Post 758414 by mike 850 on 2015-02-03 10:37:52
Hi all, have got a 4.4 ecu on my 94 850 t5 and want to fit a 0BD port, I understand its 3 wires i need to connect, anyone know which ones? Thanks
Yes just about to do mine ill post info later
Cool, think I found something but ill wait for you to confirm Cheers
Iirc pin b 36 on ecu then need a live and a earth I'm out at min so will post with pics when I get back in
Thats what i found too, pics would be great Cheers mate
[QUOTE=t5 pete;758435]Iirc pin b 36 on ecu then need a live and a earth I'm out at min so will post with pics when I get back in[/QUOTE] are you going to fit the obd socket internally under the coin holder, like in the later T-5R's or planning somewhere else for it...????
[QUOTE=MoleT-5R;758442]are you going to fit the obd socket internally under the coin holder, like in the later T-5R's or planning somewhere else for it...????[/QUOTE] only need it for data for mapping so will run it so where under dash where it can be pulled out when needed
Im gonna leave mine in the engine bay for now, gonna get one of those bluetooth jobbies
