wish bones
Post 733513 by Paul,S60r on 2014-09-05 18:33:49
hi, the wish bones have gone on my car and its in the garage next week. My question is where can i get a decent set for a reasonable price and should i change anything else while it's all apart. It's a 2006 S60R.
cheers.
Post 733516 by M-R-P on 2014-09-05 18:37:53
Just get the ones you have fitted with powerflex bushes. You'll never need to do it again. Cheaper too.
Post 733518 by Paul,S60r on 2014-09-05 18:44:36
so don't buy new ones i use the ones that are on the car?
Post 733521 by Harvey on 2014-09-05 18:51:39
Best go and look under car a see what you have fitted.
Volvo did change things in late 2006 cars have a read of this link.
http://www.ipdusa.com/products/5470/114162-front-lower-control-arm-right-s60-v70
Post 733529 by Paul,S60r on 2014-09-05 19:20:11
helpful link cheers.
Post 733612 by Paul,S60r on 2014-09-05 22:09:54
[QUOTE=M-R-P;733516]Just get the ones you have fitted with powerflex bushes. You'll never need to do it again. Cheaper too.[/QUOTE]
Is this advisable?
Post 733617 by silverhorse on 2014-09-05 22:32:26
[QUOTE=Paul,S60r;733612]Is this advisable?[/QUOTE]
Yep. Barsteward of a job though.
Post 733620 by Paul,S60r on 2014-09-05 22:50:06
why? any idea of how long it takes.
Post 733623 by M-R-P on 2014-09-06 00:50:39
Takes about 2 hours a side, depending on tools and skill. Often, it's a good idea to get hold of some old wishbones, fit them with polys and swap them over when you're ready. Still cheaper than genuine volvo wishbones and will last far longer.
Post 733636 by silverhorse on 2014-09-06 09:10:26
[QUOTE=M-R-P;733623]Takes about 2 hours a side, depending on tools and skill. Often, it's a good idea to get hold of some old wishbones, fit them with polys and swap them over when you're ready. Still cheaper than genuine volvo wishbones and will last far longer.[/QUOTE]
It's worth giving it a go Paul, but I guarantee it will take more than 2 hours a side! Make sure you have access to a bush press. There is a 'how to' on here where Martin (MRP in post above) presses them in with a G clamp with the bushes in situ. Still don't know how he did it!
If I had to do it again, I could do it much quicker, but the first time was a bit of a nightmare.
Post 733652 by Paul,S60r on 2014-09-06 11:32:46
Thanks for the advice guys. MRP please will you send me a link to that thread, if possible.
Post 733665 by M-R-P on 2014-09-06 14:06:13
clicky linky
Post 733669 by graemewelch on 2014-09-06 14:14:53
If your stuck for a spare set ive got some hanging up in the garage
Post 733678 by Paul,S60r on 2014-09-06 15:56:45
cheers for the offer. Why do i need a spare set though? I'm confused.
Post 733680 by M-R-P on 2014-09-06 16:10:52
You can fit the bushes on the spare set then fit them at your leisure or get a garage to do them.
That way, you're not left stranded if something goes wrong.
Post 733696 by Paul,S60r on 2014-09-06 17:12:54
Ahhh i see, that's good thinkin. Im in the army and Im planning on getting the mechanics at work to have a go, i don't think they would of had any experience doing this. All the info I've been getting and all the more info i can get to pass on is greatly appreciated.
Thankyou.
Post 733789 by silverhorse on 2014-09-06 22:25:38
If I had to do it again, I would get a spare set and poly bush them before fitting. That's the easiest way of doing it......
Post 733803 by M-R-P on 2014-09-06 23:35:20
Just don't put powerflex bushes in the rear of the wishbones, total arse getting them on the car.
Post 733808 by ExternalError on 2014-09-06 23:53:59
I have powerflex bushes in the rear of my wishbones I dont recall colin or adrian struggling to much to fit them and that was at a campsite
Post 733831 by JamesT5 on 2014-09-07 09:14:45
I agree with MRP, Polybushing is worth every penny.
Post 733843 by claymore on 2014-09-07 09:40:26
[QUOTE=ExternalError;733808]I have powerflex bushes in the rear of my wishbones I dont recall colin or adrian struggling to much to fit them and that was at a campsite[/QUOTE]
The first one was a bit of a struggle, but once we realized that I'd put a os wishbone on the ns things went easy enough :)
Post 733850 by M-R-P on 2014-09-07 10:17:33
Did you drop the subframe?
Post 733862 by claymore on 2014-09-07 11:00:22
[QUOTE=M-R-P;733850]Did you drop the subframe?[/QUOTE]
Nop, two bolts at the back, one at the front and bottom ball joint, about half an hour a side, if that.
Post 733885 by M-R-P on 2014-09-07 13:27:00
[QUOTE=claymore;733862]Nop, two bolts at the back, one at the front and bottom ball joint, about half an hour a side, if that.[/QUOTE]
How the hell did you bend the wishbone down enough to get the ball joint in...
Hang on... Stu has coilivers... D'oh!
Post 733897 by JamesT5 on 2014-09-07 14:45:42
You should have gone for Powerflex Black Series, then sat back with a cold Beer and watched them both sweat their nuts off trying to bend the wishbone down. MRP and I had a right fight fitting my black polybushed wishbones to the T5, heaven help me when it's time to change the ball joints again....... :beammeup: :help:
Post 733969 by ExternalError on 2014-09-07 20:09:23
[QUOTE=M-R-P;733885]How the hell did you bend the wishbone down enough to get the ball joint in...
Hang on... Stu has coilivers... D'oh![/QUOTE]
yeah for once the my low ride height helped
Post 733997 by M-R-P on 2014-09-07 21:15:19
[QUOTE=ExternalError;733969]yeah for once the my low ride height helped[/QUOTE]
Yep. With normal springs, that job in a field would be a no go.
Post 734008 by ExternalError on 2014-09-07 21:31:26
[QUOTE=JamesT5;733897]You should have gone for Powerflex Black Series, then sat back with a cold Beer and watched them both sweat their nuts off trying to bend the wishbone down. MRP and I had a right fight fitting my black polybushed wishbones to the T5, heaven help me when it's time to change the ball joints again....... :beammeup: :help:[/QUOTE]
yeah no thanks to the black polybushes my coilovers are firm enough i dont need the wishbones to be rock solid as well
Post 734015 by ExternalError on 2014-09-07 21:39:08
[QUOTE=M-R-P;733997]Yep. With normal springs, that job in a field would be a no go.[/QUOTE]
lucky really cause the bushes were shot on the ones we swapped off
Post 734016 by claymore on 2014-09-07 21:40:26
I've got black polybush in my wishbones (shock horror) and had no problem fitting them. and yes I know my car is an 850 and the wishbones are different.
Post 734017 by claymore on 2014-09-07 21:42:17
Why, worst scenario would be two bolts to undo the strut.
Post 734062 by JamesT5 on 2014-09-08 00:03:28
[QUOTE=M-R-P;733803]Just don't put powerflex bushes in the rear of the wishbones, total arse getting them on the car.[/QUOTE]
But one hell of a ride! :D
Post 734063 by JamesT5 on 2014-09-08 00:06:43
[QUOTE=claymore;734016]I've got black polybush in my wishbones (shock horror) and had no problem fitting them. and yes I know my car is an 850 and the wishbones are different.[/QUOTE]
Nice to see you're finally taking my advice and seeing sense to my black Polybush approach.
:smileypul :saythat:
Post 734072 by M-R-P on 2014-09-08 00:23:09
they only come in black lol.
850 wishbones are a bloody breeze to do too.
Post 734075 by JamesT5 on 2014-09-08 00:24:58
[QUOTE=M-R-P;734072]they only come in black lol.
850 wishbones are a bloody breeze to do too.[/QUOTE]
Ball joints are built in aren't they? That means that once you're ball joints are trashed you have to replace the entire unit again?
Post 734077 by M-R-P on 2014-09-08 00:26:50
[QUOTE=JamesT5;734075]Ball joints are built in aren't they? That means that once you're ball joints are trashed you have to replace the entire unit again?[/QUOTE]
Most people aware of this issue go looking for the early aluminium wishbones with the removable ball joint. I have a pair in my shed in fact.
Post 734326 by Paul,S60r on 2014-09-09 10:56:02
i have aluminum wish bones, dose this mean i have the shaped bar and not the straightbar.the powerflex ment for shaped bar don't go on the straight one and i don't want to buy the wrong ones.
cheers.
Post 734332 by M-R-P on 2014-09-09 12:08:58
[QUOTE=Paul,S60r;734326]i have aluminum wish bones, dose this mean i have the shaped bar and not the straightbar.the powerflex ment for shaped bar don't go on the straight one and i don't want to buy the wrong ones.
cheers.[/QUOTE]
The aluminium/steel comparison was regarding the P1/850 models mate, not overly relevant here.
It's a bit of a lottery as to which rod will be in there but if you can post a photo, I can usually work it out.
Even if you have the straight rod, it's only a 5 minute job to grind it down to the right size - just measure the hole in the bush and grind the rod to about 1mm bigger.
Post 734338 by Paul,S60r on 2014-09-09 13:22:23
am i right in saying i need these ones, pff88-601.
cheers.
Post 734339 by M-R-P on 2014-09-09 13:36:26
Yep :)
Post 734364 by Paul,S60r on 2014-09-09 17:33:38
decided to go with meyle ready built bushes as i can't be bothered with the hassle. whilst the wish bones are off should i have anything else changed.
Thanks for all the input especially M.R.P
Post 734365 by Redbrick on 2014-09-09 17:49:48
[QUOTE=Paul,S60r;734364]decided to go with meyle ready built bushes as i can't be bothered with the hassle. whilst the wish bones are off should i have anything else changed.
Thanks for all the input especially M.R.P[/QUOTE]
I'd keep the old wishbones and get them Powerflexed so you can bang them on when the Meyle's fail. lol
Post 734370 by M-R-P on 2014-09-09 18:39:15
[QUOTE=Redbrick;734365]I'd keep the old wishbones and get them Powerflexed so you can bang them on when the Meyle's fail. lol[/QUOTE]
+ 1 from me. I've done how to guides for rebuilding wishbones if you need any pointers.
Post 734372 by Paul,S60r on 2014-09-09 19:03:03
i will keep the old ones for when the meyles fail, 4 year warranty though. im thinkin of the guy who's gonna be doin the work he's a colleague and he's gonna be doin it on the cheap so i don't want to take the piss.
thanks again.........
