Post 56738 by Colin 850 T5 on 2005-11-13 01:00:24
Hi, I'm Colin from Kent.
Will be joining the Volvo ranks, collecting a '95 850 T5 Estate probably next week.
My father had a 245DL for 19 years so they have been in the family somewhat. We also had a 244DL so had two on the drive at one point. I learnt to drive and took my driving test in the 245.
The T5 is replacing the second of two Subaru's which I loved until they have become now a) too common place b) too chavvy.
The first was a Legacy Estate Turbo which was excellent, the current is an Impreza WRX which although fast doesn't have that estate car practicality which I miss. So under the excuse of needing the estate car part, I am changing one thirsty car for another. I have wanted an 850 T5 since they first appeared but couldn't afford an R at the time.
The only thing that bothers me is traction, having got so used to not spinning wheels in the Subaru. The handling will also be different but you can't have your cake and eat it. It will be great having the cavernous interior space and not driving all four wheels all of the time.
I am probably still going to be hunting down super unleaded I suppose?
I was almost getting into a pipe and slippers frame of mind about the impending estate car purchase until I saw the mad T5 with 500 odd horse power and that wonderful 5 cylinder engine note in the video section. Very reminiscent of an Audi 80 quattro I had from way back.
Having watched that I only hope I will be able to be a little restrained with the loud pedal.
I don't plan to tinker with it much (well...) but an LPG conversion seems worth the effort and better brakes a must.
Colin
Post 56740 by Wobbly Dave on 2005-11-13 01:12:13
Don't LPG it - you will be entering a whole world of pain. T5 was never designed to run it. LPG is too dry and the engine runs too hot.
If you want power and economy then buy a D5 and RICA (remap) it. You'll have more torque and more power than a stock T5 and you'll get 40MPG+ all day long
T5 will normally do around 27mpg combined - and I would recommend a 6K oil/filter interval. If you want the best out of her then Optimax/super is a good thing though not entirely necessary. If you have it remapped then it will depend on which map you have as to whether it will need it. I have a C70 which has been somewhat tuned and I defo need it.
Better brakes I would recommend a front pad change (90% of the braking effort is made there) to either Ferodo DS Performance or DS2500 pads. Change your disks as necessary. Plain ones are just fine. I am no great believer in this gimicy drilled and grooved stuff, as it reduces the friction area. IMHO and experience good pads are the key.
Enjoy the ride and the forum.
Post 56791 by Colin 850 T5 on 2005-11-13 12:24:17
Thanks Dave,
Regarding gas, is that a 'it cannot be done' or you have to do a hell of a lot of work to make it work well?
I have pretty good facilities at work including a rolling road as we do some engine management work so the challenge aspect I am used to but are there specifics with a T5 that cannot be overcome?
Water injection would give the engine back the cooling effect that gas cannot provide.
My research on this is still in its infancy and it may just be that I will leave the T5 at home and get a small diesel to go to and from work, weighing up LPG conversion costs and aggro vs running second commuter car.
This is probably the territory for the technical forum.
Thanks,
Colin
Post 56802 by dicky b t5 on 2005-11-13 13:32:05
Hi Colin :welcome: :wiggle:
Post 56821 by Mrsmopp on 2005-11-13 14:34:05
Welcome to the forum!
Why would you want to LPG a T5? The MPG stock will be around the mid twenties so I dont think they are too thirsty for the power you are getting. If mpg is a real issue to you then I would agree with Wobbly, buy a D5.
You "can" LPG a T5 but I think most of us that know these cars well would steer clear.
x
Post 56836 by Colin 850 T5 on 2005-11-13 15:56:22
I guess I have yet to get truly bitten by the T5 'bug'. The 39p a litre thing won't go away though.
Don't want to become a heretic in my first post!
:slap:
Post 56970 by Wobbly Dave on 2005-11-14 13:24:56
[QUOTE=Colin 850 T5]I guess I have yet to get truly bitten by the T5 'bug'. The 39p a litre thing won't go away though.
:slap:[/QUOTE]Not a heretic - just sensible. I know first hand that the T5 running costs are not great.
D5 is way better as an option than the T5 LPG. IMHO you just shouldnt do it. T5 ownership is not built around economy even though it isnt that bad in comparison with other performance estates/saloons. The service intervals are kinder than say evos or scoobs. 39p/litre at what price to the poor car in the long term??
Better a tuned D5 than an LPG T5, I say.
Anyway T5 ownership is not a prerequisite of site membership.
Post 56987 by Martinr on 2005-11-14 14:26:04
The main problem I always find with LPG conversions is the space that the extra gas tank takes up. If you opt for a spare wheel well tank then you have to find a space saver or risk it that one of those seal and reflate gizmos will suffice, they won't if a chunk of the sidewall is ripped out (I know from experience).
I have not heard good reports about LPG and T5's so would steer clear.
Another thing to consider is the price differential of the vehicle.
In the original post you state you are picking up a 95 855. If you were to replace this with a D5 how much more would the purchase price be?
Wouldn't mind betting that the difference would buy a heck of a lot of fuel! Same argument I had with the guy at work who recommended I follow his lead and buy a 206 diesel! Why would I want to waste so much money on a shoe box.
Post 57074 by Colin 850 T5 on 2005-11-14 18:12:48
The gas tank is a bitch, I don't believe in the foamy stuff, as you say, it will be a sidewall and no amount of foam will sort that. Our roads are useless around here with man eating potholes. That means a spare in the back at all times.
I think I will see how the MPG goes and take it from there. Cannot be worse than the Subaru. A D5 is probably beyond what I want to spend although that would be best.
I collect it on Wednesday and have a long drive home so it should be a deciding factor on that run.
What was Volvo's recommendation on fuel? Are they mapped for 95 or 98 as standard?
Will be great not having the Burberry caps flashing and waving anymore
Post 57105 by S60D5 on 2005-11-14 20:20:34
D5 = Awesome
Tuned D5 = ? Not tried one, but I'd love to!
Post 57116 by dicky b t5 on 2005-11-14 21:41:36
[QUOTE=Colin 850 T5]What was Volvo's recommendation on fuel? Are they mapped for 95 or 98 as standard?[/QUOTE]
Hi Colin , Standard you can safely run um on 95 Ron , stick 98 Ron in and they just seem to go alot better (more BHP & Torque...Fifth Gear done a test on this tonight...It Works..!!)
If you have them Rica'd i think you can only run them on 98 Ron.... :B_steerin
Post 57162 by Wobbly Dave on 2005-11-15 00:34:23
I think I will see how the MPG goes and take it from there. Cannot be worse than the Subaru. A D5 is probably beyond what I want to spend although that would be best.[/QUOTE]
You pick up second hand S60 D5s for under 6 grand.
Post 57227 by Colin 850 T5 on 2005-11-15 11:38:12
I have always liked the 850 shape, the later ones just don't do it for me I'm afraid.
Will be getting mine tomorrow so am quite looking forward to the drive home.
Already figure that it will need wheels as the Columba's won't accept meaningful disc diameters. Probably go for the Perfo's. Having had 18" wheels with 35 profile I felt every bump and the rims buckled after a while. 16's have a decent band of rubber and the Perfo's look nice.
Post 57230 by Mrsmopp on 2005-11-15 11:41:13
[QUOTE=Colin 850 T5]I have always liked the 850 shape, the later ones just don't do it for me I'm afraid.
[/QUOTE]
Plus the 850's have personality, sound better and give a much more aggressive drive ;) Cant beat em!
x
Post 57922 by Colin 850 T5 on 2005-11-17 19:21:42
Well I collected my car and have had a very stress free 550 mile drive around, the long way home.
Its excellent, very pleased.
Sounds great, 5 cylinders make a lovely noise. Tracs and ABS lights on so its soldering iron time and a bit of blowing from the middle of the exhaust.
Interior and exterior clean and tidy, no rattles apart from the tailgate.
Handling takes a little getting used to compared to the Japanese roller skate. Its also quick enough.
:B_steerin
Post 57930 by Mrsmopp on 2005-11-17 20:14:46
[QUOTE=Colin 850 T5]Well I collected my car and have had a very stress free 550 mile drive around, the long way home.
:B_steerin[/QUOTE]
All in all then a very happy new owner?!! Great news!
x
