B4194T2 owners help!!
Post 718789 by Tommy t4 on 2014-06-13 21:03:56
I've recently bought a replacement engine advertised by a company as a B4194T2. The engine arrived in good condition and with 3 months warranty, the engine code sticker on the cam belt cover has been removed, and the stamped code on the block says B4194T! Does this mean I have a phase 1 lump or do the T2s have this aswell? Many thanks tom
Post 718869 by smithy on 2014-06-14 00:00:24
Phase 2 are vvt on the exhaust cam phase 1 don't have vvt
Post 718883 by Tommy t4 on 2014-06-14 06:30:28
Yes I know that mate, I was questioning whether it was a phase 1 or phase 1.5 (t2) as apossed to b4194t. It's definately not a b4204t5, that's the engine I'm replacing as it's absolutely poo!!
Post 718897 by smithy on 2014-06-14 09:18:18
What happened to your engine .it is known that the early engine has a stronger bottom end and thicker piston walls because of the smaller cc true.but peeps still get good power out of the later t4s though .
Post 718938 by Tommy t4 on 2014-06-14 17:13:53
The previous owner lacked in servicing etc, and had a dodgy mechanic. I replaced everything almost except for the oil pump which gave up on the motorway and seized the lump pretty much, I've only ever had b4194t2s and am on my 8th t4. Hence the reason why I bough this one. Just wanted to make sure it was a T2 which now I'm almost certain of, as it has baffle sump etc.
Post 718947 by 960kg on 2014-06-14 18:57:59
Hi Tommy, I went past your way just two days ago but i missed your oily strip down the hard shoulder Lol....... If you want to know how you can tell a B4194T engine from a B4194T2 ......both as you know 1855 with the stamp as you found on the back of the block saying B4194T on both the blocks .......but you will have to take the sump off and you will see on the T2 that there are cutouts around the main bearing blocks at the bottom of each pot to allow for more oil circulation which tends to keep the temp. down as these blocks are more highly tuneable and are the Holy Grail Of X40 engines.....
Post 718969 by Tommy t4 on 2014-06-14 20:51:08
Thanks Keith, expensive oil that was too, now the motorway has it lol...,
