is a C70 wing the same as a V70 wing...
Post 737779 by The Flying Banana on 2014-09-28 16:02:02
does any one know if they are interchangeable ...
Post 737795 by Doingitsideways on 2014-09-28 17:44:07
I don't think they're the same. Didn't the C70 have wider arches to accommodate wider wheels?? Probably identical in every other way though
Post 737803 by Biff on 2014-09-28 18:24:28
No mate only from the wheels forward are they the same.
Post 738317 by Wobbly Dave on 2014-09-30 16:50:58
I think the panels are different.
Post 738340 by MoleT-5R on 2014-09-30 18:57:09
the panel is totally different as far as I've seen as curls into the sill and under the bottom corner of the door, as the door corner is rounded and not straight like the v70 Image Image
Post 738368 by The Flying Banana on 2014-09-30 20:04:10
so yellow 850 coupe is so no go then
Post 738369 by p fandango on 2014-09-30 20:06:39
[QUOTE=The Flying Banana;738368]so yellow 850 coupe is so no go then[/QUOTE] You wanted to put an 850 front on a c70, different lol
Post 738370 by The Flying Banana on 2014-09-30 20:07:59
[QUOTE=p fandango;738369]You wanted to put an 850 front on a c70, different lol[/QUOTE] yep ...850 coupe ..yellow....tops of bumpers dark anthracite...door rubbing strips anthracite and a set of 18". pegs.....
Post 738371 by p fandango on 2014-09-30 20:09:48
Shame, because I've got a complete 850 front in the garage I'm about to take apart & bin
Post 738374 by claymore on 2014-09-30 20:12:02
[QUOTE=The Flying Banana;738368]so yellow 850 coupe is so no go then[/QUOTE] Wouldn't take much to weld the bottom of the coupe wing onto an 850 wing
Post 738377 by craigoodwood on 2014-09-30 20:40:44
[QUOTE=The Flying Banana;738370]yep ...850 coupe ..yellow....tops of bumpers dark anthracite...door rubbing strips anthracite and a set of 18". pegs.....[/QUOTE] do it :)
