Fitting XC90 Calipers & 336mm Discs to S60 / V70
Post 764284 by stephenevans99 on 2015-03-18 07:34:30
Tools out time…..
First job was to remove the old 305mm discs, pads and calipers along with the old limiter arms. Armed with a new 14mm drill bit and drill, I carefully drilled out the aluminium hubs in order for them to take the new 14mm bolts, this only took a couple of minutes and was surprisingly easy:
Did a trial fit of the XC90 carriers to determine the length of bolts needed, obviously too short and the carriers wouldn’t be secure, too long and the bolts would strike the disc…discovered 55mm bolts were perfect:
Confirming that 55mm bolts were now the ones to use, I removed the carrier to mount the new 336mm disc and then refitted the limiter arm and carrier:
Copper greased the new brake pads and fitted the inner pad with the rear section of the caliper after using silicon grease to lube the slider pins, fitted the flexi brake pipe and mounted the caliper:
Installed the outer pad and bolted up the rest of the caliper and carefully fitted the pad retaining clip, trying not to scratch the new paintjob lol:
Next was the straight forward job of bleeding the calipers, starting with the nearside and moving onto the offside, bled without any issues using ATE SuperBlue DOT4 fluid.
Post 764292 by merc85 on 2015-03-18 07:46:10
STUNNING mate! :)
Post 764293 by claymore on 2015-03-18 07:53:40
Great write up mate
Post 764296 by Harvey on 2015-03-18 08:53:02
Nice job there,but where's the nebs gone ?.
Post 764299 by stephenevans99 on 2015-03-18 09:07:01
Nebs are in the garage and will be swapped over next week lol. I just wanted to run the new brakes with the 17" Comets to make sure there weren't any issues or surprises.
Post 764300 by Rich v70 on 2015-03-18 09:53:14
One of the best upgrade to do, would you do the rears to?
Post 764301 by martybelfastt5 on 2015-03-18 09:54:11
thats a great write up and they look superb!
Post 764303 by t5 pete on 2015-03-18 10:21:57
Great write up
Post 764305 by stribo on 2015-03-18 10:30:14
Great write up,and good work mate.
Post 764306 by stephenevans99 on 2015-03-18 10:32:03
[QUOTE=Rich v70;764300]One of the best upgrade to do, would you do the rears to?[/QUOTE]
Not sure exactly what's involved with the rears - caliper and discs wise
Post 764309 by expolicev70t5 on 2015-03-18 10:58:43
Looks good, nice write up.
Post 764310 by WOODY T5 on 2015-03-18 11:41:04
Great thread this mate look brilliant too get the nebs back on :)
Post 764311 by kmb on 2015-03-18 12:18:36
Looking excellent, very nice work and thread!
Post 764313 by AshDVS on 2015-03-18 12:46:43
Excellent, super neat conversion.
Great work!
Post 764314 by Biff on 2015-03-18 12:58:09
Great write up Steve & interested to know they fit behind comets. Maybe a good upgrade when I have more funds as I love a bit of braking power.
Wonder what the weight difference is with a view to unsprung weight?
Post 764317 by MoleT-5R on 2015-03-18 14:24:24
Excellent write up and a great modification
Post 764318 by Ettienne on 2015-03-18 15:02:25
[QUOTE=Biff;764314]Great write up Steve & interested to know they fit behind comets. Maybe a good upgrade when I have more funds as I love a bit of braking power.
Wonder what the weight difference is with a view to unsprung weight?[/QUOTE]
Won't fit a p1, but a good budget brake upgrade on a p2, good write up.
Now for the rears!!
Post 764319 by stephenevans99 on 2015-03-18 15:04:52
[QUOTE=Biff;764314]Wonder what the weight difference is with a view to unsprung weight?[/QUOTE]
They certainly weigh a fair bit....the calipers are probably the same weight as the discs themselves - 11.4kg each
Post 764321 by stephenevans99 on 2015-03-18 15:16:44
[QUOTE=Ettienne;764318]
Now for the rears!![/QUOTE]
What do I need for bigger stoppers on the rear? I'm interested :)
Post 764323 by Ettienne on 2015-03-18 15:39:10
To complete the braking package, they are a bit light weight iirc mine are 15 or 16kg monsters 350 x 32 (or 34) I can't remember.
I'll most likely put 330 4 pot rears on mine but, I have 308mm Porsche 4 pots or 308mm xc90 rears (both vented) on custom hangers.
Post 764325 by Ettienne on 2015-03-18 16:14:09
I think you may be able to bolt straight up xc90 vented 308mm, however I've only dealt with awd p2s and it's a straight fit so should be ok, £50 per side calipers and cost of discs, so cheap and a fair bit bigger.
If the s60r rear calipers are a straight fit on the fwd so should the xc90s
Post 764326 by Ettienne on 2015-03-18 16:15:56
Btw xc90 rears are very good
Post 764327 by jamesy12345 on 2015-03-18 16:17:52
[QUOTE=Ettienne;764323]To complete the braking package, they are a bit light weight iirc mine are 15 or 16kg monsters 350 x 32 (or 34) I can't remember.
I'll most likely put 330 4 pot rears on mine but, I have 308mm Porsche 4 pots or 308mm xc90 rears (both vented) on custom hangers.[/QUOTE]
seems like overkill to me)) have you lads considered getting lighter cars?
only kidding very impressed with the photos in this thread
Post 764328 by Ettienne on 2015-03-18 16:19:32
That's the thing p2 are heavy especially r's
Post 764332 by stephenevans99 on 2015-03-18 16:26:15
Bigger brakes is easier than a gym membership lol
Post 764333 by Ettienne on 2015-03-18 16:38:16
No need to drill rears either.
Post 764336 by stephenevans99 on 2015-03-18 17:16:16
Started looking already lol....I take it the S60 handbrake shoes can remain in situ, it's just the disc and pads along with the caliper that's changed?
Post 764350 by Ettienne on 2015-03-18 18:15:41
Yep spot on
Post 764420 by Biff on 2015-03-18 22:55:11
[QUOTE=Ettienne;764318]Won't fit a p1, but a good budget brake upgrade on a p2, good write up.
I thought Nealevo had them before his fancy ones?
Post 764422 by hemihusky on 2015-03-18 22:59:47
[QUOTE=Biff;764420]I thought Nealevo had them before his fancy ones?[/QUOTE]
i think his were those proper rare volvo OEM 320mm upgrade that are like audi calipers? T5 pete has um now i think?
Post 764430 by Ettienne on 2015-03-19 06:47:55
P2 stuff won't fit a p1 at all I should know, I've made many many brake set ups as I get bored.
You can get a bracket to fit certain p2 stuff, but it's a limited range and not 4 pots or 336s etc.
I run xc90 fronts on my 940.
Post 764432 by stribo on 2015-03-19 07:06:27
[QUOTE=stephenevans99;764321]What do I need for bigger stoppers on the rear? I'm interested :)[/QUOTE]
And as a bonus, you'll get extra R badges on your car. ;)
Post 800829 by Norbertinio on 2016-05-11 15:18:26
Sorry to resurrect this thread but just wondering if someone managed to install xc90 calipers for the rear. Are they a direct bolt-on ?
Post 808838 by silverback02 on 2017-01-17 23:05:26
And I'll resurrect it again.
Could I do this mod on my 2004 C70 2.4T GT.
She already has the 305mm carriers and disk fitted instead of the standard 280mm.
cheers
Post 808842 by stephenevans99 on 2017-01-18 07:33:56
[QUOTE=Norbertinio;800829]Sorry to resurrect this thread but just wondering if someone managed to install xc90 calipers for the rear. Are they a direct bolt-on ?[/QUOTE]
Rear calipers from an XC90 will bolt straight onto the rear of the S60/V70 but they are only slightly bigger than the standard ones already fitted, that said...you would then have vented discs rather than solid. I wouldn't replace the original rear discs and pads for the sake of it & expect a huge gain in braking performance; but if they need replacing anywhoo it maybe worth considering.
[QUOTE=silverback02;808838]And I'll resurrect it again.
cheers[/QUOTE]
I believe not.....The C70 will have 302mm carriers and discs - unfortunately the XC90 setup won't fit.
Post 813117 by rjocosta on 2017-07-25 18:54:54
I recently bought some 336mm discs and calipers of a XC90 T6 to apply on my S60 T5, but I had a question. Will I be able to mount this set in 17 "Tethys?
Post 813120 by stephenevans99 on 2017-07-25 20:05:11
I have seen this setup behind a set of 17" Tethys......not sure whether they were using spacers tbh.
Post 813128 by M-R-P on 2017-07-26 00:29:18
[QUOTE=rjocosta;813117]I recently bought some 336mm discs and calipers of a XC90 T6 to apply on my S60 T5, but I had a question. Will I be able to mount this set in 17 "Tethys?[/QUOTE]
Should fit, I know for a fact they go under 17" amaltheas, comets and pegs. There's about 15mm gap between the caliper and wheel weights with amaltheas.
Post 813137 by stephenevans99 on 2017-07-26 11:13:56
Currently in the process of refurbing a set of XC90 Rear calipers for the S60. A small upgrade from the current solid 288mm discs of the S60 to the vented 308mm discs from the XC90. Probably offer very little noticeable improvement but my rear discs need replacing so thought why not :B_thumb:
Post 813140 by MoleT-5R on 2017-07-26 12:03:32
[QUOTE=stephenevans99;813137]Currently in the process of refurbing a set of XC90 Rear calipers for the S60. A small upgrade from the current solid 288mm discs of the S60 to the vented 308mm discs from the XC90. Probably offer very little noticeable improvement but my rear discs need replacing so thought why not :B_thumb:
[/QUOTE]
oooh.....they'd look nice on my Ocean Race.......nice work Mr Evans...:)
Post 813145 by Ettienne on 2017-07-26 18:49:37
[/QUOTE]
Been using Xc90 rears on p1's a while they work quite well, you should notice it.
Post 813146 by Ettienne on 2017-07-26 18:50:12
336s fit under Tethys without spacers iirc.
Post 814016 by rjocosta on 2017-10-01 19:36:14
I have another question. Which brake lines do you use, stock ones or Xc90?
Post 814093 by M-R-P on 2017-10-04 17:23:16
[QUOTE=rjocosta;814016]I have another question. Which brake lines do you use, stock ones or Xc90?[/QUOTE]
The xc90 calipers' pipe attachment is actually slightly closer to the body than the standard one so your current lines will do fine.
Post 814698 by S.Roberts on 2017-11-14 09:13:48
Anyone know if this would work the same for a S40 II?
Post 815500 by bveenhof on 2018-02-07 18:43:40
I also did this upgrade, front and rear. I was expecting a massive difference, since the rear discs are now larger than the stock 286mm front discs. However, i find it a bit disappointing to be honest. Sure, the pedal responds a bit earlier but it doesn't really feel much different. Or does it take a while before the system really performs to it's full potential? I've driven about 200km / 120miles and went for Zimmermann sport + Ferodo Premier (front) and regular Zimmermann discs + Ferodo Premier (rear).
[ATTACH=CONFIG]31949[/ATTACH]
Post 815508 by don kalmar union on 2018-02-08 09:54:36
To the best of my knowledge the front brake set up of the now discontinued Focus RS with the Volvo 5 pot came straight off the old XC90. The problem might be that the clever front suspension on those RSs might have different spacings, bolt diameters etc. to the old small Volvos that otherwise shared the Focus platform, suspension etc.
Don.
Post 816976 by rjocosta on 2018-08-05 19:09:01
Already made the swap.
Front
[ATTACH=CONFIG]32188[/ATTACH]
[ATTACH=CONFIG]32189[/ATTACH]
[ATTACH=CONFIG]32190[/ATTACH]
Rear
[ATTACH=CONFIG]32191[/ATTACH]
[ATTACH=CONFIG]32192[/ATTACH]
Made a huge difference specially on high speed braking, and it looks soooo much better.
Post 817111 by davebb on 2018-08-16 23:18:49
Hi this is brilliant info,
I did 305mm on my s60 d5 about 3 years ago, would it be safe to fit the xc90 rears on the car with the 305mm on the front, or should I fit the 336 on to the front before the vented xc90 rears,
Thanks Dave
Post 817112 by stephenevans99 on 2018-08-17 07:52:31
I think it would be perfectly safe to fit the rears first. I can't see it upsetting the braking balance of the car that much tbh.
Post 817113 by davebb on 2018-08-17 08:59:00
Hi Stephen
Thanks for that , I did think that as pressure on the back braking is reduced anyway,
also with the front ,I read that there are 2 different sizes of the xc90 front brakes available,
how do I know the callipers are for the 336mm, was there a year car I need to get them from, as I will be looking on ebay,
Thanks Dave
Post 817116 by GMCC on 2018-08-17 19:39:41
I got the t6 2.9 336mm Calipers of a 2004 xc90 also when I fitted the rears I had the rears fitted for a couple of weeks till I got the bigger wheels you notice the increase in braking in the rear but doesn’t affect the balance
Post 817117 by davebb on 2018-08-17 21:27:39
Hi thanks that's good to know,
Thanks Dave
Post 817118 by stephenevans99 on 2018-08-18 08:17:59
I seem to recall that my calipers were from a T6 too....it's been a while lol
Post 817119 by MoleT-5R on 2018-08-18 12:26:34
Just be a little careful with xc90 disc's and calipers, as by local motor factors informed me there 3 different sizes of front disc's listed, when I went for pads recently.
Post 817121 by davebb on 2018-08-18 19:28:06
ok thanks for all of the help, I am still in two minds as I did my 305 fronts about 3 years ago and are still in very good condition, but another 31mm should be a very good up grade,
Thanks Dave
Post 817125 by M-R-P on 2018-08-19 16:19:53
The brake balance is controlled electronically.
It'll cope with different braking performance at one end.
Post 817126 by davebb on 2018-08-19 18:53:03
Hi Martin
Thanks For the info, How does it do it electronically ?, is it done by the ABS Module,
We did meet at devil developments 1.5 years ago, I was the only one with a s60 D5,
Thanks Dave
Post 817148 by M-R-P on 2018-08-24 00:28:32
[QUOTE=davebb;817126]Hi Martin
Thanks Dave[/QUOTE]
I remember - that's when mine made 310bhp. Happy days.
Yeah, providing you have the more advanced dstc safety system, it can monitor and control the brakes on each wheel and cut the throttle if it thinks you're about to do something stupid.
Post 817150 by davebb on 2018-08-24 12:17:20
Hi Martin
my 2002 does not have the more advanced dstc, only has the front wheel stc,
Thanks Dave
Post 817937 by bveenhof on 2019-01-04 14:42:01
This week, i upgraded my suspension to a Bilstein B12 Pro kit. Really good upgrade! But the mechanic said that the brake lines on the front are scraping against the chassis at maximum steering. Has anyone else noticed this and found a solution?
In the picture you can see the metal scrapes pretty clearly.
[ATTACH=CONFIG]32268[/ATTACH]
Post 817938 by davebb on 2019-01-04 15:14:11
[QUOTE=bveenhof;817937]This week, i upgraded my suspension to a Bilstein B12 Pro kit. Really good upgrade! But the mechanic said that the brake lines on the front are scraping against the chassis at maximum steering. Has anyone else noticed this and found a solution?
[ATTACH=CONFIG]32268[/ATTACH][/QUOTE]
Hi Can you give more info on what you think about the B12 kit, Do you think the damping is to hard or just right, is the car roll cut out,
Thanks Dave
Post 817939 by bveenhof on 2019-01-04 15:42:59
[QUOTE=davebb;817938]Hi Can you give more info on what you think about the B12 kit, Do you think the damping is to hard or just right, is the car roll cut out,
Thanks Dave[/QUOTE]
I just picked up the car yesterday, so i can't say too much about it yet. But what i have noticed, is that it gives you a lot more feeling and feedback. You feel much more in contact with the car. The car also has much less body roll and dives less when braking or accelerating. In the corners it just feels better and more sporty, like i'd expect from a car that's advertised by Volvo as a sporty sedan. Obviously you do give up a bit of comfort, but not too much. My wife didn't really notice anything and wondered why i "wasted" all that money :D The only place i really noticed that the damping was harder, was on a cobblestone road. But even then, the comfortability was perfectly acceptable. All in all; i highly recommend it!
Post 817940 by davebb on 2019-01-04 15:55:55
Hi Thanks for the info,
I do have the eibach springs with STD dampers so it would be the same if I got the B8 dampers, I do find the springs very good, but I have been thinking about the dampers,
Dave
Post 817942 by bveenhof on 2019-01-05 20:51:04
I think the Bilstein dampers will be an upgrade! :) Drove some more today and i must say that it's just more fun to drive right now.
As for the brake hoses scraping against the chassis... does anyone know to fix that?
Post 817943 by davebb on 2019-01-05 21:02:37
OK Thanks what hoses are they, braded hoses ?
can you cut some rubber grommets and fit them on and re glue with super glue,
Dave
Post 817946 by woz on 2019-01-06 10:46:28
Yeah i agree , it is standard fitment on many brake lines to have a section of rubber tube over the top near potential chafe points. Inthink my 850 fronts have it. I would make some grommets up out of a section of fuel hose or similar, slit down the side, clip it over the brake line and then attach with cable ties or acrylic sealant. Drawback is it wilmstill chafe so you make want to attach a small bit of shiny stainless to cover up the rubbed patch. Not sure what MoT man will say about rubbing hoses!!! Otherwise you may ned to get longer hoses and route them so they can be clipped back so they dont chafe. Good luck, let us know how it goes.
Post 817951 by jellison on 2019-01-07 14:38:14
Nice job. Lucky to get inside the 17's.
Post 817964 by bveenhof on 2019-01-09 09:34:43
Thanks! Since i wanted new brake lines anyway, i upgrade to steel braided ones. They still have a layer of plastic to cover them though, but an extra layer of rubber might be enough to protect both the chassis and the brake lines. And i don't think it'll be visible, with the massive XC90 callipers in front of them :D
Post 819400 by bveenhof on 2019-12-20 10:48:35
So, a little while later. My S60 went for the yearly checkup and my brake lines where dangerously damaged. Turns out the mechanic who installed the callipers, connected the brake lines to the bleed nipples. Apparently this fits perfectly fine, but on the max steering angle the brake lines get bend too much. I had to get new brake lines and now all is fine :) Definitely something to keep in mind.
Post 820235 by Jays V70 on 2020-08-15 13:06:19
Hi Dudes!
Sorry for the ambush!
I'm just in the process of doing this upgrade to my D5 V70.
Does anyone know whether the 336mm XC90 'upgrade' will fit with 17" Amalthea's? Don't want to go down the realms of having to buy some new rims just yet as just put new rubber on my 17's!
Thanks in advance!
Jay
Post 820240 by Timo. on 2020-08-16 09:56:11
Post 5 suggests yes.... Might depend on what 17 inch wheels you have
Post 820251 by Jays V70 on 2020-08-17 09:49:32
[QUOTE=Timo.;820240]Post 5 suggests yes.... Might depend on what 17 inch wheels you have[/QUOTE]
Hi Timo,
It does seem some 17's fit whilst others need spacers.
I'm just trying to do the homework before putting all the xc90 kit on the car and finding out that i can't use it due to the wheels (Amalthea's) not fitting.
Guess it's going to have to be a case of trial and error!
Post 821087 by Jays V70 on 2021-03-04 11:38:54
So a bit of an update.
17' Amalthea's kinda fit. As in they will physically fit over the rims, however you will need spacers to clear the calipers![ATTACH=CONFIG]32987[/ATTACH][ATTACH=CONFIG]32988[/ATTACH] I'm now running a set of Ford mondeo 18's during the winter with custom spacers to get the right offset until I get enough dosh together to get some 1AV ZX 1's with the right offset... Still work in progress!!!
Post 821723 by rozakiin on 2021-10-18 10:03:37
[QUOTE=Jays V70;821087]So a bit of an update.
17' Amalthea's kinda fit. As in they will physically fit over the rims, however you will need spacers to clear the calipers![ATTACH=CONFIG]32987[/ATTACH][ATTACH=CONFIG]32988[/ATTACH] I'm now running a set of Ford mondeo 18's during the winter with custom spacers to get the right offset until I get enough dosh together to get some 1AV ZX 1's with the right offset... Still work in progress!!![/QUOTE]
Here's how the brakes fit with 17x7.5 Amalthea maybe 3-5mm (half a finger width) at the narrowest point.
[ATTACH=CONFIG]33142[/ATTACH]
[ATTACH=CONFIG]33143[/ATTACH]
Post 821839 by M-R-P on 2021-12-31 23:49:13
I never had any trouble fitting ameltheas over the 336 kit.
Yes, it was tight but, never had any fouling.
