P1 Front Camber & RC Adjust?
Post 750138 by Henk on 2014-11-30 16:27:06
Apologies if this sounds stupid, but can you adjust the camber on the front of a P1 V70? Didn't notice slotted holes on the bottom of the strut. Had my wheel off to try and diagnose the knocking noise, and noticed i've got illegal wear on the inside 1/4 of the tyre. Looks like I've got too much negative camber (although it doesn't look like it?) Also slightly off topic, has anyone ever fitted roll centre adjusters on these? Spacer between the upright and the bearing to make the lower wishbone more horizontal (which raises the roll centre reducing body roll as it's closer to the centre of mass. Also reduces track change with suspension travel. Yes suspension dynamics is my 'thing' to a point) While i was under there I noticed they're in a hell of an upward angle (-40 springs, 205/45/r17, so nothing very different)
Post 750140 by deathrider311271 on 2014-11-30 16:29:47
you can buy camber bolts to alter it upto 4 degrees
Post 750559 by Henk on 2014-12-03 19:55:19
found them, now having done a bit of reading, what else could be causing wear on the inner edge? I think I have the pressure a bit high, but the camber isn't noticable, haven't measured it yet mind Image Still quite curious about roll centre correction considering these cars are occasionally driven quite hard Will have a look into it myself
Post 750568 by stribo on 2014-12-03 20:13:28
First thing to do would be to get the tracking checked.
Post 750580 by Jamest5r on 2014-12-03 20:34:42
I get that on.the rear of mine but the fronts are ok but it's very lowered with stiff suspension
Post 751050 by Henk on 2014-12-08 09:35:39
Tracking I can have done, as I need to get my second pair of wheels painted and have winter tyres put on! I'm wondering if it could be my wishbone bushes being shagged, 171k and i assume they're still standard. But they can't really be changed can they? Diesel wishbones are different to 'normal' cars' wishbones correct? Thinking a bit of TLC wouldn't be a bad idea when fitting my ARBs (when they come)
Post 751322 by Henk on 2014-12-10 13:02:12
bump, guys?
Post 751344 by RollingThunder on 2014-12-10 17:18:02
+1 for tracking here. Get all four wheels done with one of the new laser gizmos. I had mine done last night - the fronts were out as I've just had a new rack put on, and the rears were out quite a bit too.
Post 751349 by martin_r_smith on 2014-12-10 17:50:13
[QUOTE=RollingThunder;751344]+1 for tracking here. Get all four wheels done with one of the new laser gizmos. I had mine done last night - the fronts were out as I've just had a new rack put on, and the rears were out quite a bit too.[/QUOTE] You say the rears out, how did they adjust them to make them right??
Post 751386 by RollingThunder on 2014-12-11 08:50:29
Hi Martin, on my AWD there is adjustment as below - Image Not sure if its the same on the FWD? HTH
Post 751394 by stribo on 2014-12-11 10:10:57
[QUOTE=RollingThunder;751386]Hi Martin, on my AWD there is adjustment as below - Image Not sure if its the same on the FWD? HTH[/QUOTE] No, FWD has totally different rear suspension.
Post 751408 by RollingThunder on 2014-12-11 13:14:14
Thats what I thought Stribo. Wasn't sure if the adjustment point was the same though, but thinking about it now, it will be completely different as its multilink etc.
Post 751410 by stribo on 2014-12-11 13:22:08
I'm not even sure if the FWD has adjustable tracking at the rear.
Post 751413 by 960kg on 2014-12-11 14:04:54
Tracking can be done on rear FWD but not camber on rear.....
Post 751426 by Jamest5r on 2014-12-11 16:23:14
Well that's easier said than done, you ever tried to undo those bolts....... . Image Burnt my last one out cos it wouldn't undo lol Might be possible now :) Image
