Post 764674 by stribo on 2015-03-21 15:02:41
I'm well aware many of you are of that opinion already, but I now have evidence to back it up. As the weather's improving I thought I'd tackle the C70 again. Last year I changed the exhaust manifold and turbo on it, but when I put it all back together, there was a leak between the head and the exhaust manifold. I was pretty pissed off to say the least, assuming one of the exhaust gaskets had slipped whilst putting it back together, I parked it up for winter, and thought no more about it. So, to today, get it all stripped down, expecting half a gasket to be hanging below the manifold, but no, they're all in place and sealded nicely, it's only when I took them off that I discovered what I'd done.
3 out of the 5 were on upside down, so blocking half of the exhaust port, and leaking from the other half. So due to my lack of attention to detail I've had to spend the morning stripping it all down, hopefully it'll be up and running later this afternoon, and I'll be able to see what difference the 18t, Japanifold, and 3" DP with race cat have made, but at the end of the day, I'm still a dick. :slap:
Post 764675 by jamesy12345 on 2015-03-21 15:06:36
I'm sure people have done worse and admitted less...
Post 764676 by Nealevo on 2015-03-21 15:11:22
Order the complete gasket.in one, makes the job much easier, and yes you are a dick.
Post 764677 by stribo on 2015-03-21 15:16:09
[QUOTE=Nealevo;764676]Order the complete gasket.in one, makes the job much easier, and yes you are a dick.[/QUOTE]
At the time I ordered them I didn't know there was a one piece available, still no guarantee I wouldn't have put it on wrong. :(
Post 764678 by RichT4 on 2015-03-21 15:26:30
Haha, don't worry about it dude. I've just bought wishbone bushes and balljoints ready for change to cure a knocking..... Which turned out to be a loose droplink I failed to check was tight!
Post 764679 by Biff on 2015-03-21 15:42:57
That will make a cracking difference mate!
Yes you are a dick but you were obviously keen to get it back together. ;)
I want a bigger turbo!!!
Post 764680 by V70 Graham on 2015-03-21 15:45:56
Glad you have found the problem, hopefully its all done and running this afternoon.
As regards to your comment.....you know my thoughts !
Post 764683 by FIREBOLT on 2015-03-21 16:02:28
I bought a new auxiliary belt tensioner for my V40, think it was about £80. Anyway I was all set to change it when I picked up the box & it fell out onto the floor :( Needless to say the new tensioner was in considerably poorer condition than the old one I had just removed. I still have a brand new tensioner with a wonky pulley!
Post 764684 by t5 pete on 2015-03-21 16:19:20
It's took you that long to find out your a dick that makes you a double dick but maybe that's something to be proud of lol
Any way as it's not like me to go off topic ill get back onto the subject in hand if may spelling is bad so be it.
Tbh it's a easy thing to do and the one piece one does make it easier hopefully you should see a difference once back together.
And while I'm at it well done every body makes mistakes and it's nice to see some one who can admit it but I still think your a dick.
P.s. I like you really well until I get my intercooler and flange lol flange in one piece
Post 764685 by mitchyboy01 on 2015-03-21 16:46:13
Lol. I'm sure many have made the same mistake. I put one upside down when I fitted my new turbo a couple of weeks ago. Luckily I double checked it all before I refitted everything.
You are lucky none of them broke and went through your exhaust turbine spinning at 100,000rpm!!
Post 764687 by Ettienne on 2015-03-21 16:50:47
Just cut the part no off the one piece gasket to fit it.
Post 764692 by stribo on 2015-03-21 17:17:51
[QUOTE=mitchyboy01;764685]Lol. I'm sure many have made the same mistake. I put one upside down when I fitted my new turbo a couple of weeks ago. Luckily I double checked it all before I refitted everything.
You are lucky none of them broke and went through your exhaust turbine spinning at 100,000rpm!![/QUOTE]
I hardly ran it, when I started it up, and it sounded like a tractor, I just parked it up, and sulked.
Post 764694 by mitchyboy01 on 2015-03-21 17:21:23
Haha. That feeling when you spend hours getting everything bolted together then realise you need to remove it all again.
Post 764698 by MIKESC70T5 on 2015-03-21 18:00:09
I'm surprised you didn't do a James and blame it on the shop that supplied you the gaskets. But yes your still a dick and in my book that's worse than a tosser :dgrin:
Post 764702 by stribo on 2015-03-21 18:51:08
[QUOTE=MIKESC70T5;764698]I'm surprised you didn't do a James and blame it on the shop that supplied you the gaskets. But yes your still a dick and in my book that's worse than a tosser :dgrin:[/QUOTE]
I'm going to sue Volvo, they make it too easy to fit them upside down. ;) Oh, should I bleed the brakes now I've been fiddling with the turbo?
Post 764711 by foammanmark on 2015-03-21 19:36:41
Bloody annoying but at least you've sussed it. Hope that you're sorted now.
Post 764713 by stribo on 2015-03-21 19:42:22
[QUOTE=Jamest5r;764706]Erm......told you so :)[/QUOTE]
Erm, no you didn't :P
[QUOTE=foammanmark;764711]Bloody annoying but at least you've sussed it. Hope that you're sorted now.[/QUOTE]
Yeah it's all back together, taken it for a gentle run, hopefully be building up to a full power run during the evenings this week.
Post 764715 by foammanmark on 2015-03-21 19:45:47
Pleased to hear it. Took our C70 to Costco today, and filled the boot and back seat up with shopping. Plan to do more than 1,100 miles in her which I did in the last year, this coming year cos I really like to drive her.
Post 764716 by Wobbly Dave on 2015-03-21 19:54:03
Finally I don't feel quite so alone. You could do worse that buy the one piece?
Post 764719 by oblark on 2015-03-21 19:57:18
[QUOTE=stribo;764674]I'm still a dick. :slap:[/QUOTE]
Could agree more :P
Post 764727 by Wobbly Dave on 2015-03-21 20:10:56
[QUOTE=oblark;764719]Could agree more :P[/QUOTE] Go on then - I'm intrigued
Post 764739 by JUDGENINJA on 2015-03-21 20:37:02
Ha.... I put all 4 of the V40 gaskets upside down!!! I don't feel as lonely now being a dick!!
Post 764794 by Kingsford G on 2015-03-21 23:19:34
Don`t worry,u r still a good dick lol
