Post 775035 by sye73 on 2015-06-04 21:11:21
Hi
Please could someone confirm if longer brake lines are required when fitting the 302 discs to an 850r ?
If so, where is the best place ( and brand ) to buy them from ?
I also need a pair of genuine Volvo rear discs and some pads. Will probably go standard pads for the rear and something like Ferodo ds2500 for the fronts ?
Best deals around right now? Wondered if anyone had some good deals of late?
Cheers
Post 775036 by Ettienne on 2015-06-04 21:18:38
Yes you need longer hoses, 400mm iirc someone else will know where to get consumables
Post 775037 by claymore on 2015-06-04 21:27:25
No you don't need longer lines, I've never used longer lines on either of my cars with 302's, although, if you are putting new lines on then you may as well go for the longer ones.
Post 775038 by bonnietiler on 2015-06-04 21:34:37
Mine fitted a treat no problem, no need to change?
Post 775039 by p fandango on 2015-06-04 21:36:59
volvo changed to longer hoses for a reason, for the sake of £20-30 its got to better to be safe than sorry (especially on brakes)
Post 775042 by Ettienne on 2015-06-04 21:45:00
I had braided 280 lines on the Gul and they wouldn't have worked, but some standard ones were longer (280 again) but may as well go braided when you can if your happy they fit.
Post 775119 by sye73 on 2015-06-05 21:18:23
Thanks for the thoughts
Cheers
