Post 752612 by Ettienne on 2014-12-22 13:31:26
Made up some brackets today to fit standard calipers to 316mm discs.
Went perfectly and fits under titans and Volans perfectly.
Also 940s under 16 steelies.
Can't be arsed to grab a pic as feel like death today.
Should be quite effective with ds2500 pads, new fluid and braided hoses.
Post 752613 by claymore on 2014-12-22 13:38:17
I need pictures as I'm going to make some brackets for standard calipers onto 336mm disks :)
Post 752615 by Nealevo on 2014-12-22 13:57:56
Steve your request 355mm has been delivered
Post 752618 by Ettienne on 2014-12-22 14:12:01
Cool buddy that's awesome.
They are for the p2, yummy.
Post 752619 by Ettienne on 2014-12-22 14:15:35
[QUOTE=claymore;752613]I need pictures as I'm going to make some brackets for standard calipers onto 336mm disks :)[/QUOTE]
Won't go as the disc won't physically fit in the hanger, there is not enough width iirc, I've done it before.
Plus there is the issue of pad coverage, the xc90 etc pads won't fit in the hanger on the standard hanger.
It is pushing the limits with the 26mm wide 316mm discs, but they mount up basically perfect.
Post 752621 by Ettienne on 2014-12-22 14:17:07
[QUOTE=Nealevo;752615]Steve your request 355mm has been delivered[/QUOTE]
Are you coming to the southern?
