Post 719258 by Sweep on 2014-06-16 07:54:40
As above, where abouts should my T5 idle? Seems to be around 950-975, sounds high compared to my other cars.
Depending on model, 675 (P2) to 850 for older models iirc
Hmm mine's definitely higher than 850, any clues as to what could cause this?
Idle control valve or a vac leak somewhere probably. Someone with better knowledge on these will be along shortly... :shifty:
Check the throttle cable hasn't been over adjusted.
