Post 763980 by jamesy12345 on 2015-03-15 21:05:05
[QUOTE=Ettienne;763977]...
http://www.ebay.co.uk/itm/UNIVERSAL-6-SPEED-FING-FAST-ROUND-BALL-SCREW-ON-M8-M10-M12-KIT-SHIFT-KNOB-BLACK-/351189908221?pt=Vintage_Car_Truck_Parts_Accessories&hash=item51c48cbafd
....[/QUOTE]
Like it...
[ATTACH=CONFIG]28384[/ATTACH]
Steve do you have a thread on installing the 6-speed box? I was thinking about this for my S70
Post 763983 by Ettienne on 2015-03-15 21:30:22
Nothing difficult about doing it, it's the same as 5sp if your using a Volvo s60 / v70 box, need to move rear mount over with spacer is all really.
If not then a bit more fabrication is needed this is the route I / Oblark have gone 4 times now, works awesomely and the ratios are very fast / close on the st box, it incorporates a quick shift as well and it's like a rifle bolt , unfortunately the parts we used aren't available.
Post 763985 by oblark on 2015-03-15 21:45:33
[QUOTE=Ettienne;763983]Nothing difficult about doing it, it's the same as 5sp if your using a Volvo s60 / v70 box, need to move rear mount over with spacer is all really.
If not then a bit more fabrication is needed this is the route I / Oblark have gone 4 times now, works awesomely and [COLOR="#FF0000"]the ratios are very fast / close on the st box,[/COLOR] it incorporates a quick shift as well and it's like a rifle bolt , unfortunately the parts we used aren't available.[/QUOTE]
The S60 diesel box that will be going in my 850 have batter ratios than the ST box.
Post 763993 by Ettienne on 2015-03-15 21:56:48
[QUOTE=oblark;763985]The S60 diesel box that will be going in my 850 have batter ratios than the ST box.[/QUOTE]
Definately better if your running more power, otherwise you'd spin up a lot, but the St box does help make a standard ish car faster with the close ratios.
More power you can run the diesel box
Post 763995 by jamesy12345 on 2015-03-15 22:08:00
It's Yosser's old car I'm referring to...which is running more power than standard...just thinking out loud!
Back on topic:
[ATTACH=CONFIG]28385[/ATTACH]
QOTSA 'Go with the flow' gear stick
