Me7
Post 716264 by Biff on 2014-06-01 22:40:10
I'm just reading up on me7 modifications. I plan on keeping things relatively simple as looks like this one will be my family car. Is it as simple as putting on a blanking plate to get some turbo chatter or are me7's different? Also am I likely to have nivomats on a 00 c70? Thanks boys.
Post 716277 by deathrider311271 on 2014-06-01 23:29:44
blanking plate not a problem but dont bother with a dump valve, as for nivos i couldnt tell you
Post 716280 by Biff on 2014-06-01 23:34:00
[QUOTE=deathrider311271;716277]blanking plate not a problem but dont bother with a dump valve, as for nivos i couldnt tell you[/QUOTE] Cheers Simon. I've read really mixed results across the forums on the blanking plate, some use non return valves etc. I just don't want it chucking a wobbler for the sake of some chatter. I'm not a fan of dump valves anyway. Guess I'll have to stick my head under it when I view it. Cheers again!
Post 716285 by Kingsford G on 2014-06-02 00:10:15
[QUOTE=Biff;716280]Cheers Simon. I've read really mixed results across the forums on the blanking plate, some use non return valves etc. I just don't want it chucking a wobbler for the sake of some chatter. I'm not a fan of dump valves anyway. Guess I'll have to stick my head under it when I view it. Cheers again![/QUOTE] MRP has a nice sound from his set up.I`m sure he`ll be along with the advice
Post 716294 by stribo on 2014-06-02 07:00:09
No nivos on any C70s mate. :D
Post 716301 by M-R-P on 2014-06-02 08:23:20
I can show you how to make a gizmo that'll make it chatter nicely and on high boost, it chirps too :) The engine won't kick off over it either.
Post 716331 by Biff on 2014-06-02 13:16:18
[QUOTE=M-R-P;716301]I can show you how to make a gizmo that'll make it chatter nicely and on high boost, it chirps too :) The engine won't kick off over it either.[/QUOTE] That would be great mate! I've just got to get the car first, hopefully the mrs will let me dip in our savings so I can hop on a train & go to South Wales to pick it up. Thanks Steve, looks like it could go a little lower then! ;)
Post 716332 by stribo on 2014-06-02 13:23:19
[QUOTE=Biff;716331]That would be great mate! I've just got to get the car first, hopefully the mrs will let me dip in our savings so I can hop on a train & go to South Wales to pick it up. Thanks Steve, looks like it could go a little lower then! ;)[/QUOTE] Have you not seen how low mine is?
