v70r maf
Post 760891 by PHIL V70R on 2015-02-25 18:48:55
evening chaps long time not chat lol..right here we go...had a bad misfire on the R so replaced the plugs and leads..cap and arm...and still have same problem..so now about to change the maf..plugged in the reader and no codes..the code on the maf ends in 107...a mate has one that ends with 108...whats the difference...car is a 98 v70r auto fwd...cheers lads..:funkybana:worship:
Post 760902 by MoleT-5R on 2015-02-25 19:26:44
Hi, phil sorry I don't know the answer, but I was talking with someone the other day about you and your internal auto-dipping mirror and was wondering if you had got it fitted and working in you v70r ??
Post 760904 by PHIL V70R on 2015-02-25 19:37:41
lol...yes and no mate needs a bit of fine tuneing sir
Post 760961 by MoleT-5R on 2015-02-26 00:56:18
[QUOTE=PHIL V70R;760904]lol...yes and no mate needs a bit of fine tuneing sir[/QUOTE] on going project then, what works and what problems have you run into, if you don't mind me asking on here ??
Post 760963 by MoleT-5R on 2015-02-26 01:22:03
Just had a dig about and it looks as if the only difference is the 108 is about a £45 quid cheaper bosch unit and fitted to the same v70's and other models of the time. here's a link to a maf specialist http://www.maf-shop.com/index.php?currency=GBP&language=en&cat=c11_VOLVO.html&cPath=11 hope that helps you
Post 760979 by merc85 on 2015-02-26 09:44:11
I may be wrong but i think the 0280217108 has 4 lugs on the plug, and the 0280217107 has 6
Post 760981 by MoleT-5R on 2015-02-26 10:37:40
[QUOTE=merc85;760979]I may be wrong but i think the 0280217108 has 4 lugs on the plug, and the 0280217107 has 6[/QUOTE] not sure about six lugs, but the plug on the 208 is the later oval type not square like the early 850 ones, I should have spotted that earlier but it was getting late. but why that makes it that much cheaper I don't know
Post 760990 by merc85 on 2015-02-26 12:19:30
i thought that til i saw this http://www.ebay.de/itm/like/201181855747?clk_rvr_id=787204298150&item=201181855747&lgeo=1&vectorid=229487&rmvSB=true
Post 760999 by MoleT-5R on 2015-02-26 13:07:22
I think they have use the wrong image there, if you pull the others up the oval plug is a 108's and the squares are 107's, Phil will be to tell us for sure when he looks at his mates one
Post 761055 by LeeT5 on 2015-02-26 20:26:49
MAF won't cause a misfire, just crap idle or cutting out. I'd be leaning more towards the ignition coil. The modules are known for getting hot and overheating, failing that the windings in the coil break up.
Post 761060 by MoleT-5R on 2015-02-26 20:51:38
crank sensor ????
Post 761073 by LeeT5 on 2015-02-26 21:55:46
[QUOTE=MoleT-5R;761060]crank sensor ????[/QUOTE] Or that!
Post 761093 by Kingsford G on 2015-02-26 23:28:29
My V70R had a problem where it drove fine fo over 400 miles and the next day didn`t wanna start and eventually started after a few attempts and was running like crap and no power so plugged in showed up the MAF and replaced with a used one from 2.5t I had at the time.I can`t remember the part number though
