Finally passed.
Post 749346 by stribo on 2014-11-24 17:45:12
At the 4th time of asking the V70R has passed it's MOT, the main problem was the handbrake performance, even after fitting new shoes, and adjusting it up as much as I thought was possible it wouldn't go through, so I left it with the garage to do, and they did it, although apparently it was a 2 man job. New problem is the n/s CV joint is knocking badly on full right hand lock, so it's going to need changing sooner rather than later, my question is, is it the same as other P1 cars, or R specific?
Post 749348 by Hound on 2014-11-24 17:54:47
Glad it made it through in the end!
Post 749349 by Tomcat on 2014-11-24 18:00:01
Glad you got it through bud,no idea on the drive shaft I'm afraid.
Post 749358 by Ettienne on 2014-11-24 18:14:02
Same iirc seen a few r and non r, is yours awd? Different shaft if it is.
Post 749359 by stribo on 2014-11-24 18:15:46
[QUOTE=Tomcat;749349]Glad you got it through bud,no idea on the drive shaft I'm afraid.[/QUOTE]
No worries mate, hopefully got 2 complete driveshafts coming from an R reg V70R that's being broken.
Post 749360 by stribo on 2014-11-24 18:16:17
[QUOTE=Ettienne;749358]Same iirc seen a few r and non r, is yours awd? Different shaft if it is.[/QUOTE]
Yes, AWD.
Post 749361 by Ettienne on 2014-11-24 18:16:25
If your using a secondhand shaft, auto shafts are thinner.
Nothing wrong with secondhand shafts, just re pack with cv grease and new boot.
Post 749362 by Ettienne on 2014-11-24 18:16:56
Auto or manual
Post 749364 by Ettienne on 2014-11-24 18:19:06
You should have asked, if can almost see one from here.
Post 749365 by Ettienne on 2014-11-24 18:19:37
That's near side as it's short james
Post 749367 by Jamest5r on 2014-11-24 18:23:28
[QUOTE=Ettienne;749365]That's near side as it's short james[/QUOTE]
Yep I'm.well aware of.that, what I can't do is.read the original post properly :)
Post 749368 by Ettienne on 2014-11-24 18:26:20
[QUOTE=Jamest5r;749367]Yep I'm.well aware of.that, what I can't do is.read the original post properly :)[/QUOTE]
Don't worry about it i can't even be bothered to check the spelling on the iPad half the time.
Post 749370 by stribo on 2014-11-24 18:30:00
[QUOTE=Ettienne;749362]Auto or manual[/QUOTE]
Auto
Jim is that good that he knew I'd cocked up, it is the n/s one that's gone, I put o/s by mistake, unfortunately still won't fit.
Post 749372 by Jamest5r on 2014-11-24 18:33:46
[QUOTE=stribo;749369]Unfortunately noy Rob, that's for an ME7 car, ours has the proper engine management. ;)[/QUOTE]
So.do my car's :)
Post 749374 by Jamest5r on 2014-11-24 18:34:21
[QUOTE=stribo;749370]Auto
Jim is that good that he knew I'd cocked up, it is the n/s one that's gone, I put o/s by mistake, unfortunately still won't fit.[/QUOTE]
Pmsl :)
Post 749379 by stribo on 2014-11-24 18:51:57
[QUOTE=Jamest5r;749372]So.do my car's :)[/QUOTE]
Shows how well I read posts, I just saw an olive 850 in the sig pick, and thought you were Rob. :lol:
Post 749380 by jamesy12345 on 2014-11-24 18:52:56
[QUOTE=stribo;749346]At the 4th time of asking the V70R has passed it's MOT, the main problem was the handbrake performance, even after fitting new shoes, and adjusting it up as much as I thought was possible it wouldn't go through, so I left it with the garage to do, and they did it, although apparently it was a 2 man job. New problem is the n/s CV joint is knocking badly on full right hand lock, so it's going to need changing sooner rather than later, my question is, is it the same as other P1 cars, or R specific?[/QUOTE]
:thewave:
good news, everyone
No doubt I will go through the same....in May!!
Post 749383 by Ettienne on 2014-11-24 18:56:03
[QUOTE=stribo;749369]Unfortunately not Jim, that's for an ME7 car, ours has the proper engine management. ;)[/QUOTE]
Are they a different number of teeth on the hub end?
Post 749395 by V70 Graham on 2014-11-24 19:24:11
Well done on the pass mate
C**k
Post 749407 by AcidicDavey on 2014-11-24 19:46:20
[QUOTE=Ettienne;749383]Are they a different number of teeth on the hub end?[/QUOTE]
Yeah they, 26 or 36 splines I believe. Plus I think the ME7s are secured to the hub by a bolt were as the earlier ones a nut.
I'd like to think that the n/s driveshaft would be the same for AWDs or FWDs, just the o/s one would be different?
Post 749409 by stribo on 2014-11-24 19:51:16
[QUOTE=AcidicDavey;749407]Yeah they, 26 or 36 splines I believe. Plus I think the ME7s are secured to the hub by a bolt were as the earlier ones a nut.
I'd like to think that the n/s driveshaft would be the same for AWDs or FWDs, just the o/s one would be different?[/QUOTE]
Why would the o/s be different if the n/s are the same?
Post 749412 by AcidicDavey on 2014-11-24 19:57:46
[QUOTE=stribo;749409]Why would the o/s be different if the n/s are the same?[/QUOTE]
Because of the transfer box. Obviously the o/s one comes out of the transfer box so would be shorter than a FWD one.
I honestly couldn't tell you for definite, just a thought is all.
Post 749413 by Ettienne on 2014-11-24 20:00:25
[QUOTE=AcidicDavey;749412]Because of the transfer box. Obviously the o/s one comes out of the transfer box so would be shorter than a FWD one.
I honestly couldn't tell you for definite, just a thought is all.[/QUOTE]
No same length as fwd just thinner to fit through angle gear.
Post 749414 by Ettienne on 2014-11-24 20:01:09
That's weird as I use 850 shafts with m66 boxes
Post 749416 by oblark on 2014-11-24 20:14:29
Here you are girls here is the difference between AWD and NON AWD drive shafts.
NON AWD drive shaft
[ATTACH=CONFIG]27534[/ATTACH]
AWD drive shaft
[ATTACH=CONFIG]27535[/ATTACH]
As you can see you can`t use a NON AWD drive shaft in a AWD.
Post 749418 by Ettienne on 2014-11-24 20:22:04
[QUOTE=oblark;749416]Here you are girls here is the difference between AWD and NON AWD drive shafts.
NON AWD drive shaft
AWD drive shaft
As you can see you can`t use a NON AWD drive shaft in a AWD.[/QUOTE]
Exactly what I was saying, can't think where I've seen those before.
Post 749419 by stribo on 2014-11-24 20:26:42
I was just wondering, anyway hopefully the one's I've asked about will be in good condition, and cheap. ;)
Post 749421 by Ettienne on 2014-11-24 20:32:17
You should have asked I have a set or two in the work shop.
Post 749422 by stribo on 2014-11-24 20:37:04
I haven't committed to buying them yet, so give me a price, then I have options. ;)
Post 749427 by Ettienne on 2014-11-24 20:56:26
£50 pair, then you can rebuild them before going back on.
Post 749437 by stribo on 2014-11-24 21:26:56
[QUOTE=Ettienne;749427]£50 pair, then you can rebuild them before going back on.[/QUOTE]
TBH mate I don't want a pair to rebuild, I already have a pair on the car I can rebuild, I need a pair good to go.
Post 749446 by Ettienne on 2014-11-24 22:14:56
They are good to go, but I'll check in the morning. Maybe I'm just fastidious, I'd replace the boots and re grease before putting on.
They are actually from a low ish miles car (relatively low)
