Post 733697 by Blackdog on 2014-09-06 17:17:56
Looks good. Personally I use peanut butter.
Post 733698 by BigChuck on 2014-09-06 17:24:37
[QUOTE=Blackdog;733697]Looks good. Personally I use peanut butter.[/QUOTE]
ive tried that in the past, but it never seemed to last, i used a heat gun in the past as well, but it still needed topping up with one product or another.
this stuff is supposed to last a while, my mate uses it on his jetski and even in salt water it lasts
Post 733726 by Gold 'N' Brown on 2014-09-06 19:24:34
Plasticare (only available on ebay I believe) is about one of the most permanent treatments you'll find. More like a dye than the usual oily trim treatment. Did my V70 a year ago and it still looks black now even though it's only been washed a handful of times since and has no other products to protect it.
Post 733736 by merc85 on 2014-09-06 19:55:20
Old engine oil does the trick for me ;)
Post 733820 by volvokid on 2014-09-07 02:07:27
[QUOTE=Harvey;733735]I did use this stuff a while ago. Lasts very well.
C4
http://www.vpcuk.org/forums/showthread.php?51648-C4-Permanent-trim-restorer-by-Gtechniq[/QUOTE]
I second that stuff is great!
Post 735883 by LeeT5 on 2014-09-17 20:28:47
Meguires trim detail does the same.
Post 735885 by Ettienne on 2014-09-17 20:30:35
Kiwi Liquid black shoe polish then a trim cleaner is what I used on the gul.
Post 735898 by stephenevans99 on 2014-09-17 20:44:53
Wurth Plastidye is good stuff too....I'll be trying the C4 Gtechniq though next.
Post 760410 by volvofan84 on 2015-02-21 16:28:11
The previous owners of my S40 ran a handheld machine polisher over the bumper trim, leaving marks as they went along. Some of the waxes and trim polishes only lightens it but never removes it. Any ideas on how to get rid of it?
Post 760642 by Gold 'N' Brown on 2015-02-22 23:41:52
Are the marks physical scuffs in the plastic, or is it left over polish that has stained the trim?
Post 760650 by kmb on 2015-02-23 08:19:47
When I bought my 850 in October, the bumpers were nearly white and very unevenly stained.
I did some research and the two 'tried and proven' best ways to permanently restore the bumpers, rather than just treat them, seemed to be Wurth Plastic Dye (£34 from Ebay) or Plasticare (£13 delivered from Ebay).
Being 'economic' I went for the Plasticare, it has been on the car stored outside for over 3 months, results are excellent, a true transformation, but it took 2-3 coats.
Mine were so faded I bought the Plasticare black (not grey), I cleaned bumpers, masked the area with tape and then applied with a dabbing motion. End results looked like this:
Before, but after use of poor 'Back to Black':
After 1 coat of Plasticare... and a few days of rain:
Post 760687 by volvofan84 on 2015-02-23 15:32:12
[QUOTE=Gold 'N' Brown;760642]Are the marks physical scuffs in the plastic, or is it left over polish that has stained the trim?[/QUOTE]
Luckily only left over polish that stained it
Post 760688 by volvofan84 on 2015-02-23 15:34:36
[QUOTE=kmb;760650]When I bought my 850 in October, the bumpers were nearly white and very unevenly stained.
Being 'economic' I went for the Plasticare, it has been on the car stored outside for over 3 months, results are excellent, a true transformation, but it took 2-3 coats.[QUOTE]
Ive also tried back to black without any relative success. Will look for the plasticare though, thanks. One problem is that I would have to look locally as SA's postal system is kinda....enough said... so ordering from ebay usually ends up in wasted money with no parcel :'(
Post 760691 by kmb on 2015-02-23 16:04:08
I think the Plasticare sales on Ebay are a small independent importer (seemed to be a home address), so not sure how much success you'll have getting it in SA.
Good luck!
