Donnas new motor
Post 773191 by t5 pete on 2015-05-15 22:49:53
Went to meet Jamsey today to collect the s70r as usual it was great to catch up again.
Onto the car
Tbh I really feel sorry for James as this certainly isn't true to its original description and he bought it in good faith.
To start off its needs a fair bit of cosmetic work doing with both front and rear bumpers needing a lick of paint the passenger side wing need re fixing at the bottom and it also needs a new spoiler as it hasn't got one.
I also noticed the bulbs are either out or have been taken out for the abs system and tracs system also the service light aswell
And here's a quick list of what needs doing up to now
The car is currently in limp mode as it will not rev past 3k and with no turbo response what so ever (very long drive home).
The braking system needs a major over haul along with the abs sorting.
one wheel is badly damaged.
the passenger seat electric's do not work and is currently in the most awaked laid back position.
Front suspension needs inspection.
Door Check straps broken.
both front door speakers and dash top speaker not working.
Both front door window motors very weak.
Front passenger wheel bearing is shot.
Bad knocking from front end.
New power steering pump needed.
need to try and repair remote fobs currently broken.
New bulbs for speedo warnings.
Tracking needs aligning.
one new wheel.
new rear spoiler.
And that's with out giving it a look over in the garage I may have time on sunday to get it on the lift and give it a good going over.
One thing I must say James has been fantastic he was extremely honest and has been a true gent.
Post 773193 by Wobbly Dave on 2015-05-15 22:51:05
If you need the ABS ECU fixing up then let me know
Post 773196 by t5 pete on 2015-05-15 22:58:09
Cheers Dave but I do them my self.
Post 773197 by jamesy12345 on 2015-05-15 22:59:54
Glad you got back safe, Pete & good to see you again. Hope the little fella got some food into him sooner rather than later..!
Giving the benefit of doubt - one man's pride & joy is another man's scrapper for sure...but warning bulbs missing is something else and shows intent to hide faults, probably for MOT purposes? Not good at all. I thought the unwillingness to rev would be the MAF but if you've tried a good one it can't be that.
You are a top man for taking that on & keeping it on the forum as I hoped. Certainly worth more in parts atm.
Post 773198 by t5 pete on 2015-05-15 23:02:58
Thank you James regardless of one mans pride and joy he needed to go to spec savers and one thing for sure this will be returned to it original fully working condition to enjoy for many miles.
I am in your debt also just remembered about the wurth dye if you can send me your address ill get it into the post for you.
Cheers
Post 773199 by Wobbly Dave on 2015-05-15 23:03:41
[QUOTE=t5 pete;773196]Cheers Dave but I do them my self.[/QUOTE]
So it is you that's been pinching my trade LOL. NP - if you need an x70 parts then I have a few. What year is it?
Post 773200 by jamesy12345 on 2015-05-15 23:09:38
[QUOTE=t5 pete;773198]Thank you James regardless of one mans pride and joy he needed to go to spec savers and one thing for sure this will be returned to it original fully working condition to enjoy for many miles.
Cheers[/QUOTE]
:lol: at the spec savers comment, can't argue with that
I'll PM you fella about the dye - forgot all about it
[QUOTE=Wobbly Dave;773199]So it is you that's been pinching my trade LOL. NP - if you need an x70 parts then I have a few. What year is it?[/QUOTE]
1998 MY, Dave
Post 773202 by AcidicDavey on 2015-05-15 23:14:53
Nice save Pete ;)
We all know these are well worth saving as they're so rare now and good on Jamesy for ensuring it went to a good home, this boy has his priorities right :)
Sad to hear how badly sold it was or was it a case of 'Must have happened during shipping mate!'. Not good...
Post 773211 by Jamest5r on 2015-05-15 23:33:03
Oh well between fixing wobbly's house and this your gonna be a busy boy :)
Post 773294 by t5 pete on 2015-05-16 17:52:07
Abs system
I've got another ecu that I've repaired in the garage so hopefully it will cure the problems also been reading and this can cause the safe mode
Post 773297 by claymore on 2015-05-16 18:29:37
If the power steering pump is the same as an 850, I've just taken one off the T-10
Post 773301 by t5 pete on 2015-05-16 18:48:31
Cheers Colin that's much appreciated but I've got a few of them knocking around
Post 773309 by foammanmark on 2015-05-16 19:15:27
Nice car and I'm sure that you'll be borrowing that off Donna..............
Post 773351 by t5 pete on 2015-05-16 22:30:02
Abs ecu opened up I can visually see one bad joint but not had chance to get it under scope
Post 773364 by jamesy12345 on 2015-05-16 23:02:50
[QUOTE=t5 pete;773294]Abs system
I've got another ecu that I've repaired in the garage so hopefully it will cure the problems also been reading and this can cause the safe mode[/QUOTE]
Hopefully that list of faults will reduce when the ECU is repaired, interesting about the safe mode. Amazing how much stuff you are finding on this car that hasn't been mentioned before..!
Post 773365 by t5 pete on 2015-05-16 23:11:04
It's just a case of elimination J plugged it into the comp and mainly it's just all the abs faults.
The main fault I'm hoping that's causing it is the 443 I doubt it's the actual pump and just the ecu after doing some reading it seems this can cause the limp mode.
After work tomorrow I'm hoping to get it on the lift and have a further inspection
Post 773443 by t5 pete on 2015-05-17 19:48:41
Abs ecu now re fitted and no codes stored but still have the safe mode issue.
Also got it on the lift and more joys to find
Needs a new steering rack the seals have failed and leaking fluid.
Track rod ends x2
Needs 4 tyres chunks out of side wall and badly perished
Front discs and pads
Bodged fuel line to fuel filter
O/f side cv boot
O/f abs ring
2 new rear shocks
Top mounts X2
Timing belt
N/r side arch liner
Turbo return seals
Post 773446 by Ettienne on 2015-05-17 20:02:08
That should keep you busy for a bit
Post 773447 by t5 pete on 2015-05-17 20:05:30
Certainly will but need to sort this limp mode first before any thing else
Post 773459 by Ettienne on 2015-05-17 21:22:14
Hopefully you can sort that quickly, at least once gone through it should be a reliable motor
Post 773461 by t5 pete on 2015-05-17 21:37:54
Yeah the rest is no concern and easy work but just need to sort the limp mode my main problem is im just packed out with work at the min so only getting the odd hour here and there which is a rite pain.
And with the fcr showing no fault codes its just a case of elimanation
Post 773462 by shepbomb on 2015-05-17 21:42:23
Pete, ill show you how to use vadis/vida and the dice next weekend, that should give a more in depth reading, good luck with this, it would have been too big a project for me
Post 773463 by t5 pete on 2015-05-17 21:45:55
I didnt realise vida/dice would have connected with the car but hopefully one day next week i will get it pluged in.
And yes theres litterly ££££ loads to do lol
Post 773466 by MoleT-5R on 2015-05-17 21:52:00
Is this car originally manual or a conversion jobbie ??? Pete
Post 773469 by t5 pete on 2015-05-17 21:54:57
All original from factory thats whats stumping me as this sort of problem is normally with autos and logs codes but absoutly nothing going to test the tps when i get time then foamy is coming over at the weekend so will do some testing with ecus as his is a v70r
Post 773474 by t5 pete on 2015-05-17 22:11:02
Also forgot to add it needs a pair of head lights as the reflectors are extreamly dull and also needs headlight wipers.
Post 773476 by Ettienne on 2015-05-17 22:15:04
Is it not volfcr as pre me7
Post 773478 by shepbomb on 2015-05-17 22:50:34
It will read codes etc... Just gives very little if any live data, over 2 years since I last played with it, but I also have access to a Delphi setup which will work also
Post 773483 by Ettienne on 2015-05-18 00:09:13
I've got vida and had it for 2 years and pretty good with it now, especially when it comes to the auto gearbox side of things, I offer support to a couple of garages locally when they get problems and they do me favours when I need them I,e if I need a ramp etc, they fitted my downpipe for free, which was nice.
I also have a very good code reader for Volvos that will read anything with an obd2 port as back up for the cars vida won't work on especially the volfcr cars.
Post 773491 by Wobbly Dave on 2015-05-18 08:33:21
I think I have headlights for x70. I've lost count.
Post 773493 by t5 pete on 2015-05-18 08:37:06
I think I bought them off you dave when donna had the c70
Post 773669 by t5 pete on 2015-05-20 20:16:05
Well the limp mode continues roll on the weekend
So far have replaced/tested
Maf
Tcv
Cam sensor
Tested tps
Checked acuator and waste gate
Checked recirculation valve
Replaced all vac hoses
Repaired abs ecu which was logging codes
Coil pack
Rotor arm
Dizzy cap
Leads
Plugs
Starting to run out of items to inspect and replace
Post 773670 by martybelfastt5 on 2015-05-20 20:41:51
:eye-poppi holy sheet quite a list dont like the missing bulbs
Post 773671 by jamesy12345 on 2015-05-20 20:45:49
Pete, just a thought what about battery cables
http://forums.swedespeed.com/showthread.php?122570-B-battery-cables
Post 773672 by Ettienne on 2015-05-20 21:24:59
What about throttle position sensor? Or crank / cam sensors.
I'm sure I read somewhere about it causing limp mode.
Post 773679 by t5 pete on 2015-05-20 21:51:12
[QUOTE=Ettienne;773672]What about throttle position sensor? Or crank / cam sensors.
I'm sure I read somewhere about it causing limp mode.[/QUOTE]
Replaceed all of them bar crank
Post 773680 by t5 pete on 2015-05-20 21:59:11
[QUOTE=jamesy12345;773671]Pete, just a thought what about battery cables
http://forums.swedespeed.com/showthread.php?122570-B-battery-cables[/QUOTE]
Interesting read the j suprisingly the battery is fine and still holding charge but I will certainly inspect the wires
Post 773683 by jamesy12345 on 2015-05-20 22:05:24
[QUOTE=t5 pete;773680]Interesting read the j suprisingly the battery is fine and still holding charge but I will certainly inspect the wires[/QUOTE]
Well the battery that came with the car was far too small so I put a larger one on for u. Looking at that link I posted, the leads can be checked by looking at the condition of ends and checking charging voltage at either end of the cable (battery end and alternator end)
Post 773709 by Ettienne on 2015-05-21 07:20:14
It's not fuel pressure, pump regulator etc?
Post 773729 by t5 pete on 2015-05-21 14:48:29
Spent a little more time on the silver shed lol
New power steering pump fitted now really pissing fluid out of rack but at least it's quiet.
Tried a 3rd maf
Replaced fly wheel sensor
Repaired passanger front wing and mud flap
Inspected passanger seat power is getting to it but still no function.
And naughty naughty the bulbs were missing
New bulbs fitted now much better
Also the drivers dash under tray is missing so also need a new one of those
Also drove it round back with live date and nothing is a miss
So now just got to wait while weekend for when Foamy comes to try his ecu
Post 773865 by t5 pete on 2015-05-23 14:36:07
Update time.
Mark foammanmark came over today which was good to catch up I also tried his spare ecu to which it's didn't make any improvement but the S70r original ecu wasn't showing any fault codes but now I've tried this other one here's what it brought up
I must admit the auto box code threw me enough to ring volvo and ask weather it was a factory manual to which it is so I'm assuming that marks spare ecu must have once come from a auto.
So I've got a few things else to check now but still not actually pin pointing any thing directly.
Post 773867 by jamesy12345 on 2015-05-23 14:48:07
[QUOTE=t5 pete;773865]Update time.
So I've got a few things else to check now but still not actually pin pointing any thing directly.[/QUOTE]
Pete the VIN code starts YV1-LS5002W2 for manuals.
Post 773868 by t5 pete on 2015-05-23 15:11:01
[QUOTE=jamesy12345;773867]Pete the VIN code starts YV1-LS5002W2 for manuals.[/QUOTE]
Cheers j ill have a look when I get back in but volvo them self's said it was a factory manual so I'm just assuming the spare ecu that mark brought came from a auto that's why it's got that code it's weird the the original ecu wasn't logging any codes going the replace tps now for the 444 code and check evap system and fuel rail pressure valve for other code
Post 773872 by jamesy12345 on 2015-05-23 15:41:51
[QUOTE=t5 pete;773868]Cheers j ill have a look when I get back in but volvo them self's said it was a factory manual so I'm just assuming the spare ecu that mark brought came from a auto that's why it's got that code it's weird the the original ecu wasn't logging any codes going the replace tps now for the 444 code and check evap system and fuel rail pressure valve for other code[/QUOTE]
Just a thought - if a knackered ABS ECU can cause limp mode....is the right unit fitted?
https://www.midwest-abs.com/Troubleshooting.php
Post 773874 by t5 pete on 2015-05-23 15:54:57
I re fitted the oiginal abs pump yesterday as it was a replacement I put on while I repaired the one all faults are gone on both pumps bar a left wheel sensor so looks like that's another fault to sort.
I've also bee reading and they do have a accelerometer sensor fitted which can reduce performance and mpg
Post 773877 by foammanmark on 2015-05-23 17:38:19
Great to see you today Pete, and glad that the ecu helped by throwing up some codes that might help you. Cheers for reading my codes and for the brew as well. The car will be no doubt be a belter when you sort her.
Post 773895 by t5 pete on 2015-05-23 19:12:36
Post 773897 by t5 pete on 2015-05-23 19:17:31
I rememeber reading through nordicks threads and noticed he said he had fitted a new rad ive noiced the rad pack is loose so im hoping he may have forgot to connect it back up.
I wonder if it was since he changed the rad when this problem started as also on vida it stated this failing can also bring the code 621 up fuel tank pressure sensor fault.
Post 773900 by 500tie on 2015-05-23 19:26:31
What a nightmare motor fair play for sticking with it, it'll be a proper sorted R once you've finished with it mate
Post 773901 by t5 pete on 2015-05-23 19:44:05
[QUOTE=500tie;773900]What a nightmare motor fair play for sticking with it, it'll be a proper sorted R once you've finished with it mate[/QUOTE]
Thank you it will certainly scrub upto be a nice car with a lick of paint and ironing out all the faults but one thisngs for sure it cannot be quicker than my gul as theres no way the misses is having a faster car than mine lol
Post 773905 by foammanmark on 2015-05-23 20:01:19
Looking good on the boot spoiler side of things, and hopefully I can let you know more tomoz. Also asked about the driver's side lower dash trim...........
Post 773906 by foammanmark on 2015-05-23 20:02:10
[QUOTE=t5 pete;773901]Thank you it will certainly scrub upto be a nice car with a lick of paint and ironing out all the faults but one thisngs for sure it cannot be quicker than my gul as theres no way the misses is having a faster car than mine lol[/QUOTE]
With that mapped ecu, it could be close!!
Post 773913 by t5 pete on 2015-05-23 21:25:11
Hummm just looked for the accelerometer where vida said it would be but nothing
Post 773915 by Shinsplintz 101 on 2015-05-23 21:40:40
We nailed down a similar problem on my dads v70 the same way. So many codes we couldn't figure out what was happening.Looked deeper on Vida for what wasn't showing up where it should be. Big fat whole where the abs module should have been. Sometimes looking for the needle you just have to take the haystack out of the picture. good luck with the search fella.
Post 774093 by t5 pete on 2015-05-25 15:57:52
Hopefully sorted and due to a blocked cat removed it from the exhaust housing today and there is certainly an improvement even with it running rough with the down pipe missing so hopefully got a spare in garage and will fit it possibly next weekend if I have a hour free.
Also any one got any crystal head lights for sale as I need to renew the head lights any way.
Post 774111 by MoleT-5R on 2015-05-25 18:31:02
just bash the inners out with a long bar, that's how my olive got de-catted when the cat collapsed and as the dp was still useable I saved a few quid
Post 774112 by t5 pete on 2015-05-25 18:37:03
I think I've got a spare cat in other garage and I'm sure I also bought the dwarfs s70r cat when I fitted him a race cat either way the blocked one will be getting weighed in
Post 774438 by t5 pete on 2015-05-28 19:59:52
Roll on tomorrow and hopefully the running issue should be sorted also been collecting other parts for the car which I didn't have so now got
Custom rear spoiler
Crystal head lights
Stainless exhaust
5 tyres
And a comet of wobbly
Hopefully if all goes well tomorrow ide like to have every thing sorted bar wheels and paint next weekend.
Post 774441 by 500tie on 2015-05-28 20:51:33
Be nice to get her sorted Pete hopefully the replacement cat will sort it I'm looking forward to seeing this custom spoiler though
Post 774446 by martybelfastt5 on 2015-05-28 21:47:35
sounds good cant belive many issues this had nearly bought it myself
Post 774447 by t5 pete on 2015-05-28 21:55:13
[QUOTE=martybelfastt5;774446]sounds good cant belive many issues this had nearly bought it myself[/QUOTE]
Yep absolutely loads tbh most would have scraped it once I've sorted the running issue ill post up with all the works that's needed doing
Post 774474 by t5 pete on 2015-05-29 09:17:27
Holy moly it's alive I don't know if the original ecu has been mapped but it's certainly quick
Post 774493 by jamesy12345 on 2015-05-29 11:21:59
[QUOTE=t5 pete;774474]Holy moly it's alive I don't know if the original ecu has been mapped but it's certainly quick[/QUOTE]
what was it, the cat?
Post 774561 by t5 pete on 2015-05-30 08:13:56
When I came back in last night I built the front brakes back up so that's now new discs and pads.
Post 774564 by jamesy12345 on 2015-05-30 09:02:19
There's not many people would have done all this work Pete, nice one...like trigger's broom this car now :)
Post 774567 by t5 pete on 2015-05-30 09:39:32
[QUOTE=jamesy12345;774564]There's not many people would have done all this work Pete, nice one...like trigger's broom this car now :)[/QUOTE]
Pmsl yes i think most would have broken it but I gave you my word I would do every thing possible to get it up and running and she certainly will be
Post 774573 by t5 pete on 2015-05-30 12:17:00
And a quick lick of gold to replace the red
Post 774635 by AcidicDavey on 2015-05-30 20:31:23
Very good Pete, well pleased to hear you finally got to the bottom of this :D
Post 774715 by t5 pete on 2015-05-31 19:23:15
Had a hour today and got all the front end mechanical work done bar the seals in steering rack I striped the front suspension to fine the knocking and it was down to the left strut top bolt being loose.
Hopefully on Tues I can sort the rear brakes and adjust the hand brake and also a set of new rear shocks then all that's left is underseal.
Post 774729 by martybelfastt5 on 2015-05-31 20:36:32
exellent
Post 774743 by AcidicDavey on 2015-05-31 21:30:43
I packed your headlights etc up this afternoon for you Pete and I'll be dropping them off at the parcelshop for you tomorrow.
Looking forward to seeing them on it :)
Post 774747 by Doingitsideways on 2015-05-31 21:36:42
Glad this has been rescued.
Jay offered it me at one point, and to be honest I'm glad I didn't take it on, but only because I wouldn't have been able to lavish it with the attention that you have Pete.
Top work that man, many would have considered it too far gone and broken it. :)
Post 774750 by NORDIC R on 2015-05-31 21:47:04
Woooooooooooooooow!
I honestly thought this car was in pretty good condition
Before we go any further I had absolutely no idea about the dash lights
Fuel line bodge job yes but defo not the dash lights. Too think that I had my daughter in this car thinking she was safe has stunned me!!!
James I apoligise on that front pal
T5 Pete glad too see its in good hands and getting re vamped
Health too enjoy it
Post 774751 by NORDIC R on 2015-05-31 21:52:28
Mail me your address I will post u the origanal spoiler
Post 774753 by jamesy12345 on 2015-05-31 22:10:52
[QUOTE=NORDIC R;774750]Woooooooooooooooow!
Health too enjoy it[/QUOTE]
No worries fella, thanks for that. Yes there was stuff that I was surprised about but tbf sitting for a few months over the winter didn't help either. Peter is bringing it up nice now so no harm done and another one saved.
Post 774789 by t5 pete on 2015-06-01 18:22:29
[QUOTE=AcidicDavey;774743]I packed your headlights etc up this afternoon for you Pete and I'll be dropping them off at the parcelshop for you tomorrow.
Looking forward to seeing them on it :)[/QUOTE]
I cannot wait to get them fitted it will transform the car
Post 774794 by 500tie on 2015-06-01 18:32:47
[QUOTE=t5 pete;774789]I cannot wait to get them fitted it will transform the car[/QUOTE]
They certainly having seen them in the flesh they are pretty mint mate
Post 774799 by stribo on 2015-06-01 19:11:55
Good to see another one being saved mate, as you say most would have scrapped it, but some have to be saved. We've done the same with the V70R, we bought it knowing it needed work, but probably weren't aware how much, it's since had a replacement auto box, new rad, new front wishbones, new track rod end, new heater matrix, new cam seals, new ignition system etc. It was worth saving though, just a shame we'll be selling it soon.
Post 774858 by t5 pete on 2015-06-02 14:36:42
Had a nice parcel today
And also the driver's lower trim
I must say a big thank you to AcidicDavey for the items
Post 774957 by t5 pete on 2015-06-03 16:04:04
Productive day today
Replaced front speakers now all working
Got central locking working and repaired drivers side
Replaced driver rear caliper as old one cast had broken for pins
Adjusted hand brake
I'm sure I read that it'd had new cables certainly not and their very tired so need new cables for next mot
Post 775537 by Jamest5r on 2015-06-09 18:10:50
Is that fish eyes I see :)
Post 775545 by t5 pete on 2015-06-09 19:23:01
[QUOTE=Jamest5r;775537]Is that fish eyes I see :)[/QUOTE]
I'll give ya a black eye never mind fish eye lol
Post 775608 by t5 pete on 2015-06-10 18:04:58
Just need to leave them a few days then it's a cut and polish
Post 775617 by 500tie on 2015-06-10 19:28:10
I really like the exhaust mate, the bumpers have come up a treat too it's going to look bloody good when you've finished
Post 775618 by jamesy12345 on 2015-06-10 19:33:09
Looking much better even just in the shott time you've had it, Peter
Post 775624 by t5 pete on 2015-06-10 20:09:21
[QUOTE=jamesy12345;775618]Looking much better even just in the shott time you've had it, Peter[/QUOTE]
Yep it certainly has had some work done but by next week it will be fully up to scratch just need to wait on the number plate transfer from donnas old car and then it can be getting used
Post 775677 by t5 pete on 2015-06-11 15:53:21
Replaced gear knob
And just in time
Post 775678 by foammanmark on 2015-06-11 15:58:24
Looking good Pete and I bet you're looking forward to having her on the road.
Post 775727 by t5 pete on 2015-06-12 12:15:26
Timing belt all done today and new serpentine belt
New oil and filter
New coolant
Went to fit spoiler and nuts on brackets are absolutely sized in and are now just spinning so that's that spoiler out of the question as with it being a 850 on they need the brackets to hold them down on the s70 boot.
Post 775728 by stribo on 2015-06-12 12:52:25
[QUOTE=t5 pete;775727]Timing belt all done today and new serpentine belt
New oil and filter
New coolant
Went to fit spoiler and nuts on brackets are absolutely sized in and are now just spinning so that's that spoiler out of the question as with it being a 850 on they need the brackets to hold them down on the s70 boot.[/QUOTE]
You were lucky with that timing belt.
Post 775733 by t5 pete on 2015-06-12 14:03:40
[QUOTE=stribo;775728]You were lucky with that timing belt.[/QUOTE]
Yep certainly was tbh there were a few things I've noticed with the car that's I've been lucky with for instance on two of the tyres the inside wall have really deep gouges
Post 775734 by stribo on 2015-06-12 14:32:30
You should buy a ticket for tonight's Euromillions. ;)
Post 776082 by t5 pete on 2015-06-16 17:55:29
Dropped wheels off at metal magic and decided to alter the 850 spoiler so it does fit correctly and drilled the original bolts out of the brackets that were just spinning.
Post 776122 by The Flying Moose on 2015-06-16 20:24:02
Coming along really nicely Pete, a real testament to your workmanship.
Do you have any advice for painting bumpers? My front and rear if I wanted to tidy the V70 up could do with paint but only if a reasonable job can be done by a home mechanic on a budget...dirty TDI doesnt want much spending on her!!! ;)
Post 776126 by t5 pete on 2015-06-16 20:29:29
Erm as for paint best thing is preperation and a clean environment tbh as long as you take your time and not slap it on too heavy it will be more than a acceptable job.
Post 776208 by t5 pete on 2015-06-17 18:10:07
Thought ide give my self some motivation on the silver shed today so decided to wet sand and cut the rear bumper
Also treated my self to a new gun as the suction fed one is past its day
Post 776218 by Blackdog on 2015-06-17 20:03:36
Wheel colour....Do you want a picci of an anthracite against the silver?
Post 776226 by Ettienne on 2015-06-17 21:17:48
Looking very good nice work and a good save on the Cambelt
Post 776228 by stribo on 2015-06-17 21:25:55
[QUOTE=t5 pete;776082]Dropped wheels off at metal magic and decided to alter the 850 spoiler so it does fit correctly and drilled the original bolts out of the brackets that were just spinning.[/QUOTE]
Do you still want the S70R spoiler?
Post 776229 by t5 pete on 2015-06-17 21:35:29
[QUOTE=stribo;776228]Do you still want the S70R spoiler?[/QUOTE]
Yes please
Post 776639 by craigoodwood on 2015-06-23 19:36:53
your mancave is awesome :)
Post 776646 by t5 pete on 2015-06-23 20:14:39
Lol yeah ypu should see the other side there's a great big bundle of electrical tape rolled round the cable god knows what it's hiding that's the next job once funds allow a pair of new cables
Post 776648 by stribo on 2015-06-23 20:50:57
[QUOTE=craigoodwood;776639]your mancave is awesome :)[/QUOTE]
I thought only Wobbly Dave had ventured into his man cave.lol
Post 776651 by Doingitsideways on 2015-06-23 21:08:27
[QUOTE=stribo;776648]I thought only Wobbly Dave had ventured into his man cave.lol[/QUOTE]
With the strap-on?
[QUOTE=stribo;776649] has the car lived by the sea by any chance?[/QUOTE]
Looks like it's lived IN the sea!!
Post 776653 by jamesy12345 on 2015-06-23 21:16:57
[QUOTE=Doingitsideways;776651]...
Looks like it's lived IN the sea!![/QUOTE]
I was thinking that....! Pete must the first guy doing any work on the thing (other than taking bulbs out that is)
Post 776655 by stribo on 2015-06-23 21:33:22
[QUOTE=Doingitsideways;776651]With the strap-on?
[/QUOTE]
TBF he had a spare condom. ;)
Post 776791 by t5 pete on 2015-06-25 15:47:02
Because it's wurth it
Post 776860 by Wobbly Dave on 2015-06-26 16:23:11
Good colour match
Post 776865 by Nealevo on 2015-06-26 17:42:40
Nice tyres.
Post 776866 by t5 pete on 2015-06-26 18:31:11
[QUOTE=Nealevo;776865]Nice tyres.[/QUOTE]
Yeah got them off some nice bloke with a pink volvo estate
Post 776868 by kmb on 2015-06-26 19:16:45
Look great!
Post 776872 by AcidicDavey on 2015-06-26 19:32:20
They look really good, not too dark. ;)
Post 776875 by t5 pete on 2015-06-26 19:55:44
[QUOTE=AcidicDavey;776872]They look really good, not too dark. ;)[/QUOTE]
Yes that's the colour I should have done the titans in for the gul but never mind I was torn between this colour and silver but I went for the contrast and as ypu said there not too dark so should still keep the car nice and bright
Post 776900 by t5 pete on 2015-06-26 21:24:15
[QUOTE=stribo;776895]I can't believe you've put them on the bonnet. :slap:[/QUOTE]
Pmsl your the second person to say that, that's the 240 bonnet that's getting ripped Appart
Post 776904 by Doingitsideways on 2015-06-26 21:29:50
[QUOTE=t5 pete;776900]Pmsl your the second person to say that, that's the 240 bonnet that's getting ripped Appart[/QUOTE]
Now you mention it, it's bloody obvious!!
They look really good, Pete.
Graphite wheels always look awesome on a silver car.
In fact, they'll look NEARLY as good as this:
Pmsl :D
Post 776908 by AcidicDavey on 2015-06-26 21:34:40
I nearly wrote an angry response to seeing them being on the bonnet but just spotted it was the 240 and shut up lol
Post 776912 by t5 pete on 2015-06-26 21:59:20
Pmsl as my favourite saying goes people who make assumptions are normally wrong
Post 776913 by stribo on 2015-06-26 22:00:32
I have no knowledge of these old fashioned Volvos. ;)
Post 776914 by Doingitsideways on 2015-06-26 22:07:18
[QUOTE=t5 pete;776912]Pmsl as my favourite saying goes people who make assumptions are normally wrong[/QUOTE]
Or, one of my personal favourites...
Assumption is the mother of all f##k-ups!
Post 777321 by jamesy12345 on 2015-07-01 17:17:50
Is this the same car..!
Post 777326 by t5 pete on 2015-07-01 17:57:30
[QUOTE=jamesy12345;777321]Is this the same car..![/QUOTE]
Erm the shame shell interior and engine most other things have been replaced certainly needed it
Post 777328 by Ettienne on 2015-07-01 18:04:28
Glad u finally sorted the issues, looks a different car, pity my wife is not a Volvo fan be an excuse to buy another
Post 777329 by t5 pete on 2015-07-01 18:11:56
[QUOTE=Ettienne;777328]Glad u finally sorted the issues, looks a different car, pity my wife is not a Volvo fan be an excuse to buy another[/QUOTE]
Yeah certainly is back up and running 100% hopefully by the weekend or eairly next week we should have it on the road.
Tbh my wife isn't too bothered what she drives so I just get to pick them Donna did want wobblys convertible a month ago but there just not practical for us.
Post 777337 by Shinsplintz 101 on 2015-07-01 19:34:12
Top work again Pete. Now stop messing about with the easy stuff & get back to turning the 240 into a rwd monster!
Post 777340 by t5 pete on 2015-07-01 19:52:55
[QUOTE=Shinsplintz 101;777337]Top work again Pete. Now stop messing about with the easy stuff & get back to turning the 240 into a rwd monster![/QUOTE]
The 240 will be getting done but as and when funds allow doing things like this on the t5's are pretty cheap but building a 16v turbo is stupidly expensive saying that tho ill soon be doing the manual conversion then it's a case of pistons and rods for the red block
Post 777342 by jamesy12345 on 2015-07-01 19:59:20
[QUOTE=t5 pete;777326]Erm the shame shell interior and engine most other things have been replaced certainly needed it[/QUOTE]
I'm glad you could see the potential in it fella
Post 777343 by t5 pete on 2015-07-01 20:06:03
[QUOTE=jamesy12345;777342]I'm glad you could see the potential in it fella[/QUOTE]
There was certainly potential in the car it was just a case of the ammount of work needed if some one had to take it to a garage to be done it would just not be viable due to cost but with being able to do it my self and having a fair few parts my self made it all worth it and now touch wood it should be a good reliable motor for the misses and the kids.
I'm just happy to have been able to restore another one to good spec and with out your fairness I doubt it wouldn't have happend it's much appreciated.
Post 777346 by stribo on 2015-07-01 20:12:18
TBF, I think after the Gul, this was going to be a walk in the park, but still great work, and it does help being able to do the work yourself, and a bonus you happen to have some spares on stock. :B_thumb:
Post 777347 by jamesy12345 on 2015-07-01 21:18:59
[QUOTE=stribo;777346]TBF, I think after the Gul, this was going to be a walk in the park, but still great work, and it does help being able to do the work yourself, and a bonus you happen to have some spares on stock. :B_thumb:[/QUOTE]
True enough...it's surprised me how much gear Peter has in his man cave. Something to aspire to!
Post 777348 by stribo on 2015-07-01 21:29:48
[QUOTE=jamesy12345;777347]True enough...it's surprised me how much gear Peter has in his man cave. Something to aspire to![/QUOTE]
True enough, but I have loads of stuff in my garage, whether I'll actually need it or not I've no idea, in fact I still have rakes of Cougar parts, including a spare door and wing, that I'll never use. :slap:
Post 777349 by jamesy12345 on 2015-07-01 21:46:08
[QUOTE=stribo;777348]True enough, but I have loads of stuff in my garage, whether I'll actually need it or not I've no idea, in fact I still have rakes of Cougar parts, including a spare door and wing, that I'll never use. :slap:[/QUOTE]
I did have a garage full of spares but had a big clear out when I thought my 400-series days were over...2 months later & now have a 440 & a 480 again....:) that reminds me I recently emptied out my ma & da's garge also and threw out some Renault 5 Campus front wings that had sat in the rafters for almost 20 years......might've come in handy one day!!
The pics that Pete is showing this thread he could do this as a business....if only he reduced the quality of his work as otherwise he wouldn't be making a profit...! I am firmly in the category of 'all the gear, no idea'...without the gear...
Post 777350 by t5 pete on 2015-07-01 21:59:41
[QUOTE=jamesy12345;777349]I did have a garage full of spares but had a big clear out when I thought my 400-series days were over...2 months later & now have a 440 & a 480 again....:) that reminds me I recently emptied out my ma & da's garge also and threw out some Renault 5 Campus front wings that had sat in the rafters for almost 20 years......might've come in handy one day!!
The pics that Pete is showing this thread he could do this as a business....if only he reduced the quality of his work as otherwise he wouldn't be making a profit...! I am firmly in the category of 'all the gear, no idea'...without the gear...[/QUOTE]
Why thank you that's really appreciated but as you know I could never make a profit as I just get so carried away and every thing has to be spot on and other than that I don't get a minute to scratch me arse that's why I have Jamest5r as my secretary bitch I think he likes it as well
Post 777596 by t5 pete on 2015-07-05 00:12:09
Cool haven't tested them yet they were some I just had in stock but there just the same as the v40 ones
Post 777602 by Ettienne on 2015-07-05 07:59:48
Me7 washer jets from p2? Rather than me7 p1?
Post 777603 by p fandango on 2015-07-05 08:05:11
[QUOTE=stribo;777593]just need to buy another set for the V70R now, as we're keeping it.[/QUOTE]
sure i've got a set in the garage, PM me your address & i'll put them in an envelope for you
Post 777612 by stribo on 2015-07-05 11:05:53
[QUOTE=p fandango;777603]sure i've got a set in the garage, PM me your address & i'll put them in an envelope for you[/QUOTE]
PM sent.
Post 777614 by foammanmark on 2015-07-05 12:47:37
Pete, are you still running the mapped ecu that you bought off me in her joi?
Post 777632 by t5 pete on 2015-07-05 16:36:08
Hey Mark once we've got the car on the road ill be putting that ecu in to see how it is
Post 777633 by foammanmark on 2015-07-05 17:14:46
[QUOTE=t5 pete;777632]Hey Mark once we've got the car on the road ill be putting that ecu in to see how it is[/QUOTE]
OK, and I hope it works well for you. It'd be good to see the car when she's finished as I saw her when you first got her, and from the pics above you've done it again Pete China.
Post 777701 by t5 pete on 2015-07-06 22:47:37
Jobs for tomorrow fit tow bar and electrics, bolt back bumper and fixings, fit exhaust, under seal, get passanger seat working or at least in a decent position while I source a new switch pack, wash, clay, polish,wax and test drive
Post 777731 by jamesy12345 on 2015-07-07 18:36:21
Well done fella some effort put in there, looks great. Glad the car went to you
Post 777732 by AcidicDavey on 2015-07-07 18:37:22
Very nice matey, another one saved ;)
Post 777738 by Jamest5r on 2015-07-07 19:25:32
Superb.:)
Post 777739 by martybelfastt5 on 2015-07-07 19:38:43
that looks exaclty how it should well done pete:)
Post 777741 by foammanmark on 2015-07-07 19:49:00
Looking great Pete and I hope that Donna appreciates what's gone into getting her car looking like that(my wife wouldn't..........).
Post 777742 by t5 pete on 2015-07-07 19:50:17
She better do or its back to walking lol
Post 777744 by hemihusky on 2015-07-07 19:50:45
looks absolutely amazing as usual pete. hope to see this at a show sometime
Post 777745 by Doingitsideways on 2015-07-07 19:50:45
Proper job that, Pete :)
Post 777750 by 500tie on 2015-07-07 20:25:35
Bloody lovely mate top work saving that one
Post 777756 by martin_r_smith on 2015-07-07 21:34:22
Wow! Top work as usual pete, looks the nuts.
Post 777758 by stribo on 2015-07-07 21:51:30
Looking good mate. :D
Post 779015 by t5 pete on 2015-07-24 18:04:43
Hey Adrian it's a power flow exhaust I bought a while ago only 2.5" but it will do for the S70r.
I'll be coming in the s70 as got to bring a trailer now we've got rid of the estates not a very wise move lol cost me 680 for trailer 400 new tent 220 tent awning and all camping gear who said campin was cheap
Post 779024 by LiamT4 on 2015-07-24 18:51:31
Looking good now pete, reminds me of a car i used to own ;)
Post 780689 by t5 pete on 2015-08-06 22:13:08
Finally got round to sorting most of the final issues.
Fitted a new rear abs loom as the rear right was still coming up with a code eluminating the abs light so that cured that.
But now the pedal is grinding below 10mph which feels to be from the passanger side as this was problematic while I had all the issues so I'm assuming it's the ring which will be replaced that and that's the only thing left that hasn't been renewed.
Also when braking the car was pulling to the right badly so a quick Inspection showed the bushes on the n/r side were absolutely shot.
And as usual nothing is ever straight forward with this car some one had bodged a threaded bar through one of the mounting points instead of a bolt that should be there, so engine jacked up and new bolts installed.
Going to put a new ring on tomorrow and that should see all of the jobs done on the s70 and every thing will all be back to standard spec.
Post 780731 by t5 pete on 2015-08-07 12:12:20
Front abs issue all sorted ide fitted a used hub witch all ready had a sensor in but upon inspection today it wasn't seated correctly finally a nice and easy fix.
Fingers crossed that's all the jobs done also got the passanger seat fully working
