P0305 missfire code
Post 732349 by multiskilled on 2014-08-30 09:47:18
Hi all As above had this code come up . Changed plugs but still no better, i cleared the code but it hasnt came back on altough the missfire is still there.could this be a coil pack starting to go
Post 732351 by JamesT5 on 2014-08-30 09:57:35
Coil pack on cylinder 5 mate, I had the same problem. Try clearing the codes, swap the coil packs around and see if the code changes, the last number will change depending on the cylinder, so for example P0301 would be cylinder 1, P0302 would be cylinder 2 etc. Edit: If the coil pack is faulty, it will cause a misfire on whatever cylinder it's on. Once you've established that, then replace the coil pack and you're done. Some people will say replace them all but to be honest, get some second hand ones and then just change them as they fail. Not a big job, I did one at a Motorway services back in May.
Post 732352 by JamesT5 on 2014-08-30 09:58:41
[QUOTE=JamesT5;732351]Coil pack on cylinder 5 mate, I had the same problem. Try clearing the codes, swap the coil packs around and see if the code changes, the last number will change depending on the cylinder, so for example P0301 would be cylinder 1, P0302 would be cylinder 2 etc.[/QUOTE] Just to clarify, cylinder 5 will be the one closest to the passenger side (nearside).
Post 732353 by multiskilled on 2014-08-30 10:07:27
Thaks mate are the coil packs the same on all the engine sizes or are t5 ones diffrent
Post 732375 by JamesT5 on 2014-08-30 11:46:47
[QUOTE=multiskilled;732353]Thaks mate are the coil packs the same on all the engine sizes or are t5 ones diffrent[/QUOTE] Not 100% sure on that one mate but if you contact Andy at Norfolk Volvo Spares, he's normally very reasonably priced and will send you the right ones for your car if you tell him what model and engine you have. NVS are a member on here but also there's a website for them. Genuine Volvo ones are an option but they are pricey at about £50 each.
Post 732416 by multiskilled on 2014-08-30 16:46:14
Thanks new coil fitted and she runs a treat
Post 732417 by V70 Graham on 2014-08-30 16:55:58
[QUOTE=multiskilled;732416]Thanks new coil fitted and she runs a treat[/QUOTE] Excellent news, and well done James for pointing you in the right direction.
