Post 718305 by stribo on 2014-06-11 18:45:22
I've bought some wheel spacers from GraemeWelch, and although he supplied wheel bolts for them, they're P2 bolts, and won't fit the C70, so has anyone got any links to some that aren't going to break the bank? I'm after 40mm ones.
Post 718312 by M-R-P on 2014-06-11 18:53:42
Isn't 40mm standard length for the 70 series any way?
Can't you run a die down the ones you've got? :D
Post 718314 by stribo on 2014-06-11 19:01:53
[QUOTE=M-R-P;718312]Isn't 40mm standard length for the 70 series any way? [COLOR="#0000CD"] If it is I want 15mm longer ones.[/COLOR]
[COLOR="#FF0000"]Can't you run a die down the ones you've got?[/COLOR] :D[/QUOTE]
No :P
Post 718319 by S70T5Chris on 2014-06-11 19:08:05
Don @ Kalmar stocks 45mm bolts for the P1's I think. May be worth giving him a shout.
Post 718320 by S70T5Chris on 2014-06-11 19:10:31
Provided they are decent quality, the ones you linked on Ebay arn't too badly priced tbh. I bought a complete set of new Volvo bolts for the S70 a few years ago and it was around £60 IIRC.
The only thing to be careful with aftermarket (sub standard) bolts, is they can and do work their way loose over time.
Post 718334 by T5frankie on 2014-06-11 19:45:48
i have mine out my 850r mate £20 posted??
