V70R, ABS Ring/s
Post 749688 by Craigy t5 on 2014-11-26 22:23:49
Hi, How are the abs ring/s attached to the drive-shaft,,,? and how do they come off? Cheers, Craig.
Post 749706 by LeeT5 on 2014-11-27 04:03:01
They are simply heated until cherry red then slid over the shaft. Then when they cool they literally grip on tight as! To remove, simply break off the old one and heat up (with a blow torch or Oxy/acet - but be careful) then slip over. Before you remove the old one, make sure you mark up where it sits. Once it's slipped on you can tap it around a little while it's still very hot.
Post 749736 by Wobbly Dave on 2014-11-27 11:49:42
new ones are available here.. http://www.reluctorrings.com/ and more specifically here... http://www.reluctorrings.com/cars/volvo
