as well as clog up the filter and ruin it.
I leave mine totally dry and wash it in warm soapy water once a year, rinse then air dry for 24hrs.
Post 716751 by stribo on 2014-06-04 07:02:24
[QUOTE=LeeT5;716745]Too be honest, It's not necessary to oil a cotton filter. I know the manufacturers say you should, but the way I see it is this....
I leave mine totally dry and wash it in warm soapy water once a year, rinse then air dry for 24hrs.[/QUOTE]
Thanks Lee, my thought was to not bother oiling the filter, as you say it just seems to attract dirt.
Post 716752 by M-R-P on 2014-06-04 07:17:42
The exact reason I don't oil filters any more.
