Post 752656 by Pliskin on 2014-12-22 18:30:44
Hi all,
I have got a 1999 V70 140 petrol v70 with 110K on it which has just started to introduce what smells like recirculated un-burnt fuel into the cab when the blower is on.
Are there any usual suspects and what is the best way to track it down?
Many thanks and a Very Merry Xmas to all.
Post 752657 by T5frankie on 2014-12-22 18:55:51
probably your breather pipe leaking or come off?
Post 752670 by JamesT5 on 2014-12-22 19:52:14
[QUOTE=Pliskin;752656]Hi all,
Many thanks and a Very Merry Xmas to all.[/QUOTE]
Check for fuel leaks in the engine bay, around the injectors and any fuel lines.
Post 752687 by Harvey on 2014-12-22 21:52:05
[QUOTE=T5frankie;752657]probably your breather pipe leaking or come off?[/QUOTE]
Like he says the pipe next to the engine oil filler cap does split/ crack,if you get the engine nice and hot then have a good look around with it running good chance you will see a bit of smoke.:santa:
Post 753500 by Pliskin on 2014-12-28 10:31:48
I can't seem to find anything obvious that is causing the smell in the cab, but to add insult to poisoning the car is now jerking forward on tickover. It's like riding a camel, not that I've done it. This is accompanied by the ETS light coming on, which is a bit disappointing as I have just had it uprated to the contactless version by Volvo Diagnostics in London. If I stop and turn it off and on the light usually clears but reappears, with the jerkiness after a few miles, which isn't the best.
I am fast approaching the point where she might have to go as I have recently been spending good money after bad. If anyone knows of a good V70 D5 around the 2007 era could you please let me know.
Post 753504 by stribo on 2014-12-28 10:55:08
If the throttle body's been done, it may be the throttle pedal, or even the wiring.
Post 753528 by 960kg on 2014-12-28 12:52:09
[QUOTE=Pliskin;753500]I can't seem to find anything obvious that is causing the smell in the cab, but to add insult to poisoning the car is now jerking forward on tickover. It's like riding a camel, not that I've done it. This is accompanied by the ETS light coming on, which is a bit disappointing as I have just had it uprated to the contactless version by Volvo Diagnostics in London. If I stop and turn it off and on the light usually clears but reappears, with the jerkiness after a few miles, which isn't the best.
I am fast approaching the point where she might have to go as I have recently been spending good money after bad. If anyone knows of a good V70 D5 around the 2007 era could you please let me know.[/QUOTE]
If you reverse the car when cold if it`s worse and your doing 12 mpg it will probably be the front O2 sensor gone......i see your at the right mileage for these problems!
Had this with my 960 at 103,000
