3" throttle body ?
Post 753613 by richyt5 on 2014-12-28 20:08:36
Ive noticed alot of people put these on the 850s as im trying to find out as many mods as i can im just wondering what car you get them off, what do i need to change, and is there any gains etc?
Post 753630 by nottsgreent5 on 2014-12-28 21:03:24
I dont have one fitted to mine but from memory they are fitted to the 960 3 ltr sure you have to change some of the pipe work to 3" to make it work
Post 753659 by AndysR on 2014-12-28 22:38:42
960 3 litre is where they're found. Also think the 2.5 20v 850 has a larger throttle body and can be modified to accept a larger throttle butterfly but not 100% on that. As far as experiences go the 3.0 throttle body with the 2.5 20v inlet manifold makes a big difference to the throttle response of the car but I had to have my map tweaked after that was fitted as it suffered with very minor det with the existing custom map I had done to the car. I wouldn't go back to the standard items though as drivability its transformed the car.
Post 753662 by Ettienne on 2014-12-28 22:45:00
I've got one for the 940, which I'm bound to crash, looking forward to fitting it. Tim Williams does a modified version which may not cause the map problem, but guessing you were running a custom map andy
Post 753672 by AndysR on 2014-12-28 23:01:05
[QUOTE=Ettienne;753662]I've got one for the 940, which I'm bound to crash, looking forward to fitting it. Tim Williams does a modified version which may not cause the map problem, but guessing you were running a custom map andy[/QUOTE] Yes was running a custom map pre the throttle body replacement, it was done at the same time as the engine build and I had the map checked and adjusted as necessary, and have had it rechecked again since to make sure all is well :)
