S60 & V70 RTI removal from dashboard satellite navigation unit.
Post 762321 by Harvey on 2015-03-05 20:42:18
Very easy to remove the unit from the dashboard. First thing is to remove the mesh trim,all you need is a bone trim tool something wide and flat / thin just poke it in the gap between the two. As it's held in place by 4 spring clips. Image Image Then the unit is just screwed to the dash by 4 torx screws.( not the 4 that hold the speaker in place it's ok to leave them in place ) Image Then the unit will just pull out,but if it's hard to come out it will be due to something I would call a big blob of blue tack volvo style. Image You can just see a blue mark at the bottom of the screen box that's the blue tack type stuff just to stop it rattling in the dashboard.
