1999 V70 T5 mystery!
Post 757476 by dionbullock on 2015-01-26 09:39:27
Hi guys, Im posting this on behalf of my father who has a 1999 V70 T5. He bought the car brand new in 98-99 and the car has been faultless until he decided to lpg it about 5 years ago, running problems etc. It turned out that the guys who fitted the lpg had fitted the lpg ecu in the same box as the cars ecu, and by doing this somehow dislodged the cars ecu resulting in it overheating and frying the connecting pins. they took out the lpg in the end. A replacement ecu was ordered and the car has been fine ever since, 3-4 years driving. until now! He's complaining that sometimes when you drive the car, stop somewhere, jump back in and want to go again, the car wont start, ignition on, all dash lights go on and off as they should, it turns over but wont fire. Sometimes no lights come on the dash, then he leaves the car for 10-20 mins, and poof! it works fine again! its truly a mystery. We've had a auto electrician look at her, he's had the car for the past month and has gone through everything he can think of. Fuel pumps, fuses, bad earths, crank sensors, maf's, and a load of other checks i cant remember. No faults/codes come up on his computer. Can anyone on here suggest anything else that maybe the auto leccy guy missed? What are the chances of the replacement ECU being faulty after 3-4 years of faultless driving? As you can imagine, the car holds a great sentimental value to him and the last thing he wants to do is have to sell it as a spares/repairs. But we are running out of options/ideas on what is wrong and how to fix it :(
Post 757477 by jamesy12345 on 2015-01-26 10:03:14
Seems unlikely to be the ECU....sounds like a hot start problem. It would be worth getting the codes read - could be something like coil or coolant temp sensor edit sorry just noticed you mentioned codes read already...what software did they use - VOL-FCR is good, will work if the car is M4.4
Post 757478 by dionbullock on 2015-01-26 10:20:47
Hi - forgot to mention that sometimes the car wont start even when its cold. Not sure what code reader he used tbh? But the car is deffo an ME7
Post 757479 by jamesy12345 on 2015-01-26 10:30:58
[QUOTE=dionbullock;757478]Hi - forgot to mention that sometimes the car wont start even when its cold. Not sure what code reader he used tbh? But the car is deffo an ME7[/QUOTE] my advice is a bit useless then))
Post 757480 by dionbullock on 2015-01-26 10:34:50
Any advice is appreciated :)
Post 757487 by abdul on 2015-01-26 11:12:17
I had a problem with my car it would not start start left it for a while or half a day and then it started . Then when parked after a while driving would not start again turned out to be fuel pump relay
Post 757506 by jdavis on 2015-01-26 12:27:39
Starter Solenoid Can you hear the Starter motor clicking? try hitting it with a hammer or similiar if you can get to it. It will be ME7 being a '99. did Vida show anything?
Post 757514 by dionbullock on 2015-01-26 13:58:38
Ill ask the auto leccy if he's investigated these items. The starter works fine im sure, its not the tell tale click of a busted starter
Post 757515 by Dangerous Dave on 2015-01-26 14:04:05
Does the engine just turn over without firing or does it fire for a brief second then cut out?
Post 757518 by dionbullock on 2015-01-26 14:24:48
[QUOTE=Dangerous Dave;757515]Does the engine just turn over without firing or does it fire for a brief second then cut out?[/QUOTE] Sometimes it will turn over without firing! other times it will fire up straight away and runs perfectly with no coughs,smoke or splutters. Other times you can put the key in the ignition, turn the key and nothing will happen, as if the battery was completely dead or not there (its a brand new battery before someone suggests a new battery :) ) Although this happens very rarely.
Post 757521 by kmb on 2015-01-26 14:32:35
Could it be related to the actual ignition barrel/switch?
Post 757524 by dionbullock on 2015-01-26 14:37:39
[QUOTE=kmb;757521]Could it be related to the actual ignition barrel/switch?[/QUOTE] Never thought of that tbh, i'll put it to the auto electrician to test it if possible
Post 757528 by The Flying Banana on 2015-01-26 15:41:06
Crankshaft Position Sensor .... had exactly same issue on two other cars..replaced them and it never happened again
Post 757537 by dionbullock on 2015-01-26 16:43:04
crankshaft sensor was one of the first things he checked and turned out to be fine
Post 757548 by 960kg on 2015-01-26 18:17:09
It probably is the bottom half of the ignition switch...was £64 for my `97 V70 T5....common fault.
Post 757569 by jdavis on 2015-01-26 20:18:12
Yeah my p1 v70 had a dodgy ignition switch just used to spin sometimes.
Post 757649 by dionbullock on 2015-01-27 15:09:29
The auto leccy thinks it might be down to either the fuel pump or relay. Looking to order one of each to see if it solves the problem. Volvo wanted £284 + vat for the pump and £33.20 + vat for the relay.... which i thought was a tad expensive. Euro car parts has bosch pumps for about £130 - but which one is the one i need?? http://www.eurocarparts.com/fuel-pump
