Post 764695 by Ettienne on 2015-03-21 17:23:45
So as I'm keeping the 855r I don't want, I have been looking around the workshop for parts. So far I have found: 19t (rebuilt but leaking exhaust seal) or k24 or 15g (second 19t and k24) Forge actuator. 2.5 stainless rip (actually found 2 top and 4 bottom pipes) Bailey 2 piston dv Uprated rear arb Ipd rose bearing drop links M66 with brackets linkage Brass linkage bushes S60r clutch and flywheel V70 roof bars Many many silicon hoses Blue, white injectors 4.4 ECU Choice of titans (2 sets) Volans Eibach springs (jamest5r cheers buddy) Koni yellows (again James) Ally wishbones Meyle ball joints Polybushes for wishbones Poly lower engine mount Conversion parts for me7 to fit s60r lump I have a choice of brakes Front: 350mm cross drilled front discs on big piston 4 pots 350mm using xc90 calipers 320mm st calipers (under titans) 316 original calipers on brackets (under titans) 312 brembo 4 pots (under titans) Rear: S60r rear calipers 330mm Porsche 911 4 pots 308mm Xc90 rear calipers 308mm (Oblark design) Braided front hoses I think I have the making of a decent car
