boost problem and oil leak? help please
Post 769056 by richyt5 on 2015-04-18 21:03:32
As above really bad oil leak from the back of engine up top end and the car is also suffering from boost problems if i dont boot the car and just drive like an old man there doesnt seem to be an oil leak ? Got me puzzled after just putting new plugs leads cap roter arm and coil on her
Post 769057 by claymore on 2015-04-18 21:04:22
Could be the boost pipe off the turbo.
Post 769058 by richyt5 on 2015-04-18 21:07:39
Is that the top pipe ?
Post 769059 by claymore on 2015-04-18 21:12:14
[QUOTE=richyt5;769058]Is that the top pipe ?[/QUOTE] yep, the joiner might even have a split in it, mine split last week.
Post 769061 by richyt5 on 2015-04-18 21:14:47
Aye probly to much boost on yours haha
Post 769063 by richyt5 on 2015-04-18 21:29:06
And where would the oil be coming from?
Post 769064 by jamesy12345 on 2015-04-18 22:33:26
[QUOTE=richyt5;769063]And where would the oil be coming from?[/QUOTE] A bit of oil in the pipes after the turbo is normal but loads could mean the oil is getting past the seals in the turbo.
Post 769065 by richyt5 on 2015-04-18 22:54:02
There isnt oil in the pipes well it wasnt anyways il have a check through week and let you no cheers
Post 769098 by wetwhippet on 2015-04-19 10:10:13
only leaks oil when engines seen boost, can drive all over the county off boost and its dry, sees boost then it leaks..
Post 769107 by stribo on 2015-04-19 11:25:55
Sounds like the turbo oil return pipe seal, got the same problem with mine, when on boost the oil will fire past the seal, and up the back of the engine.
Post 769908 by richyt5 on 2015-04-24 20:51:47
Wel just like to say thanks put new gaskets on return pipe there was a crack on the gasket sorted now no more oil leaks just need to sort the boost problem out does the actuaters ever brake on the 850s?
