Post 759301 by Sweep on 2015-02-10 07:52:59
Over the past week or so I've noticed the car hunting at idle as soon as it's fired up, only lasts for 10 seconds or so and then disappears. Any ideas chaps? Seems to be after the car has been sat in the cold at night as i don't recall it doing it after work.
Post 759378 by Biff on 2015-02-10 22:09:59
Clean the idle control valve with some carb cleaner & blow it out with an airline if you can.
Post 759382 by stribo on 2015-02-10 22:36:52
What car is it, could be the ambient temperature sensor.
Post 759388 by Saaamon on 2015-02-10 23:37:53
Clean tb whilst down there.
Post 759484 by Sweep on 2015-02-11 16:59:22
Cheers chaps will give that a go this weekend, it's an 850 T5.
Post 763777 by Sweep on 2015-03-14 17:21:02
Tried the above and it's made it worse! Dab the throttle on idle and it'll perk up and sit at about 1200 for 3 seconds and then drop back to 950.
Post 763779 by matt_t5r on 2015-03-14 17:32:05
Check hoae under / behind inlet manifold.kind of under top rad hose. Pcv pipe i belive. Check rubber elbow.
