Post 762275 by Ettienne on 2015-03-05 18:30:01
With the klracing group buy does anyone know the maximum width for the 850 retaining the air con? Is it 40, 50 or 60mm
Whatever the do88 one is. I can measure it if needs be.
[QUOTE=stribo;762276]Whatever the do88 one is. I can measure it if needs be.[/QUOTE] I did look on pfv but didn't give a size I think they 30mm standard, but yes please measure.
Mine is 50mm, but I did need to trim the front crossmember a bit to get the aircon rad to fit:
Mines 75mm and nothing else is going to fit lol.
My do88 intercooler is 50mm, I think Nealevo is the one to talk to :)
[QUOTE=oblark;762333]My do88 intercooler is 50mm, I think Nealevo is the one to talk to :)[/QUOTE] Why, did I not give the right information?
Mine it 50mm too, and I retained my air con rad with the slightest of fettling, but it was close
Mine is also a 50mm one that I fitted but I didn't want to either push the rad back or notch the front brace so didn't use the air con rad but left pipe work there if I decide to install it. Personally got for the 40mm one
poor pics but.........
50mm inc AC:
60mm without:
in both cases, you can see the panel holding the relays has moved back, but I think if you want to use a 60mm,you will need some brackets to move the rad rearwards, if you want to keep the AC
