brembos under titans
Post 750155 by dazbooker on 2014-11-30 20:40:51
new it could be done heres a photo Image 320mm discs and brembo Renault calipers
Post 750156 by oblark on 2014-11-30 20:43:43
What size discs are you using ?
Post 750157 by dazbooker on 2014-11-30 20:51:22
[QUOTE=oblark;750156]What size discs are you using ?[/QUOTE] it says mate 320mm
Post 750158 by Ettienne on 2014-11-30 20:53:31
[QUOTE=dazbooker;750155]new it could be done heres a photo Image 320mm discs and brembo Renault calipers[/QUOTE] I know did it last year, I know (pretty sure) exactly how you did it as well.
Post 750159 by dazbooker on 2014-11-30 20:54:15
here a video https://www.youtube.com/watch?v=eqwx_rEeMT8&feature=youtu.be this is just a trial fit now I know they fit ill get the brackets made and shallower bolts to hold the caliper to the bracket as I had to shamfer the heads to clear the wheels and the longer brake hoses
Post 750160 by dazbooker on 2014-11-30 20:58:55
[QUOTE=Ettienne;750158]I know did it last year, I know (pretty sure) exactly how you did it as well.[/QUOTE] no wheel spacers and no grinding of caliper or wheel
Post 750161 by Ettienne on 2014-11-30 21:00:07
I really do know!!
Post 750162 by deathrider311271 on 2014-11-30 21:02:16
one question how are you now going to balance your wheels without wrecking the rims?
Post 750163 by Ettienne on 2014-11-30 21:02:18
Done it donkeys ago, made several kits up. Like I said I know how you did it as it's similar to my way, there nothing secret about it. You moved the disc inboard, I,e renault disc same stud pattern.
Post 750164 by dazbooker on 2014-11-30 21:03:48
thought it would have been but people were saying that they would only go under 18s so I had to have a go and see took a while to fabricate the bracket what hubs did you use on yours as there not Volvos are they as Volvos have bolts
Post 750165 by Ettienne on 2014-11-30 21:05:32
[QUOTE=deathrider311271;750162]one question how are you now going to balance your wheels without wrecking the rims?[/QUOTE] Mine had enough clearance as I used different discs (not renault), but there are other issues moving the disc inwards, but nothing major. I use the ash dvs brackets on 320mm with focus st calipers, it's just cheaper.
Post 750166 by dazbooker on 2014-11-30 21:06:30
[QUOTE=Ettienne;750163]Done it donkeys ago, made several kits up. Like I said I know how you did it as it's similar to my way, there nothing secret about it. You moved the disc inboard, I,e renault disc same stud pattern.[/QUOTE] didn't use Renault disc mate the discs are 320mm Volvo the wheel bolted on ok a bit close minds so may add 2mm spacer just to be sure
Post 750167 by Ettienne on 2014-11-30 21:07:04
[QUOTE=dazbooker;750164]thought it would have been but people were saying that they would only go under 18s so I had to have a go and see took a while to fabricate the bracket what hubs did you use on yours as there not Volvos are they as Volvos have bolts[/QUOTE] It is a Volvo hub, iirc I was at friends engineers and only had a bit of stud to hand and some nuts.
Post 750169 by dazbooker on 2014-11-30 21:07:56
the wheels are balanced bud it clears the weights too
Post 750170 by Ettienne on 2014-11-30 21:08:44
No my mistake that's the prototype 740 brembo, I'll dig out the t5r one.
Post 750171 by dazbooker on 2014-11-30 21:09:18
[QUOTE=Ettienne;750167]It is a Volvo hub, iirc I was at friends engineers and only had a bit of stud to hand and some nuts.[/QUOTE] are you running those now then
Post 750172 by Ettienne on 2014-11-30 21:10:33
This Is the finished 740 ones 2 years ago
Post 750173 by t5 pete on 2014-11-30 21:10:37
Looks good I personaly would do sone trimming if it is possible on the calliper as it looks very tight also as Simon has mentioned if your wheels need stick on weights in the centre along the spokes theres going to be no chance on fitting them, its the same with the v50 320mm brake kit i believe unsing the v50 calipers Heres how the clearance looks on the original Volvo 320 kit looks Image Image Image
Post 750174 by dazbooker on 2014-11-30 21:14:29
[QUOTE=t5 pete;750173]Looks good I personal would do so trimming if it is possible on the calliper and it looks very tight also as Simon has mentioned if your wheels need stick on weight in the centre along the pokes there going to be no chance on fitting them, its the same with the v50 320mm brake kit i believe Heres how the clearance looks on the original Volvo 320 kit looks Image Image Image[/QUOTE] I thought the balance weights would be a problem but luckly not don't know wether to paint them though quite like them in silver
Post 750175 by Ettienne on 2014-11-30 21:14:35
[QUOTE=dazbooker;750171]are you running those now then[/QUOTE] I have made 7-10 sets up, all sorts, but drive a v70r as a daily with p2 330mm 4 pots on each corner so don't bother, but I'll fit a set on the gul front and rear, xc90 rears or porsche 4 pots. Just Made some up for my 940, which fit under steelies with no spacer 17s
Post 750176 by dazbooker on 2014-11-30 21:15:52
[QUOTE=Ettienne;750172]This Is the finished 740 ones 2 years ago[/QUOTE] looks great buddy did you do this on the t5 too
Post 750178 by Ettienne on 2014-11-30 21:24:29
Yep, I think there is some pics floating about but I was the first to use the renault brembo calipers. Ive done 2 types of brembo 4 pot on 350mm and various brembos on: Xc90 336mm Xc90 316s S60 320mm S60r 330s Rears 308s and 330s on brembo 4 pots or single pots including awd v70r p1s Quite literally most things, I don't use the 350s with 4 pots, as I keep cars looking standard, although one set does fit under Volans.
Post 750179 by dazbooker on 2014-11-30 21:27:51
[QUOTE=Ettienne;750178]Yep, I think there is some pics floating about but I was the first to use the renault brembo calipers. Ive done 2 types of brembo 4 pot on 350mm and various brembos on: Xc90 336mm Xc90 316s S60 320mm S60r 330s Rears 308s and 330s on brembo 4 pots or single pots including awd v70r p1s Quite literally most things, I don't use the 350s with 4 pots, as I keep cars looking standard, although one set does fit under Volans.[/QUOTE] whats the best four pots to use on the rears
Post 750181 by Ettienne on 2014-11-30 21:38:34
Porsche 4 pots fit well, actually Charlie's 854 t5r (my old car) has 4 pot fronts and rears on it (I forgot about that).
Post 750182 by oblark on 2014-11-30 21:42:49
[QUOTE=Ettienne;750181]Porsche 4 pots fit well, actually Charlie's 854 t5r (my old car) has 4 pot fronts and rears on it (I forgot about that).[/QUOTE] Fronts Image Rears Image
Post 750186 by dazbooker on 2014-11-30 21:44:59
[QUOTE=oblark;750182]Fronts Image Rears Image[/QUOTE] looks cool are you running the pegs on that car
Post 750189 by Ettienne on 2014-11-30 21:58:04
17 pegs.
Post 750190 by dazbooker on 2014-11-30 22:07:44
[QUOTE=Ettienne;750189]17 pegs.[/QUOTE] which car were they on
Post 750224 by Ettienne on 2014-12-01 12:29:34
[QUOTE=dazbooker;750166]didn't use Renault disc mate the discs are 320mm Volvo the wheel bolted on ok a bit close minds so may add 2mm spacer just to be sure[/QUOTE] It's not feesible to use the 320mm, you have to pull the caliper in from the edge, plus clearance issues are just too close (I find) to be safe. You should try a 316mm if you going to do it allows more clearance. But you've just said you may use a spacer, I'll dig out pics of the clearance with my set up I've got 10-12mm from the spokes or castings on the wheel, so more than enough to be a safe margin. The 350s I have made, (under Volans, no spacers etc) have similar clearance to your set up and I'm on the fence about using them due to clearance. Although I'll revisit that in the summer.
Post 751411 by Avinitlarge on 2014-12-11 13:36:53
Ive got Renault Brembo's and 320mm P2 discs. My wheels are 17" comets, everything is ready to fit, no idea how it will go though, Never did a dummy fit on the car.
Post 751417 by Ettienne on 2014-12-11 14:28:50
[QUOTE=Avinitlarge;751411]Ive got Renault Brembo's and 320mm P2 discs. My wheels are 17" comets, everything is ready to fit, no idea how it will go though, Never did a dummy fit on the car.[/QUOTE] I doubt it will fit as I tried 7 and 7.5j comets before, but as always it's close just depending on if you want a safety margin / spacer etc. From what I remember they actually physically touch
Post 751418 by Ettienne on 2014-12-11 14:30:58
I've just made some 320mm p2 large piston calipers fit under my 17 steelies on the 940 and accidentally made an adaptor bracket to allow running p2 brakes on it inc s60r 330s Worth noting its the same mounting pattern just different offset to the 850s, I'll offer it up when I get a minute
Post 751427 by t5 pete on 2014-12-11 16:27:25
Opps wrong thread
Post 751990 by Ettienne on 2014-12-17 17:30:41
Had an hour or so today, so hopefully fixed the clearance issue for 350mm brembo 4 pots under Volans (no spacer). Someone has my mock up hub so can't check until I buy a spare, but problem should be solved.
Post 753687 by AshDVS on 2014-12-29 05:35:30
Renault Brembos under Titans look great! I'd be conscious of clearance with wheel weights though, personally, I wouldn't take to a caliper with a grinder or a file. If you need to do that, you're using the wrong caliper for the application. Pete's oem 320mm brakes are really neat too and are one of those unusual factory options that were fairly uncommon - probably less common even than the AP 5200 calipers and rotors that could have been opted for when new. The S40/V50T5 AWD & LS-LV Ford Focus ST conversion is a nice and simple conversion if, like me, you just really want to stay with a factory 17" wheel - if you can or want to go bigger, the options open up significantly. It's not the conversion you'd choose if your car is destined solely for track day duties - for that you'd use a 'real' 4 or 6 piston caliper, rather than a sliding type. It is however, a massive improvement over the 280mm and 302mm factory options and, with good pads and rotors, will be happy enough to do some track work. Here's a pic of the caliper and rotor mounted - Image Clearance with a 17" 'Propus C' wheel - Image Clearance with a 17" 'Titan' wheel - Image Stick-on weights located on the inside of the spokes will not clear, however they would if they were stuck on in the 'open area' between the spokes (though this would be fairly ugly) and an even better idea would be clamp-on/punch-on weights on the rear rim lip. For reference, here's how they fill out a 19" rim in comparison to the factory volvo options. 280mm rotors with standard calipers. Aftermarket 19" wheel. C70 - Image 302mm rotors with standard calipers. Aftermarket 19" wheel. C70 - Image 320mm rotors with calipers sourced from LS-LV Ford Focus XR5 (ST to those of you in the UK). Aftermarket 19" wheel. C70 - Image
Post 753715 by Ettienne on 2014-12-29 08:43:24
I just made up a bracket to use existing 850 caliper on 316s. Fits under titans etc will post up pics once I've fiddled a bit more.
Post 753717 by claymore on 2014-12-29 08:50:26
[QUOTE=AshDVS;753687] Image[/QUOTE] Them wheels would look mint on my car with the 380mm rotors.
Post 753750 by Ettienne on 2014-12-29 16:08:22
[QUOTE=claymore;753717]Them wheels would look mint on my car with the 380mm rotors.[/QUOTE] I doubt they'd fit, they are big 380mm!
Post 753768 by claymore on 2014-12-29 17:18:03
[QUOTE=Ettienne;753750]I doubt they'd fit, they are big 380mm![/QUOTE] They fit under my Jag 19" wheels.
Post 753770 by Ettienne on 2014-12-29 17:25:09
[QUOTE=claymore;753768]They fit under my Jag 19" wheels.[/QUOTE] Show off:haha:
Post 754449 by AshDVS on 2015-01-04 10:28:39
[QUOTE=claymore;753717]Them wheels would look mint on my car with the 380mm rotors.[/QUOTE] I'm not sure that 380mm rotors would fit under there actually. They might, but it'd be very tight! [QUOTE=Ettienne;753750]I doubt they'd fit, they are big 380mm![/QUOTE] Maybe depending on the caliper being used? [QUOTE=claymore;753768]They fit under my Jag 19" wheels.[/QUOTE] The fact that they're off a jag is reason enough not to use them. ;)
Post 754451 by claymore on 2015-01-04 10:36:36
[QUOTE=AshDVS;754449] The fact that they're off a jag is reason enough not to use them. ;)[/QUOTE] I don't agree. 380mm under 19" wheel: Image
Post 754452 by AshDVS on 2015-01-04 10:40:13
Argggh! My eyes!
Post 754453 by claymore on 2015-01-04 10:56:17
[QUOTE=AshDVS;754452]Argggh! My eyes![/QUOTE] Give me yours then :)
Post 754586 by AshDVS on 2015-01-05 00:45:08
[QUOTE=claymore;754453]Give me yours then :)[/QUOTE] Realistically, if you'd told me they were from something other than a jag, I'd probably like them. ;) Wheel style is speculative anyway, in your case it's function over form. They need to fit over your brakes, plain and simple. These fit, therefore they're ideal!
Post 759129 by Avinitlarge on 2015-02-09 14:40:28
[QUOTE=Ettienne;751417]I doubt it will fit as I tried 7 and 7.5j comets before, but as always it's close just depending on if you want a safety margin / spacer etc. From what I remember they actually physically touch[/QUOTE] Ive just tried them with my comets, No go, Need about 10mm spacers
Post 759134 by Ettienne on 2015-02-09 15:03:08
[QUOTE=Avinitlarge;759129]Ive just tried them with my comets, No go, Need about 10mm spacers[/QUOTE] Done it a few times, I've sorted mine now to fit under titans on 312mm no spacers, so that's good enough for me. But I don't make any brakes as I'm done with fixing them just fiddling with my 940
Post 765406 by Avinitlarge on 2015-03-26 14:53:19
Bought a set of Pegs, they fit now :D Image
Post 765414 by Ettienne on 2015-03-26 17:03:43
Titans have always been awkward for space
Post 765416 by Avinitlarge on 2015-03-26 17:25:37
Thats why I went straight for Pegs. Just wanted something that would go straight on and leave a decent gap. Any suggestions for rear upgrades? I was looking at Merc ML twinpot brembos.
Post 765492 by Ettienne on 2015-03-26 22:28:44
Xc90 rear discs 308mm and vented, use xc90 calipers, make bracket I have one here rob made a while back after I started using the 308s with Porsche calipers (wanted something cheap). or Porsche 911 / boxster calipers work well, used these for a while, more braking force than 302mm fronts, I made these up a few years back. Or s60r rears on 330s I have these as well with brackets, just not sure what I. Fitting to the olive yet. I have 4 or 5 different front set ups to use ill most likely pop on the 316mm discs with standard front calipers (on bracket) to get the olive through mot, then decide from there.
