Post 733766 by DONKEYT5 on 2014-09-06 21:42:00
Hi all -
I have a 1995 850 T5 which I was informed would be odb1 (1993-1995) except mine is an odbii (under the coin tray)
would an 850T5 rica ecu work on it? (advised the ecu is an odb1 version) its also a non air con and my car has aircon....
thanks in advance
Don \m/
Post 733778 by Jamest5r on 2014-09-06 22:05:08
Can't do the link as on my phone but go to the TurboTuner website and it has a compatability table
Post 733783 by DONKEYT5 on 2014-09-06 22:13:32
thanks James - Have had a look thru the page you mean and it says that the Bosch 0 261 200 549 is compatible with the 850 T5 from 1993-1997 - my only thoughts were that odb1 and odb2 could make a difference and that it is for non air con and mine has aircon, or am being too fussy? The rica'd ecu is an odb1 and my car is odb2
thanks in advance
Don
Post 733787 by Jamest5r on 2014-09-06 22:24:00
[QUOTE=DONKEYT5;733783]thanks James - Have had a look thru the page you mean and it says that the Bosch 0 261 200 549 is compatible with the 850 T5 from 1993-1997 - my only thoughts were that odb1 and odb2 could make a difference and that it is for non air con and mine has aircon, or am being too fussy? The rica'd ecu is an odb1 and my car is odb2
thanks in advance
Don[/QUOTE]
No idea tbh lol, i just know that chart is pretty accurate only way to be 100% is to try it
Post 733793 by DONKEYT5 on 2014-09-06 22:40:34
Cheers for that. That chart says it should work...fingers crossed it will :)
