Post 733681 by Blackdog on 2014-09-06 16:18:43
97 V70 awd. As per the title. I will try the ecu for dry joints first. My question is where the hell is it?
It's under the pump on the n/s at the back of the engine bay, you'll need a E5 torx socket, then 4 bolts, and it's off.
[QUOTE=stribo;733685]It's under the pump on the n/s at the back of the engine bay, you'll need a E5 torx socket, then 4 bolts, and it's off.[/QUOTE] Ta. I was looking on the off side under the servo.
Not a hard job to swap it out, hardest part of resoldering is getting the damn lid off.
not if you know how ;)
