Recirc valve vacuum hose
Post 743252 by Sweep on 2014-10-18 15:50:57
Just fitted my blanking plate (what a £££££££ job), and now I'm wondering what to do with the vacuum hose that used to be on the valve itself? Can I use where it goes to the inlet for my boost gauge? Ben.
Post 743253 by oblark on 2014-10-18 15:54:13
You run the pipe to a dump valve unless you want to f££k your turbo up.
Post 743267 by Sweep on 2014-10-18 17:13:42
[QUOTE=oblark;743253]You run the pipe to a dump valve unless you want to f££k your turbo up.[/QUOTE] I'm aware of the potential risks of not running any form of recirc/dump valve, however the 15g simply doesn't make enough boost for compressor stall to be enough of an issue. Besides, if anything does occur, it'll give me the perfect excuse to go down the bigger turbo route :wink:
Post 743268 by Saaamon on 2014-10-18 17:23:22
Block/seal the hole up.
Post 743270 by Sweep on 2014-10-18 17:32:10
[QUOTE=Saaamon;743268]Block/seal the hole up.[/QUOTE] Can the port on the inlet not be used for a boost gauge?
Post 743271 by oblark on 2014-10-18 17:33:39
[QUOTE=Sweep;743270]Can the port on the inlet not be used for a boost gauge?[/QUOTE] yes :)
Post 743273 by Sweep on 2014-10-18 17:43:15
[QUOTE=oblark;743271]yes :)[/QUOTE] Marvelous! Another job on the list to do.
