Post 733112 by stribo on 2014-09-03 10:23:30
Since fitting the GWE intake pipe on the C70, I now have no port for the vac pipe from the fuel regulator :slap: is there any other pipe I can tee into? I'm guessing from its previous location it has to be under constant vacuum, so the vac tree will be no good. The only options I can think of is either get a port fitted in the top silicon intake hose, or disconnect the tcv from the intake pipe and connect it there, but then I'll probably get issues with venting metered air to atmosphere. Any suggestions gratefully received. :)
Post 733122 by MoleT-5R on 2014-09-03 11:58:50
as far as I can see the pipe your on about is not the fuel pressure reg one , as that goes to the vacuum tree, the pipe giving you troubles is the one from the inlet manifold that connects to it just behind the power steering pump and runs to the tee as the pcv connects to the inlet, personally I'd try it into the tcv's connection to the inlet and run with the tcv's return off, if this gives issues then another spigot may be required or what about teeing into the on the new inlet ??
Post 733129 by stribo on 2014-09-03 13:09:00
[QUOTE=MoleT-5R;733122]as far as I can see the pipe your on about is not the fuel pressure reg one , as that goes to the vacuum tree, the pipe giving you troubles is the one from the inlet manifold that connects to it just behind the power steering pump and runs to the tee as the pcv connects to the inlet, personally I'd try it into the tcv's connection to the inlet and run with the tcv's return off, if this gives issues then another spigot may be required or what about teeing into the on the new inlet ??[/QUOTE]
The pipe I'm referring to connects to the intake pipe, then down to a metal pipe above the recirc valve, this metal pipe is strapped to the main water pipe that runs behind the engine, then at the other end of the block, connects to another vacuum hose which runs down to the fuel regulator, which is just above the steering rack.
Post 733136 by MoleT-5R on 2014-09-03 13:50:21
[QUOTE=stribo;733129]The pipe I'm referring to connects to the intake pipe, then down to a metal pipe above the recirc valve, this metal pipe is strapped to the main water pipe that runs behind the engine, then at the other end of the block, connects to another vacuum hose which runs down to the fuel regulator, which is just above the steering rack.[/QUOTE]
There are sum small differences between the 4 turbo models I have here but nothing quick like what you describe the closest is the v70r awd me7 but the pipework runs differently to your description
Post 733150 by MoleT-5R on 2014-09-03 15:27:24
Think I'm up to speed now just studied the 850awd which is 4.4, think you will have to add an extra nipple or leave the tcv return pipe off and see how she goes, odd that GWE hasn't supplied the correct no of spigots for your application...;)
Post 733152 by oblark on 2014-09-03 15:41:15
[QUOTE=MoleT-5R;733150]Think I'm up to speed now just studied the 850awd which is 4.4, think you will have to add [COLOR="#FF0000"]an extra nipple [/COLOR]or leave the tcv return pipe off and see how she goes, odd that GWE hasn't supplied the correct no of spigots for your application...;)[/QUOTE]
He is from Basingstoke :haha:
Post 733153 by stribo on 2014-09-03 15:41:50
[QUOTE=MoleT-5R;733150]Think I'm up to speed now just studied the 850awd which is 4.4, think you will have to add an extra nipple or leave the tcv return pipe off and see how she goes, odd that GWE hasn't supplied the correct no of spigots for your application...;)[/QUOTE]
Isn't that strange.;) I've had a thought, if I tee into the small pcv pipe, it should be under vacuum all the time.
Post 733154 by stribo on 2014-09-03 15:42:44
[QUOTE=oblark;733152]He is from Basingstoke :haha:[/QUOTE]
No I'm not :P
Post 733155 by oblark on 2014-09-03 15:44:06
[QUOTE=stribo;733153]Isn't that strange.;) I've had a thought, if I tee into the small pcv pipe, it should be under vacuum all the time.[/QUOTE]
No, any where after the turbo will be under vacuum and pressure.
Post 733158 by stribo on 2014-09-03 15:46:45
[QUOTE=oblark;733155]No, any where after the turbo will be under vacuum and pressure.[/QUOTE]
But the small PCV pipe goes into the intake pipe before the turbo, or is that pipe under pressure when on boost?
Post 733159 by oblark on 2014-09-03 15:49:19
[QUOTE=stribo;733158]But the small PCV pipe goes into the intake pipe before the turbo, or is that pipe under pressure when on boost?[/QUOTE]
And where is the other end of the PCV pipe ????
Post 733163 by M-R-P on 2014-09-03 16:05:22
I think the obvious way to go would be to drill the inlet pipe and resin the pipe or a pipe connector into it. It's the inlet after all and just needs to be secure and sealed, rather than pressure tested.
Post 733166 by t5 pete on 2014-09-03 16:11:28
When I did the midgets I had to send him out for some adapters to make extra T's for the pipe work
Post 733169 by stribo on 2014-09-03 16:23:39
[QUOTE=t5 pete;733166]When I did the midgets I had to send him out for some adapters to make extra T's for the pipe work[/QUOTE]
But what did you tee into?
