2003 s60 alarm HELP
Post 758637 by luked5 on 2015-02-04 22:17:17
Hi everyone. I jave just joined the forum as i have just bought an s60 d5. I bought it about 2 weeks ago and it has been sat on my drove since. I drove it today for about 15 miles then parked it back up and went out for food. I got home and heard a faint beeping sound coming for the frobt wong and when i got in it was saying alarm triggard check car. I lock the car amd then get the dull neeping again and hazards flashing. I have locked it now by hand via thw drivers door lock. I know it has proably been asked 1 million and 1 time but is that the battery or the alarm itself? I did have to charge the battery they other day as it was flat. Dont know if they are connected? Thanks Luke
Post 758641 by Harvey on 2015-02-04 23:13:46
The battery in the siren do fail ,I just changed mine siren as the alarm fault code poped up. You could have a faulty door - boot - bonnet switch ? just use the car for a bit that might recharge the siren battery if you are lucky. If you get this message pop up you will need a new siren unit. Image
Post 758656 by silverhorse on 2015-02-05 03:23:43
I had this problem for a while. When you lock the car, do the flashers flash once? If not, the alarm has not set. Mine turned out to be the bonnet not fully clicking shut. I pressed the bonnet down at intervals across the leading edge and there was a small click and the flashers flashed. Sorted. Saved me a few quid! Worth a try
Post 760875 by LeeT5 on 2015-02-25 16:21:21
[QUOTE=luked5;758637]Hi everyone. I jave just joined the forum as i have just bought an s60 d5. I bought it about 2 weeks ago and it has been sat on my drove since. I drove it today for about 15 miles then parked it back up and went out for food. I got home and heard a faint beeping sound coming for the frobt wong and when i got in it was saying alarm triggard check car. I lock the car amd then get the dull neeping again and hazards flashing. I have locked it now by hand via thw drivers door lock. I know it has proably been asked 1 million and 1 time but is that the battery or the alarm itself? I did have to charge the battery they other day as it was flat. Dont know if they are connected? Thanks Luke[/QUOTE] As Harvey says. Also, check for fault code UEM 0004. If you have it then you'll need a new siren.
