SC-802 does "OFF" mean fu-barred?
Post 732857 by JUDGENINJA on 2014-09-01 18:44:11
Image This is the stereo in the TDi(which I'm sadly enjoying). It seems to be knackered. Does anyone know if you can reset the system at present all it shows is "OFF". I can't press anything at all. I've thought about freezing it, but I have never heard of it working on Volvo stereos. Any ideas before I bin it??
Post 732859 by Harvey on 2014-09-01 18:49:05
No just leave it on for a couple hours,then it will ask for the code . http://www.volvoforums.org.uk/showthread.php?t=108339
Post 732864 by JUDGENINJA on 2014-09-01 19:12:22
It's been a week!
Post 732866 by Harvey on 2014-09-01 19:13:57
With the Key on position one ?.
Post 732867 by stephenevans99 on 2014-09-01 19:20:53
[QUOTE=Harvey;732866]With the Key on position one ?.[/QUOTE] +1 Ignition has to on for 2 hours iirc for it to reset back to CODE
Post 732870 by Jamest5r on 2014-09-01 19:29:13
I've done the same myself goes to off if wrong code is put in 3 times as above leave ignition on my take more than a couple of hours mine took nearly 3 lol
Post 732873 by JUDGENINJA on 2014-09-01 19:36:01
Ah OK...... I did think, but didn't have signal to adjust my original response.. I'll leave the key in when I get to work tonight. Fingers crossed someone will steal it..
Post 732874 by Harvey on 2014-09-01 19:40:06
Hope it works. The stereo that is.
Post 732879 by MoleT-5R on 2014-09-01 19:59:17
had this happen with mine, left the battery off for a week or so and it then asked for the code, hope this helps if you've not already sorted it. :)
