Post 772689 by j@mie on 2015-05-12 07:49:19
Looking into getting new disc and pads all round.
The fronts are severely warped.
Thinking of this lot;
Front Discs: http://www.partsforvolvosonline.com/index.php?cPath=52_54_792
Rear Discs: http://www.partsforvolvosonline.com/index.php?cPath=52_56_801
Front Pads: http://www.partsforvolvosonline.com/product_info.php?cPath=52_53_802&products_id=4579
Rear Pads: http://www.partsforvolvosonline.com/product_info.php?cPath=52_55_803&products_id=4589
Basically, all above Volvo Genuine parts.
Now, I've noticed that you can get bigger front discs 302mm.
Will my car allow this? Are the 280mm standard on the T5-R? Was it an option, or on the R only?
What do people think?
Post 772690 by claymore on 2015-05-12 07:53:50
I would go for the 302 upgrade
Post 772692 by MoleT-5R on 2015-05-12 07:55:32
you just need the 302 carrier brackets ( getting rarer but still out there ), to mount your existing calipers onto and new 302 disc's obviously
Post 772714 by bonelorry on 2015-05-12 12:11:34
Your car already has the 302mm front upgrade Jamie ;)
Surprised to here the fronts have warped as they where fine in my ownership...That said I sold the car almost 2 years ago.
Post 772722 by j@mie on 2015-05-12 13:30:10
Well, bugger me Simon!
I haven't actually had a proper look into what's already on the car.
Yeah, the fronts are terrible. Quite bad to be honest.
I've got the another set of wheels for the car because at least two are buckled. I'm having them all reconditioned as we speak; I'll get some photos up soon.
What's on there at the moment then Simon? Do Volvo actually sell the 302mm? Can I get them from www.partsforvolvosonline.com
Post 772734 by bonelorry on 2015-05-12 15:34:35
[QUOTE=j@mie;772722]Well, bugger me Simon!
What's on there at the moment then Simon? Do Volvo actually sell the 302mm? Can I get them from www.partsforvolvosonline.com[/QUOTE]
Buckled wheels also?
Jesus its been through the wars a bit since I had it. I personally removed and refitted the tyres aswell as re-balanced them in 2013 and they where all nice and straight!
The Discs and pads are Pagid all-round, I replaced them all at the same time as-well as the OSR Brake Caliper. Again fine in my ownership or I would have removed them and had them replaced free of charge under warranty, The only vibration I got when braking was from the rear of the car but that was easily rectified by purchasing some Genuine Brake Pad shims from Volvo. Cured the problem instantly.
http://www.vpcuk.org/forums/showthread.php?51312-Bonelorry-s-854-T5-R-Manual-Creme-quot-Gul-quot-Yellow-project/page4
You can buy the 302mm discs from Volvo if you are going Genuine, They where standard fitment on S70R's and P1 V70R's aswell as other models.
The place I would use and have used for many Genuine parts is FRF Swansea, Speak to Rufe or Simon as he is properly known. Tel: 01792 790066
Post 772800 by j@mie on 2015-05-12 20:51:50
[QUOTE=bonelorry;772734]Buckled wheels also?
The place I would use and have used for many Genuine parts is FRF Swansea, Speak to Rufe or Simon as he is properly known. Tel: 01792 790066[/QUOTE]
Yep, when I brought the car it was the first thing I noticed.
On two of the wheels I had a load of counter-balance weights on the inside, which to me indicated something was wrong...when I got it on the ramp I spun the wheels and they have flat spots which indicate an impact of some sort.
I've actually hardly driven the car since having it; now we all make mistakes now and then...and can honestly say I haven't knocked it the slightest. This car is treated better than my Focus RS.
Another thing I'm going to look into is the gearbox...4th crunches. Going to get the synchros looked at next year. Starter motor is sometimes not releasing as well; going to get a recon one soon (exchange).
To be honest, all these little things are silly, but I enjoy every moment of it. It satisfaction that I know its been done.
Thanks for the contact also Simon at Volvo.
Photo below;
[ATTACH=CONFIG]28900[/ATTACH]
Post 772808 by bonelorry on 2015-05-12 21:09:28
[QUOTE=j@mie;772800]Yep, when I brought the car it was the first thing I noticed.
[/QUOTE]
The weights are packed together like that because of the 5 spoke design of the wheel, You cannot put the adhesive weight's on the outside and on the inside like a conventional alloy wheel design unless you fit the knock on type weights onto the outside lips of the wheel which would damage them and also ruin the looks. So all the weight is placed behind each of the spokes ideally in one place.
Having worked for Goodyear for 8 years I can confirm than Brand new Wheels and Brand new tyres can sometimes take considerable amounts of weight to properly balance! So this is not always an indication of a bent, Damaged or flat spotted wheel.
These where balanced on a Hunter GSP9200 which is one of the finest and most accurate wheel balancers, No flatspots or buckles when I fitted the tyres and balanced the wheels.
However as said this was nearly 2 years ago, It is possible some pot hole damage or whatever has occurred since then. It is easily done with the state of UK roads!
Anyway, Thought I would try and be helpful but reading that back looks like I am trying to explain myself for some unknown reason.
Time for me to keep my mouth shut from now on.
Post 772814 by j@mie on 2015-05-12 21:21:46
[QUOTE=bonelorry;772808]The weights are packed together like that because of the 5 spoke design of the wheel, You cannot put the adhesive weight's on the outside and on the inside like a conventional alloy wheel design unless you fit the knock on type weights onto the outside lips of the wheel which would damage them and also ruin the looks. So all the weight is placed behind each of the spokes ideally in one place.
Time for me to keep my mouth shut from now on.[/QUOTE]
Blimey; you did make sure you did a good job...perhaps I should keep my mouth shut! hehe
