Post 57006 by Engineer on 2005-11-14 15:28:39
Hi mike, hope this info helps.
[font=Verdana][font=Arial]Cost me £20 from www.swautos.co.uk/default.aspx but postage is extra if you don’t pick up.[/font][/font]
[font=Verdana][font=Arial][/font][/font]
[font=Verdana][font=Arial]For S70R 98my turn wipers on and switch ignition off when wipers are pointing upwards, open bonnet partial or full tilt your choice, remove strut brace if fitted, remove the four screws (torque heads) that secure the plastic bulkhead cover (the one that surrounds the wiper arms) remove n/s wiper arm. [/font][/font]
[font=Verdana][font=Arial]Gently pull cover forward to clear windscreen on n/s (mind you don’t scratch wing/bonnet corner) and put something soft underneath to give you room to work, you could remove o/s wiper arm as well and take cover completely off, but this is more work. Pull cable from clip and tuck under air intake to clear area, remove nut 15mm and bolt 13mm which secures bracket to engine mount, now remove the two 15mm nuts securing the bracket/small alloy mount to bulkhead inside under the cover, don’t loose washers. Place assembly to one side. [/font][/font]
[font=Verdana][font=Arial]Ok you should now be looking at the engine mount which has a plastic outer shell void bush fitted inside it. Take a normal hacksaw blade tape up the end opposite to teeth direction (saves blood everywhere) place a suitable cloth to catch swarf and then place blade inside void bush and carefully cut through the plastic case of the bush, this only takes a minute so take care not to cut through metal engine mount, keep blade horizontal, if the note of the blade changes you are cutting metal! [/font][/font]
[font=Verdana][font=Arial]The bush will then just fall out. The replacement bush is in three parts and fits as follows, lube all (supplied with kit) and fit o/s half first, then fit metal sleeve and finally n/s half making sure it is started on the metal sleeve before squeezing together. I used a small portable vice but a G-clamp and suitable sized blocks would suffice. [/font][/font]
[font=Verdana][font=Arial]Re-build in reverse order. [/font][/font]
Post 57367 by Rufe on 2005-11-15 19:27:32
good how 2 mate. the volvo genuine bushes are no where near as good as these replacements, and much more difficult to fit (we get garages coming back to us telling us they are the wrong ones we have supplied, when they are not) these poly replacements in seperate half's are a better idea :)
Post 57368 by colnotts on 2005-11-15 19:32:40
what is the difference???
Post 57392 by siamblue on 2005-11-15 20:54:47
[QUOTE=colnotts]what is the difference???[/QUOTE]
The noise mate is sexy as hell when that 5 pot starts roaring, engine has virtually no movement with the poly bush.
Post 57396 by Unknown on 2005-11-15 21:13:30
Doesn't the poly bush squeek ?
Post 57452 by siamblue on 2005-11-16 00:33:40
[QUOTE=Andrew]Doesn't the poly bush squeek ?[/QUOTE]
No not mine. but mine isn't a hairdressers car :haha:
Post 58216 by Luigi on 2005-11-18 23:35:34
[QUOTE=siamblue]The noise mate is sexy as hell when that 5 pot starts roaring, engine has virtually no movement with the poly bush.[/QUOTE]
I have fitted my poly bush today and what a difference :jaw: the roar is amazing and the 5 pot gurgle is spot on when trundling along. Best 20 quid I ever spent. :jaw:
Post 58219 by BlackBeast on 2005-11-18 23:37:51
Right, im sold, i want a little more noise from the 5pot and for £20 i shall get one very soon :D
Post 58291 by mike 850 on 2005-11-19 11:25:43
yeah me too, just ordered one now :B_steerin
Post 59284 by mike 850 on 2005-11-22 22:36:58
wow, just wow!!!!!!!!!!!!
Post 89379 by Jod T5 on 2006-03-14 17:49:46
gary, how does the poly bush increase the engine noise?? i understand it keeps the engine more rigid but cant understand why eveyone is raving about them.....i want one tho....
jod :B_steerin
Post 89380 by SaffronC70 on 2006-03-14 18:06:24
The Volvo damper is designed to stabilise and absorb engine vibration.
The stiffer poly bush holds the engine firmer; the vibration has to go somewhere, so it is transmitted into the bulkhead, giving the lovely noise inside.
Helps gear changes at high revs as well, as the gearbox will be better positioned.
Also, in my case, handling as improved !
Chris
Post 89382 by Jod T5 on 2006-03-14 18:10:00
thanks chris, a deffo top of the list mod for me then....
cheers
jod
Post 89549 by Babybadger on 2006-03-15 10:07:40
Got there in the end. It has totally transformed the handling of the car. and I don't get the annoying thump on the gearbox changing up gear anymore at low speed. Top mod for not a lot of money.
Post 89550 by Mrsmopp on 2006-03-15 10:09:04
[QUOTE=Babybadger]Got there in the end. It has totally transformed the handling of the car. and I don't get the annoying thump on the gearbox changing up gear anymore at low speed. Top mod for not a lot of money.[/QUOTE]
Just dont do any long motorway journeys!!
The constant droneing is like chinese torture on a long run
x
Post 89552 by Babybadger on 2006-03-15 10:10:21
[QUOTE=Mrsmopp]Just dont do any long motorway journeys!!
x[/QUOTE]
Like the mother in law then........ I am used to it. Funny that I was planning spain in the summer
