Juddering from front passenger wheel.
Post 759122 by petrolh34d on 2015-02-09 13:58:22
I've got a juddering under braking and at high speed from the front passenger wheel. There's no rumbling noise, so I'm assuming that this is a warped disc as opposed to a bearing? Also have a clunking noise coming from this corner when hitting bumps and whilst maneuvering the car at low speeds. Is this bushings? Car is 1998 V70 2.5 TDi
Post 759128 by t5 pete on 2015-02-09 14:35:47
Juddering could be warped or incorrectly fitting discs I. E not cleaning the surface of the hub or could be worn wish bone bushes. The knocking will most Likely me either drop link or suspension top mount
Post 759138 by petrolh34d on 2015-02-09 15:17:31
Thanks. I'll strip her down and get a look at the disc, but I'm pretty sure it's going to be slightly warped. Judging by the clunking sound, I'd say you're right about the top mount. Any suggestions where I can get a replacement?
Post 759144 by t5 pete on 2015-02-09 15:40:26
Ebay pfv euro car parts volvo there widely available
Post 760088 by petrolh34d on 2015-02-18 11:45:49
Changed disc and top mount, and all good now. Thanks!
