P0013 fault code
Post 745881 by Volvosean on 2014-11-01 13:21:17
Hello I had my car pluged in today and came back with a fault which the code was p0013 b camshaft position actuator circuit open bank 1. Anyone else had this problem and what was broken? Any help apreciated thanks
Post 745883 by M-R-P on 2014-11-01 13:26:30
Could be the vvt solenoid. What year/engine is the car?
Post 746169 by abdul on 2014-11-02 21:56:32
Had the same code on my 1999 v70 r awd changed the vvt solehnoid then cleared the codes car seems fine now
Post 746190 by Volvosean on 2014-11-03 09:23:39
Car is a 99 engine is the 2.3 Will get a vvt and try thanks
Post 746193 by jamesy12345 on 2014-11-03 10:20:46
if the car has no accelerator cable i.e. is an ME7 car then the exhaust side has VVT (rear cam - the one nearest windscreen)
