Does the 850 and 850r
Post 772526 by S40kieran on 2015-05-11 10:51:42
Do they have the same flywheel or does the r version have a uprated flywheel I won't to do a smf conversion on my s40 judge has done one on his. The s40 has the m56 box so all is good as I've never had a 850 some advice is great and welcome. Thanks guys
Post 772527 by Tomcat on 2015-05-11 10:53:23
No they share the same flywheel however the R does have an uprated clutch.
Post 772529 by S40kieran on 2015-05-11 10:55:00
Brilliant mate I just wanted to check before I go off and get a flywheel lol.
Post 772549 by 960kg on 2015-05-11 16:03:07
[QUOTE=S40kieran;772526]Do they have the same flywheel or does the r version have a uprated flywheel I won't to do a smf conversion on my s40 judge has done one on his. The s40 has the m56 box so all is good as I've never had a 850 some advice is great and welcome. Thanks guys[/QUOTE] The thing is your conversion may be more difficult as Judges X40 is a 2001 T4 petrol with a 21 spline clutch plate! You are a 2003 Diesel with probably / maybe a 23 spline clutch plate, (you are around the change over years) and what happens with the engine RPM sensor as it is in a different place to the petrol so the cut outs also in the diesel flywheel may be different to suit! I think if you are doing this conversion you will have to tread careful and get all the knowledge you need beforehand.....
Post 772569 by martin_r_smith on 2015-05-11 18:24:36
Hasn't the diesel got a Dmf? The 850 tdi has an M56 gearbox but the flywheel is completely different to a petrol one.
Post 772713 by 960kg on 2015-05-12 12:09:57
[QUOTE=martin_r_smith;772569]Hasn't the diesel got a Dmf? The 850 tdi has an M56 gearbox but the flywheel is completely different to a petrol one.[/QUOTE] Yes, it has ...but the OP wants to fit an SMF in it`s place......:uglyhamme
Post 772717 by S40kieran on 2015-05-12 12:27:07
Martin yes it has but I've stumbled upon a potential problem apparently in 2003 the m56 box gained extra splines on the shaft, and only way to tell is to strip it down and look see if I have the changeover box
