Post 769490 by MaxTS on 2015-04-22 09:09:51
Hi,
I tried to drop my radiator to replace my intercooler last weekend but the two 12mm but threaded tabs/nuts on the chassis have both broken free. This now makes it very difficult to remove these bolts now.
Has anyone had this issue before and could suggest a good solution to remove them?
Post 769491 by stribo on 2015-04-22 09:18:53
Yeah, it's very common, the easiest way is to cut the heads off the bolts, then replace them with nuts and bolts when reassembling. If you look at my project thread, there's a complete breakdown of how I did mine on my C70, unfortunately I'm accessing the forum from my phone, so can't link it.
Post 769492 by Nealevo on 2015-04-22 09:20:57
I did the same as above as its a common problem
Stribos thread
http://www.vpcuk.org/forums/showthread.php?45817-Saffy-C70-T5-GT-work-in-progress&highlight=
Post 769493 by MaxTS on 2015-04-22 09:34:39
Great thanks guys.
Sorry if I missed it but what did you use to cut the nuts off? Space seems tight down there!
Post 769494 by dant5r on 2015-04-22 09:57:15
Weld the rivet nuts back to the chassis.
Post 769506 by stribo on 2015-04-22 12:22:56
[QUOTE=MaxTS;769493]Great thanks guys.
Sorry if I missed it but what did you use to cut the nuts off? Space seems tight down there![/QUOTE]
I used a 4" angle grinder, just take your time, use a grinding disc, and literally grind the head off the bolt.
Post 769513 by MaxTS on 2015-04-22 13:19:19
Dan, unfortunately I don't have access to a welded and it will involve grinding the paint, welding and coating which personally seems a lot of faff. But sure if I had the time and tools it does seem the better option.
Thanks Stribo, I will give that a go over the week end :) nice car by the way, I hadn't noticed how much work you have done to it until I read your thread.
Post 769547 by stribo on 2015-04-22 18:52:54
[QUOTE=MaxTS;769513]Dan, unfortunately I don't have access to a welded and it will involve grinding the paint, welding and coating which personally seems a lot of faff. But sure if I had the time and tools it does seem the better option.
Thanks Stribo, I will give that a go over the week end :) [COLOR="#FF0000"]nice car by the way, I hadn't noticed how much work you have done to it until I read your thread.[/COLOR][/QUOTE]
Thanks mate, it's not finished yet, but it's getting there.
