Post 743197 by MoleT-5R on 2014-10-18 10:10:35
Heard some talk about strut top mounts/spring seats recently. I agree that genuine top mounts are probably best, but heard xc90 as an upgrade from the spring seats, but are they any better, does anyone have any real info on them being better ? As I'm just about to change the Guls suspension (not because it needs it, its just I have a nice set of Koni's on the shelf here (Thanks Neal)) and was going to change the mounts whilst I'm at it.
Post 743227 by Volvostorm on 2014-10-18 11:30:34
I'm pretty certain the only ones you can get from Volvo are the XC90 ones now
I have them on mine, can't tell you what difference they made though!
Post 743237 by M-R-P on 2014-10-18 12:04:29
Gotta do mine soon. Interesting to see if there's any difference with the XC mounts.
Post 743242 by Sweep on 2014-10-18 12:35:00
Mine need doing too, must be the time of year :wink:
Post 743243 by M-R-P on 2014-10-18 12:37:57
[QUOTE=Sweep;743242]Mine need doing too, must be the time of year :wink:[/QUOTE]
Tbh, mine needed doing 2 MOTs ago, it's just not got any worse and I can't be arsed with stripping the struts down again lol.
Post 743244 by MoleT-5R on 2014-10-18 12:45:29
are there any heavy duty or uprated ones available ??
Post 743245 by M-R-P on 2014-10-18 12:48:24
Mayle might do HD ones. Bilstein do some but I've read they're not as good. I imagine IPD have had a crack at it too.
Post 743246 by Ettienne on 2014-10-18 12:57:46
Xc90, top mounts springs, top bearing mounts and rear subframe brackets are all upgrades.
Post 743248 by Volvostorm on 2014-10-18 13:57:41
I've heard that the IPD HD ones are just XC ones anyway, dunno if it is true though.
Post 743657 by partsforvolvos.com on 2014-10-20 15:40:18
ipd ones are not the same as xc90 , there are a couple of places you can see its reinforced.
there is only 1 type from Volvo, I haven't heard anything about them all being from an xc90 .
meyle ones are not hd for this part.
my preference on these is :
ipd heavy duty
genuine Volvo
meyle
others .
the rubber seat is a part I have had poor versions in the past so I am very picky with them.
the metal plate with bearing, get from us defo - ours are half the price of Volvo .
Post 743718 by classicswede on 2014-10-20 20:40:21
A lot of the aftermarket ones are rubbish and do not last. Not tried the IPD ones so no idea how good they are. Gen Volvo are good but life is limited. I have considered making something I've not managed to come up with a working design yet
Post 743955 by AshDVS on 2014-10-22 10:41:22
[QUOTE=Pault5estate;743227]I'm pretty certain the only ones you can get from Volvo are the XC90 ones now
I have them on mine, can't tell you what difference they made though![/QUOTE]
This is correct.
The XC90 spring seat supersedes the previous part numbers.
It's a heavier duty spring seat - you wont experience a handling improvement but it will have a longer service life.
Strut mounts are fine in INA or Genuine Volvo and the spring seats are fine in Boge or Genuine Volvo too.
Avoid the unbranded ones or the 'Pro Parts' or 'Scantech' options and you'll be fine.
Post 744004 by AcidicDavey on 2014-10-22 14:22:29
[QUOTE=AshDVS;743955]Strut mounts are fine in INA or Genuine Volvo and the spring seats are fine in Boge or Genuine Volvo too.
Avoid the unbranded ones or the 'Pro Parts' or 'Scantech' options and you'll be fine.[/QUOTE]
You got any links where to buy from in the UK? All I can find are Febi and others PPS etc but not Sachs/Boge.
Post 744006 by MoleT-5R on 2014-10-22 14:28:05
[QUOTE=AcidicDavey;744004]You got any links where to buy from in the UK? All I can find are Febi and others PPS etc but not Sachs/Boge.[/QUOTE]
A link would be handy as I'm just about to change my shocks and springs and I'm hoping to fit some top mounts that are going to give a nice long service life.
Post 744009 by AcidicDavey on 2014-10-22 14:35:24
I've just rang FRF and with 15% discount the rubber Spring seats are £65 something a pair and the mounting plate (the bit with the 3 studs coming out) are £180 something the pair!!!
Post 744010 by ExternalError on 2014-10-22 14:45:25
[QUOTE=AcidicDavey;744009]I've just rang FRF and with 15% discount the rubber Spring seats are £65 something a pair and the mounting plate (the bit with the 3 studs coming out) are £180 something the pair!!![/QUOTE]
Yep thats correct its why i changed my coilover to bc coilovers as my previous set was popping 3 strutmounts a year at £250 a time
Post 744011 by AcidicDavey on 2014-10-22 14:50:31
[QUOTE=ExternalError;744010]Yep thats correct its why i changed my coilover to bc coilovers as my previous set was popping 3 strutmounts a year at £250 a time[/QUOTE]
Post 744377 by AshDVS on 2014-10-24 01:38:20
No I dont I'm afraid.
We offer them here and source via one of the wholesaler/distributors that we use.
Post 744449 by classicswede on 2014-10-24 20:25:50
Febi are part of sachs/boge so they are probably the same part??
Post 744452 by merc85 on 2014-10-24 21:01:58
[QUOTE=classicswede;744449]Febi are part of sachs/boge so they are probably the same part??[/QUOTE]
Really?? i believe that tobe incorrect, They are apart of the Bilstein Group see there group companies >> http://www.febi.com/febicouk/company/partner-websites.html
Thats not taken anything away from them, There are a very good Oe manufacture and equally as good as Sachs/Boge which are a ZF company, in which as also recently aquired TRW (Lucas) as it used to be. :)
http://www.zf.com/corporate/en/products/product_brands/product_brands.html
