Post 764123 by jdavis on 2015-03-16 20:20:38
This is something i intend to do on my T5 auto at some point. Got a couple of questions though:
- Would any 850 manual box work or does it have to be a t5? Seen a couple of cheap TDi's that are manuals.
- I'm hoping to exhange car-car so should have most bits available but is there anything i should be buying new, clutch, etc...
- anything to look out for?
- Any tips?
Post 764125 by AcidicDavey on 2015-03-16 20:32:44
I'll be getting my car converted at some point.
Any petrol manual should do, can't comment on the use of a diesel but I'd guess not.
A few things to think of is if your car has cruise control and if so whether you want to retain it.
If so on manual cars there is a switch on the clutch pedal to cut it out when the drive is disengaged.
With regards to buying new bits I'll be buying new linkage cables rather than the old ones off the donor.
Also might be worth changing the rear main oil seal?
This guide might be worth a read?
Post 764127 by Ettienne on 2015-03-16 20:37:31
Any 850 box except the diesel box iirc as it's a vw engine.
Can use later boxes as well I do focus st etc
M56h is what you want for cheapness
Post 764132 by Jamest5r on 2015-03-16 21:18:22
Everything you need here :)
http://www.volvoforums.org.uk/showthread.php?t=71697
Edit should of read above posts lol :)
Post 764143 by Nealevo on 2015-03-16 22:03:49
Get a complete car to make it much easier.
Post 764161 by MoleT-5R on 2015-03-17 07:44:02
should be able to start the manual conversion of our v70r awd in the next few weeks, can wait to get that back on the road and with 6 speed awd it will be great
Post 764180 by jdavis on 2015-03-17 10:51:59
Excellent guys, thanks for the pointers. I have heard of the six speed St box being used, is it a simple case of just using that box or is there far more involved? I will hopefully be getting a donor 850 at some point.
Post 764248 by AcidicDavey on 2015-03-17 21:31:14
[QUOTE=jdavis;764180]Excellent guys, thanks for the pointers. I have heard of the six speed St box being used, is it a simple case of just using that box or is there far more involved? I will hopefully be getting a donor 850 at some point.[/QUOTE]
The gear shift set up is a bit different on the Ford box I'm told and needs a bit of fabrication.
Best Steve (Ettienne) fills you in as he's done the conversion a few times now apparently.
Post 764254 by hemihusky on 2015-03-17 22:03:19
depending how things go and whats involved id love a 6 speed box for my 850. i do a fair few motorway miles n having another gear to slot it into n lower the revs that little bit more would be great! sits at about 3K when crusing not great for the drone or the fuel eco!
Post 764257 by claymore on 2015-03-17 22:18:11
[QUOTE=hemihusky;764254]depending how things go and whats involved id love a 6 speed box for my 850. i do a fair few motorway miles n having another gear to slot it into n lower the revs that little bit more would be great! sits at about 3K when crusing not great for the drone or the fuel eco![/QUOTE]
I'm not sure the final drive ratio is any different to the 5 speed, but I could be talking ££££££ :)
Post 764260 by hemihusky on 2015-03-17 22:33:52
ohhhh so itd be more a acceleration advantage?
Post 764261 by Ettienne on 2015-03-17 22:38:36
All depends on the box all approx but 6sp top speeds iirc 167, 185, 215, 225, 235, 250
Post 764262 by Ettienne on 2015-03-17 22:39:49
My 6sp auto does 100mph in third actually over 100
Post 764265 by oblark on 2015-03-17 22:42:22
On the motorway my car with its 6 speed boz does 80 mph @ 3000 rpm.
To fit the M66 box in a 850 you will need to fabricate a new rear mount, a new spider for the gear cables and a new arm for the selector on the box. All of these where designed and fabricated by Steve and myself.
Post 764266 by oblark on 2015-03-17 22:44:56
Also when i get around to fitting it the diesel M66 box will do 2k at 80 mph
Post 764268 by Ettienne on 2015-03-17 23:03:18
[QUOTE=oblark;764265]On the motorway my car with its 6 speed boz does 80 mph @ 3000 rpm.
To fit the M66 box in a 850 you will need to fabricate a new rear mount, a new spider for the gear cables and a new arm for the selector on the box. All of these where designed and fabricated by Steve and myself.[/QUOTE]
You designed I helped fettle and had fabricated.
Post 764269 by jamesy12345 on 2015-03-17 23:12:25
[QUOTE=claymore;764257]I'm not sure the final drive ratio is any different to the 5 speed, but I could be talking ££££££ :)[/QUOTE]
depends on the box/final drive you have
http://volvospeed.com/vs_forum/topic/146868-m56h-m59-differences/
Seems pointless for me to change my M59 to an M66 or an ST box as top gear ratio in all of them is 0.7:1 and final drive 4:1..? Or is there more than one M66. Might accelerate better I guess!
Post 764271 by Ettienne on 2015-03-18 05:45:16
I listed above there's (iirc) 6, but the focus box gives nice acceleration to a sub 300bhp car with the ratios, makes them really move
Post 764274 by jamesy12345 on 2015-03-18 06:57:30
[QUOTE=Ettienne;764271]I listed above there's (iirc) 6, but the focus box gives nice acceleration to a sub 300bhp car with the ratios, makes them really move[/QUOTE]
think I'll stick with my 5-speed then
Post 764275 by Ettienne on 2015-03-18 07:05:32
[QUOTE=jamesy12345;764274]think I'll stick with my 5-speed then[/QUOTE]
I prefer the 6 sp, I have an m59 with shafts sitting on the workshop floor and a focus box, it's the focus box that's being fitted.
Post 764279 by jamesy12345 on 2015-03-18 07:15:41
[QUOTE=Ettienne;764275]I prefer the 6 sp, I have an m59 with shafts sitting on the workshop floor and a focus box, it's the focus box that's being fitted.[/QUOTE]
I remember Yosser said the M59 ratios weren't very good for Knockhill track...should be OK for Croft!!....and the 4-speed auto wasn't good on Harewood hillclimb either...!
edit
pm'd about the spare M59 :D
Post 764320 by Ettienne on 2015-03-18 15:05:24
[QUOTE=jamesy12345;764279]I remember Yosser said the M59 ratios weren't very good for Knockhill track...should be OK for Croft!!....and the 4-speed auto wasn't good on Harewood hillclimb either...!
edit
pm'd about the spare M59 :D[/QUOTE]
It's sitting in my aladins cave at the moment, with the rest of the stuff I don't part with.
Post 764322 by jamesy12345 on 2015-03-18 15:18:38
[QUOTE=Ettienne;764320]It's sitting in my aladins cave at the moment, with the rest of the stuff I don't part with.[/QUOTE]
OK no worries)
