Post 773311 by foammanmark on 2015-05-16 19:23:38
So I have very limited mechanical knowledge, but I'm learning some things with various issues with my 9-5. Started with an engine oil/filter/plug change, which led to cam cover gaskets and de-sludge, then full PCV system replacement but I still had a bad oil leak. Now doing the oil cooler pipes as one is leaking very badly. Sump drop and de-sludge is next on the list. Do Volvos not suffer with the sludge which seems to be a major Saab issue?
I know the above is pretty simple by some of your standards but for me it's a real achievement.......
Post 773316 by Harvey on 2015-05-16 19:29:58
The sludge comes from wrong grade of oil and it not being fully synthetic and/or not changing the oil at the correct intervals.
Post 773318 by Blackdog on 2015-05-16 19:30:53
Once you have desludged use synthetic oil and you should have no more issues.
Former 9-5 aero owner.
Post 773319 by foammanmark on 2015-05-16 19:31:48
[QUOTE=Harvey;773316]The sludge comes from wrong grade of oil and it not being fully synthetic and/or not changing the oil at the correct intervals.[/QUOTE]
It'd done 136k when I bought her and I run her on 5w-30 fully synth, so previous owners must have used the incorrect grade. It's an Aero and should be fully synth.
Post 773323 by foammanmark on 2015-05-16 19:36:33
[QUOTE=Blackdog;773318]Once you have desludged use synthetic oil and you should have no more issues.
Former 9-5 aero owner.[/QUOTE]
What year was your's joi? Mine is a 2002 and on the original PCV, so well overdue replacing. The sludge wasn't as bad as some pics I've seen but the oven cleaner got rid of what was there.
Post 775679 by foammanmark on 2015-06-11 16:23:29
Well, another expensive part and the Aero is running the best that she has done since I got her. That DI cassette needed replacing at £180, but hopefully that's an end to the issues, or else she'll be looking a new Home.
Post 775743 by stevie69 on 2015-06-12 15:59:55
I had a 2002 9-5 aero after my 850.got mine mapped where I bought the whole ecu..still got my original if you want it..you can send it away to get mapped and save buying another like what I did..guys called saabnoob on uksaabs..
Post 775747 by foammanmark on 2015-06-12 16:57:11
[QUOTE=stevie69;775743]I had a 2002 9-5 aero after my 850.got mine mapped where I bought the whole ecu..still got my original if you want it..you can send it away to get mapped and save buying another like what I did..guys called saabnoob on uksaabs..[/QUOTE]
That guy was at the Midlands RR day the other week in his latest Saab, when we had a Saab v Volvo day. Cheers for the offer and mapping is my intention when I know that I have sorted all the issues, so I may be in touch.
Post 775749 by stevie69 on 2015-06-12 17:02:21
no prob..I went stage 1.if I was doing it again id go straight to stage 3..if you blank of 1 of the pipes on the boost control thing you get all your lost boost back..
