Post 770116 by CAMO on 2015-04-25 20:12:57
Hi, folkes, long time since I was on here, but i've just took delivery of a nice blue 850 T5 auto. In great condition, but has a slight misfire on full chat at approx 4,000rpm upwards. I have done the obvious of change of spark plugs which has made no difference. Normal driving runs smooth as silk, but as soon as you load her up, there is a hesitation/ misfire, which is not releasing the potential of the motor. I suppose the next thing is distributor, leads, and rotor arm???
Post 770128 by stribo on 2015-04-25 20:42:58
[QUOTE=CAMO;770116]Hi, folkes, long time since I was on here, but i've just took delivery of a nice blue 850 T5 auto. In great condition, but has a slight misfire on full chat at approx 4,000rpm upwards. I have done the obvious of change of spark plugs which has made no difference. Normal driving runs smooth as silk, but as soon as you load her up, there is a hesitation/ misfire, which is not releasing the potential of the motor. I suppose the next thing is distributor, leads, and rotor arm???[/QUOTE]
Yeah, the only thing you can do is work through the ignition system.
Post 770147 by Biff on 2015-04-25 21:43:26
I'd try the dizzy cap & rotor arm first as they are the cheapest.
Post 770340 by CAMO on 2015-04-26 20:47:14
Let you know how it develops. Ta!
Post 770344 by CAMO on 2015-04-26 20:52:18
Could well be, may drop the fault code reader on, but it's going to be process of elimination no doubt, dizzt cap, rotor arm, HT lead, coil!!!
Post 772328 by CAMO on 2015-05-10 08:44:03
HT lead is the offender! Power is restored!!!
Post 772597 by Hotz on 2015-05-11 20:50:44
Spray water around the ignition system, to see if the escape energy.
Post 773685 by CAMO on 2015-05-20 22:14:50
All good now, HT lead was knackered. Ta all!!!
