Post 765223 by AcidicDavey on 2015-03-25 01:20:44
Hey folks,
This is my breaker, just curious, do we think this is a bent con rod?
The PCV system is blocked and it started making this noise a couple of days after a remap I'm told.
[video=youtube;g_Y9aJTEma0]https://www.youtube.com/watch?v=g_Y9aJTEma0[/video]
Post 765225 by Sweep on 2015-03-25 07:04:46
Sounds more like top end to me?
Post 765229 by LeeT5 on 2015-03-25 07:55:56
If a rod was bent then surely it would misfire on that cylinder. Yours, from what I can hear, is not misfiring. There is definitely a metallic noise but as Sweep says, it's more top end.
Think you'll need to do a compression test to at least isolate the problem. It could also be a hydraulic lifter has gone solid or not filling with oil.
Post 765235 by merc85 on 2015-03-25 08:09:37
[QUOTE=Sweep;765225]Sounds more like top end to me?[/QUOTE]
Strangely the rods do when they go, not Deep knocking sound.
Post 765237 by merc85 on 2015-03-25 08:10:25
[QUOTE=LeeT5;765229]If a rod was bent then surely it would misfire on that cylinder. Yours, from what I can hear, is not misfiring. There is definitely a metallic noise but as Sweep says, it's more top end.
Think you'll need to do a compression test to at least isolate the problem. It could also be a hydraulic lifter has gone solid or not filling with oil.[/QUOTE]
2 850's one being AndysR didnt miss fire with there bent rods
Post 765239 by merc85 on 2015-03-25 08:11:02
Could be a lifter, worth a oil change n filter
Post 765244 by t5 pete on 2015-03-25 08:28:54
Yes they don't miss fire with a bent con rod they do have a destintive noise that gets faster as the revs raise
Post 765347 by AcidicDavey on 2015-03-25 22:21:18
The car went back to the tuners after the noise started, full service yet noise obviously persisted.
If you listen to the clip again yes there is a lot of what sounds like top end tapping but also under that there is a slightly deeper sound tapping noise, the recording has quite picked that up too well :(
Anyway, I don't have a crane and if anyone wants this bare engine they can have it for FREE if they come and remove it out the top as I still need to be able to roll the car around.
Post 765351 by AndysR on 2015-03-25 23:02:27
Sounds rod like to me, as already said mine ran smoothly and perfectly when I bent a rod, you honestly wouldn't have known if you always drove the car with the windows up.
Post 765353 by Biff on 2015-03-25 23:09:49
That's a bent rod if you ask me. Memories!
Mine sounded like the little end, had perfect compression & no miss fire. The rod was certainly bent.
Just for interest when people have bent rods which one went? Mine was number 5.
Post 765358 by jamesy12345 on 2015-03-26 07:04:35
[QUOTE=Biff;765353]That's a bent rod if you ask me. Memories!
Just for interest when people have bent rods which one went? Mine was number 5.[/QUOTE]
I read somewhere that detonation is most likely to be furthest away from the water pump, within the hottest cylinder, so that makes sense
Post 765371 by Doingitsideways on 2015-03-26 10:26:50
I agree Dave. Sounds like a rod.
It sounds deep when the bonnet is down, so not being absorbed by the bonnet insulation = bottom end, but not a deep enough thud to be a thrown big end.
Ah, too much boost, not enough fuel...
Poor thing :(
Post 765393 by mike 850 on 2015-03-26 13:29:51
[video=youtube;URhNeLVb5n8]https://www.youtube.com/watch?v=URhNeLVb5n8[/video]
this was my bent rod
